Question about Norelco Reflex 5825 XL Electric Shaver
Does the 5825 charge only on a single voltage (120 or 230 volts ac) or is it 100 to 250 volts usable everywhere.
  • 577 Answers
Hello, It depends where you bought it.But now a days most of the power units come either in DUAL VOLTAGE (switchable ) or UNIVERSAL VOLTAGE ..USA (110 v AC) and European (230 V AC )..it works in between.The later one automatically accepts the plug in voltage without any switch.
If you look carefully his info should have been posted ( with tiny letters ) onto the power adapter.
Regards
Posted on Oct 06, 2010
  • Norelco Master
  • 1,610 Answers
Model 5825XL can be used with 100-240V as it has an internal automatic voltage converter
Atv charging problems
115 ac volts at idle seems very high to me. if all 3 coils are putting out the same voltage I'd say its ok.
Jan 29, 2016 | Polaris ATV
Tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
on May 14, 2015 | Xantrex Technology Electronics - Others
Need a wireing diagram for 149 cub cadet mower tractor it does not charge
The Battery Won't Charge or stay charged.
Several possibilities
  1. Key switch doesn't turn off the system and the battery drains while it's parked.
  2. Bad insulation on the wiring somewhere and the battery drains down.
  3. The alternator is not putting out enough power or no power at all.
  4. The battery is bad.
Let's consider the battery first. This is an easy check if you have a cheap, simple volt meter. It's much better to have an old fashioned needle meter rather than a digital. The needle is more sensitive, much quicker, and makes a clearer diagnostic tool. But not to worry, for you fancy folks a digital still works (sometimes the results are not as easy to decipher).
  1. Set the meter to DC Volts.
  2. Attach the red and black leads of the meter to the positive and negative posts of the battery. Most modern day digital meters don't care if the polarity is correct or not. However, if you have a needle meter, best to put the positive of the battery with the red wire of the meter; otherwise the needle will not be happy with you.
  3. Note voltage. It should read near or above 13 volts if the battery is good and fully charged. If it reads below 12 volts the battery needs charged or it has bad cells. If after charging a few hours, the voltage is still below 12 volts then the cells are bad, replace it. That should solve your problem. If not...continue.
  4. "Load Test". Turn the key to crank the engine while keeping your eyes on the meter. Whether the engine cranks (turns over) or not, the meter should not fall much below 11 Volts. If it falls below 10 volts or worse yet below 9 volts, the battery has a bad cell or two. Replace the battery, charge it, and repeat the test.
  5. If the engine starts, rev it up and watch the meter.
    1. If the charging system is working the voltage on the meter should quickly rise above 13 volts.
    2. If it rises up strongly towards the 14 volt range this indicates the charging system of the machine is working.
    3. If it plays around down near 12 volts you are reading the recovered voltage of a good battery, but the charging system is not working.
    4. If it simply stays below 11 volts, the battery and the charging system are both suspect.
      1. Charge you battery.
      2. Repeat the test.If you get the same results...continue
      3. Replace the battery.
      4. Fully charge it,
      5. Repeat the tests before worrying about the charging system.
Note: if the battery falls below 9 volts the fuel cut off, a black cylinder on the bottom of the carburetor (if your model has this), will cut off the gas supply to the carburetor.
If the battery passes all the tests and you still don't get 13-14 volts of charge it's time to test the charging system.
Small engines have 3 different possible alternators, standard circuit, dual circuit, tri circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is the same multi-meter used for battery testing. Do take note: The settings for battery testing are DC Volts. The Settings for Stator or Alternator testing are AC Volts (in the 50 Volt range).
  1. Disconnect the connector from stator. The stator is right there on top of the engine under the plastic/metal fan guard. Take this off and look for a pigtail wire with a connector. Don't get the coil wire with the spark plug end.
  2. Set multi-meter for AC volts.
  3. Attach RED test lead to either pin on stator side of stator connector. (On single wire leads, attach RED test lead to the single pin.) On AC output alternators there is no positive or negative because both wires alternate from positive to negative, so either pin will do.
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine or other ground.
  5. Prepare the lawn tractor for engine start (set parking brake). Start engine and run at full throttle.
  6. Check output. Output for engines of this general size run in the 30 to 50 volt range. For instance the B&S V twin 22 hp AC output at full throttle is 30 Volts minimum. Other B&S on these machines spec 40 Volt minimum.
If your voltages are not in the manufacturers range (too low), or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
A. In the picture is a single lead stator connector.
B .In the picture is a two wire lead stator connector.
Mar 18, 2015 | Cub Cadet Garden
I have a charging problem with JD L155c lawn tractor. The battery is new and the voltage to the battery is 12 volts. Not enough to charge the battery. How do I check the ac voltage & what should the...
There are several possible Mowers of the "L" 155 versions.
John Deere LA155 garden tractor lawn mower. These stopped being made in 2010 (they started production in 2009, and so enjoyed a run of 2 years on the assembly lines). The JD LA155 is powered by a Briggs and Stratton 2 cylinder, V twin engine. This engine is 0.656 liters (40 cubic inches) in size and produces 22 hp.
1998 - 2001 LT Series
John Deere LT155 Engine: Kohler 1-cyl gasoline
2006-2006 L155c, This series was produced only in 2006.
Briggs & Stratton gasoline, 2-cylinder air-cooled, 724 cc [44.2ci ], 25 hp
Model 445777-0168E Code 021125YC, these are the engine numbers from a 25 hp twin cylinder, B&S.
Notes on these engines from parts supplier ereplacementparts.com:
Briggs and Stratton 445777-0231-E1 Engine: The proper flywheel part number and/or the alternator magnet size will determine the alternator type or output.
This 25 hp engine has 3 different possible alternators, standard circuit, dual circuit, tri-circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is a multimeter for testing.
  1. Disconnect connector from stator.
  2. Set multimeter for AC volts.
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine ground.
  5. Prepare the lawn tractor for engine start (set parking brake, blade off, etc). Start engine and run at full throttle.
If your voltages are not in the manufacturers range, or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
B. In the picture is a two wire stator connector.
Mar 15, 2015 | Garden
Does a miller 225 charge off of the flywheel or does it have and alternator?
Flywheel. Check for AC voltage on the two outside wires of the voltage regulator with it running. At fast speed, should be 30-40 volts ac. It that is there, then check dc voltage on battery, which should be close to 14 volts dc.
Aug 25, 2014 | Welding Tools
Stanley 450 amp how long does it takebto charge
Sealed lead acid batteries are at the heart of most jumpstarters, mobile power supplies and equipment with standby capability. Such batteries arrive in a wide variety of qualities and while not particularly unreliable they do tend to fail suddenly.
Most often it is leaving them in a discharged state for more than a few weeks that hastens the death of all lead acid batteries. Even leaving one in a half charged state for as little as a month will permanently damage the battery causing it to have a reduced capacity.
The instruction leaflets supplied with such equipment invariably say recharge should take place periodically and after every use.
Usually there is an indicator light to show when charging has been successful but an overnight charge should be sufficient for a simple top-up charge and perhaps 24 hours for a periodic charge.
Use a digital voltmeter to check the battery voltage after it has been off-charge for 24 hours. A young healthy 12 volt battery will read 13.2 volts. An older but still usable example will read perhaps 12.7. 12.5 volts could be usable but the battery is definitely past its best.
A 12 volt battery that has a voltage of 12 volts is only half charged and is practically useless...
Less than 12 volts after charging and it is ready for recycling.
Jun 30, 2014 | Vehicle Parts & Accessories
What or how does the battery get its charge
Most bike have an alternator driven off the left-hand crankshaft shaft.
This turns with the engine, producing the AC charging power.
This power then runs through a voltage regulator, that both converts the the AC voltage into DC voltage, and regulates the amount of voltage flowing into the remaining electrical system.
Now, you did do the first step correctly.
DC volt meter to battery terminals to see if you get 13-14 volts DC with engine running.
Next, locate voltage regulator and unplug connector for wires coming FROM the regulator, and hook up the DC voltmeter.
With engine running, you should have 13-14 (or so) DC volts.
If not, locate and unplug wires coming from alternator to regulator, and hook up AC (note change from DC to AC) voltmeter.
With engine running, should have AC voltage (this could be 20-40 volts or more).
This will let you know where the problem is, and what needs to be replaced.
Apr 25, 2014 | 1993 kawasaki KLE 500
94 flstc. On first start-up, 35 AC stator, 14.5 v off battery. About 15 minutes into ride, lights dim to near nothing, battery always needs a charge after even a short ride. Regulator?
It sounds to me to be the battery. if you have a digital volt meter charge up your battery and first with the bike off check your voltage at the battery if this is between 13 and 14.5 volts that's a good voltage (but the cca ((cold cranking amps)) can be off) after you've gotten your voltage start the bike and test for voltage at 3000 rpm or 10% throttle if the voltage is over 16 volts or has not changed and starting to drop, check the connection to the stator and regulator located at the front of the primary chain case on the inner primary and that the long single wire from the regulator to the battery is good check 3000rpm voltage again if this did not fix the problem then you may have a problem with your voltage regulator.
Nov 14, 2010 | Harley Davidson Harley-Davidson FLSTC...
I wnat to test the alternator of my Focus ZX3 2002.I think that it isn't working properly.I need to know what is the voltage that I should find with the engine running without load, and also the voltage...
With a good fully charged battery no load should be 13.4 to 14.2 volts DC, loaded 13.4 to 14.4 volts DC. You can also check the AC volts it should not be over 0.040 volts AC a higher reading indicates a diode problem (batteries won't charge with AC voltage).
Oct 24, 2009 | 2002 Ford SVT Focus
I will go in Italy , may I use 220 V to charge my Philishave 5825 ?
If your shaver is a 110/120 V-AC razor, you MUST use a voltage converter that will allow you to charge/use your shaver while on your trip.
I would not reccommend you attempt to use it directly, since you still would need a special cord with a plug for the different outlets in Europe.
Purchase a converter/adapter kit and you can use anything with your existing power cords, with the proper adapters in the kit, without an worries.
Have a great trip and hope you find this Very Helpful. Best regards!
Sep 07, 2009 | Philips Health & Beauty
Norelco Reflex 5825 XL Electric Shaver Logo
307 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
