Question about Arcam Audio Players & Recorders
No output from Arcam Alpha A7 amp. Noise at speakers (varies with volume control so assume powerstage ok). Switching to phono input increases hiss so assume phono pre stage ok, but no output from ANY input CD/Phono/tuner/dvd. Power light on. amp has been unused for two months, other than that, no change. Any ideas gratefully received. Mike Blackwood E-mail nimrod2112@talktalk.net...are there any known faults....the unit is around 8 years old. Thanks for any clues!
5 Suggested Answers
SOURCE: Receiver shut down only when using phono preamp
Since the protection circuit trips after 4-5 songs at high volume from LPs, it may be that the infra-sonic rumble common to phonographic recordings is driving your amp stages much harder than it sounds like they are driving. You can check this with watt meters for your speaker outputs, or by filtering such extremely low frequencies on the input. If you have an equalizer--especially an old one--it may have an infrasonic filter, or just cut the very lowest frequency available on the equalizer after running your phono pre-amp into the EQ and the EQ into your VCR2 input. This setup will verify if your problem is the infrasonic rumble, but I wouldn't use it as the solution. There are very quiet infrasonic filters available that would work better for the long term. And if you just cut the lowest EQ frequency out, you'll miss some good bass.
Posted on Nov 07, 2006
  • 3600 Answers
SOURCE: Hi ,Marantz SR7200 , i am getting an audible hiss
if your hooking up a phono input lead to a digital input lead it won't work analog and digital totally different setup. when you connect the leads up it just kills the input amp so there is no noise.
Posted on Jul 10, 2009
  • 4234 Answers
SOURCE: I have bought an used Nakamichi AV1 AVR. The unit
There is a switching IC inside this unit that may be the problem, but without seeing the actual unit and signal tracing, this will be near impossible to diagnose. If you have an oscilloscope, place an input signal on one of the inputs and trace the signal to the IC. It will be a TA9263 or something similar. You should see the signal on 2,4 or 6 pins. If you see the signal only on 2, then the IC is likely to be defective.
That would be my first attempt. Also check the power supply to that IC.
Keep us posted on progress.
Dan
Posted on Aug 17, 2010
SOURCE: I have bought an used Nakamichi AV1. The unit
I also have an AV-1. I suspect you might be missing the pair of bridging pins (looks like a shiny u-shaped stubby nail) inserted between the center of the "Pre-Out" and "Main In" rca connectors on the back of the unit. There are two sets, one set of left and right each for the Front and Rear. Without these, you will get no output from the unit.
Hope this helps.
Posted on Apr 19, 2011
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
Problem with my alpha arcam 7 amp.. internal 240v 25a fuse blows right after switching it on even when all speaker and RCA cables were disconnected.i need the schematic diagram. Where should i start the...
hi,
I have the service manual of ARCAM AVR 200 with me. send me a mail on my mail id. I will send u the service manual. its a large file having a size of 4.8 mb. I can sent it through fixya.
agingopakumar@yahoo.co.in
Check the standby transformer T752 first. if its primary winding is short the this problem can occur.
ok
Jan 17, 2011 | Arcam AVR-200
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
I have bought an used Nakamichi AV1 AVR. The unit powers up and the display is fine. The problem is that there is no sound output from any source (Tuner, CD, Phono or tapes) to the speakers. I get speaker...
Dan
Aug 17, 2010 | Audio Players & Recorders
How to hook up a computer sub to a hometheater amp
http://www.arcam.co.uk/_ugc/file/avr280e_manual.pdf
If you have the whole Z5500 package you could run the Arcam's optical- or coaxial digital audio output to the corresponding input on the Logitech.
But I'd be careful about letting BOTH the Arcam and the Logictech perform Digital Sound Processing on the sound. DSP's aren't meant to be stacked. My money says the Arcam is better in the DSP department than the Logitech.
If you have just the sub, run the Sub PRE out from the Arcam to the Sub/Center input (adapt it to 3.5 mm) on the Control Center and set the switch to "6 ch direct".
Mar 06, 2010 | Jensen JW250 Main / Stereo Speaker
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
I have recently purchased a arcam alpha 10 amp to go with my arcam alpha 9 cd player and my monitor audio rs8 speakers. I am pleased with the amp and i am thinking of adding the power amp, the problem is i...
A better solution is like I have mine; use the Arcam 10 connected to the tweeters of your speakers & the power Amp connected to the woofers & link the pre out's on the 10 to the power Amp. using phono cables. The Manual can be downloaded from Arcams discontinued section of their website.
This Bi-Amp method gives a far superior sound than just using the 10 as a pre Amp.
May 04, 2009 | Audio Players & Recorders
Buzzing noise coming from speakers (bose acoustimass 5). volume up on the buzzing only happens in phono mode - no increase on other modes.Had amp since new and no probs. I think it was left on for a day...
The coupling capacitor on the phono input is possibly become leaky. Try replacing any small electrolytic capacitors you see near the input within the amp.
Mar 03, 2009 | NAD Audio Players & Recorders
Bose 151 main with amp
Does your tv have stereo outputs? if yes all you have to do is run RCA red..white jacks into tv outtput then run the other ends into the amps tape or aux or cd input and your done! If you dont have outputs on tour tv you will have to but an RF converter box (about 20.00 at wal-mart) and hook that into the tv and the cables will run out of that to the stereo!
Jan 14, 2009 | Bose 901 VI Main / Stereo Speaker
Using a tube pre amp with my CA Azur 640A?
There are many answers to your questions but Ill have a go with the basics...
Audio connections should be matched.... its called Frequency impedance,.... to get a signal along wires or cables (or Fibre) the Impedance of the cables and wires must be matched to the device they are connected to transfer the signal along the cables without distortion...
Manufacturers provide many sockets on the input side of amplifiers and preamplifiers to allow the consumer to connect various devices of different impedance.
They label these inputs like CD, or Tuner, or PHONO etc etc,
That means if you have a CD player it must be plugged into the CD input socket then the impedance will be correct and the sound will transfer along the CD cables correctly, without distortion..same with the Phono input etc...
You will find on the sound output to the speakers terminals are also labelled 4-6ohm, or 8-10ohm, these are the impedance expected for the coil ratings of the speakers them selves and its important to get the correct speakers to the correct out put terminals...
In your case all you have to do is follow these simple rules and all will be well....you say you have a squeeze box well there probably isnt a port labelled squeeze box so you need to experiment and try out each input port for the squeeze box to see what input gives you the correct sound output...Watch the Phono inputs as these are very sensative to input sound levels and must be treated very carefully as they have a double stage of sound amplification and as such you need to have the volume right down when connecting up the Phono inputs then increase the volume carefully after the cable connections are completed.
If you follow these rules then all will be well,,,,there is no difference if the Pre amp or Power amp is valve or transistor or FET or has IC outputs to the speaker the same impedance rules apply..just treat it as a box with input and output terminals and all the impedance will be taken care of for you...if you read the lables...
You need to connect you signal source to the Preamp inputs the out put from the Preamp connects to the power amp input then the power amp output goes to the speakers. this is a basic configuration for sound systems, there are other variations but are outside this discussion.
Cheers From YUBEUT
Nov 12, 2007 | Cambridge Audio Azur 640A Amplifier
59 people viewed this question
Top Arcam Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
berggei
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
