No power I have power in the outlet and the surge bar, just nothing in the computer. I have changed the power supply with two different ones and nothing. Will pulling the modem have any to do with it, some one at work suggested that but I didn't see the reasoning for it. Thanks CArol
  • urbo4 May 28, 2008
    MY monitor is black that has "no signal" across the middle of it. Thanks Carol
  • urbo4 May 29, 2008
    I had a chance to look more at the computer, the test button kicks on the fans, the only light any where is s little green one by the small round removable battery. The green light on the cd drive will flash a couple of times when you use the test button. I tried all the connection to make sure they were snug. So when I push the start button there is no noise ,the fans do not kick on and no other lights that come on in the inside. The monitor stays black and just says no signal and then nothing. Is it hopeless? Thanks Carol
    Sergeant:
  • 336 Answers
The Modem I what connects your computer to the internet. Now the next possibility is that the system board that controls all of your information is bad because of the surge. Also have you checked to see if the screen will go on?
So I recommend first checking to see if the screen will go on, then looking at a new computer because if the system board is gone your computer is almost worthless. You may still be able to save the information off of the drive. Do you have another computer?
If this doesn't work I will see what else I can do.
Hope This Helps
All The Best,
RCF
Posted on May 28, 2008
  • Ryan Frame
    Ryan Frame May 29, 2008
    No this is not hopeless because there is some power getting somewhere. Now is the data recoverable i can't say untill we solve the problem. First of all do you know anybody who is envolved in a computer business? A friend, family member, or child? If you know some body ask if they can lend you an antistatic brcelet. If not you can buy one at Best buy for about $7. Once you get an antistatic braclet I will walk you through. what you need to do.
    All The Best,
    RCF
No Display
If you are testing the motherboard by removing items plugged into it, remember to leave the CPU Heatsink on if the CPU is still in the socket otherwise the CPU will overheat in seconds or minutes and could be damaged.
If you power on the system, do the fans spin? such as the CPU heatsink fan? If no fans are spinning that are connected to the motherboard, see if the fan is spinning inside the power supply using a flashlight if needed. If not, try a known good power outlet or different plug on your surge bar or a new surge bar.
Even if the power supply fan is spinning, the power supply could be faulty. Borrow or buy one that matches the current wattage written on the side (ie: "output 350W")
Post back here with more info or if anything of this sounds like the issue you are having.
Apr 13, 2014 | Foxconn G41MXE Motherboard
My Acer Aspire M1201 won't turn on.
More than likely your power supply got fried from a power surge during that storm anyway. You'd be surprised at how worthless most surge suppressors are these days.
Jul 25, 2012 | Computers & Internet
When I try to power up my acer aspire M1201 the power button isn't responding
Check to make sure that power is reaching the power supply of your unit. If it is and still does not work, then the issue is with the supply that needs replacement. Common malady.
Jun 20, 2017 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Blew a breaker and now my computor won.t turn on
Try this, unplug the computer, hold in the power button for 30 seconds or so (this will discharge the capasitors). Now plug the computer back in and try to turn it on. If you still get nothing, try a different surge suppessor. If you still get nothing, try a different outlet. If all of this fails, you most likely have a bad power supply. You will have to open the computer, uplug the power supply from the motherboard, hard drives, DVD drives, ect. Play close attention to what plug goes were. Remove the screws holding the power supply in, and remove it from the computer. You can take this old power supply to about any computer store and find a replacement. Put in the new power supply, plug everything back in. Hopefully the computer will now boot up and run. If not you could have a bad motherboard.
I hope this helps
Jun 20, 2012 | Lenovo Computers & Internet
Today we lost power to our home. Blinked first then dimmed and then went out completely. When power was restored, I tried to turn my computer on but the switch light would not come on. No power except...
If the computer was not plugged into a surge protector the computer could be damaged. If it was plugged into into a surge protector see if there is a reset on the surge protector .Try unplugging the computer for a few minutes and the plug it in again and try it. You can try plugging the computer into a different outlet that you know is working(without the surge protector). If you look on the power supply there may be a reset inside the case.
If nothing works you may have only burnt out the power supply in the computer, you could try another power supply from another computer to see if it is just the power supply. If still not working you would have to test and trouble shoot all your parts to see what is damaged.
Thanks for using FixYa
Jun 02, 2011 | HP Pavilion A730N (PJ510AA) PC Desktop
No power coming through even red light won't come on tried different cords. That didn't work either. And we had the tv on a surge strip along with the computer and it is fine.
Try plugging the tv in a different outlet in the strip. Maybe the outlet it was plugged in during the surge got fried. I would bet thought the fuse on the power supply has blown and needs replaced. You will have to take the back cover off of the tv to find the power supply. Good Luck!!!! Hope this helps.
Mar 08, 2010 | Protron PLTV-32 Television
Won't power on
Have you checked if the outlet has power? If so That is not good because that means that the Power supply is shot, or some other component is shot. If it has no power reset the circuit breaker.
All The Best,
RCF
May 27, 2008 | Computers & Internet
Comp won't power on
Hi KlubeT,
I would suggest replacing the PSU (Power Supply Unit).
Gerry
Jan 31, 2008 | Dell OptiPlex GX270 PC Desktop
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
