Question about Seagate Barracuda 7200.7 40 GB Hard Drive
I have hard disk model (Seagate 7200.7) not detected in the BIOS, how to fix this situation? "There are many pictures of family .. Anatoly.Moscow
    Master:
  • 388 Answers
If it isnt picked up in the BIOS check the jumper on the back its a small plastic cover which will blank out two of the gold pins remove it follow the diagram on the front and set it to master.
Failing that check to see if you have power to the device and the ribbon power cord isnt damaged.
Posted on Oct 06, 2010
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
This does not sound hopeful, Have you tried the same drive in different slots on the motherboard and using different power and data cables?
Perhaps in a different machine? Is this IDE or SATA?
Apart from that you may find your only solution to be sending the disk to a data recovery expert.
Oct 06, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hi, My Seagate 500 GB Internal hard disk (Barracuda 7200.11) suddenly became non responsive (not detected by BIOS), Is there a way to make it responsive?
Please check the internal connection of your motherboard to your hard drive. Try reconnecting the cable connecting the hard drive to the motherboard. It usually fixes issues with undetected devices.
Btw, this model has a known issue, turns bad easily turns bad.
Just a suggestion, try using different models or a different brand.
Hope this helps! :D
Sep 08, 2010 | Seagate Computers & Internet
Hi, I have a seagate freeagent external disk with 500 Gb capacity, I had long time without to use my diks, then when I tried to use, It doesn't work, the power source is Ok, but my disk it It doesn't...
is the hdd getting detected....??? if it got detected then format it and try to use... if it is not detected then, let me know, i shall assist you further...
May 17, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
A6561SMS amibios v 1.7 on MSI 745 Ultra Motherboard does not detect the HD Seagate Barracuda 7200 Ide 160gb. The bios simply won't start. What could be? Are they compatible?
Dear user,
Yes HD is compatible on that motherboard but some problem in your ide of motherboard.
pl check your hard disk to another pc working or not ?
Regards,
Ravindra Shah
May 17, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
Gowthaman
Check if the jumpers on the hard disks are in the right position.
Apr 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 20GB SATA hard disk not detected
Ok, look at the hard disks circuit board, look for rust or something suspicious.
Jun 19, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Seagate pro 750, xp, xfx 630i mother board, esata
those drivers should be on seagate site, by o/s...make sure you have latest(not what came with disk, by the way)
check your computers warranty here 4 FREE
Mar 05, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Barracuda 7200.7 40 GB Hard Drive Logo
117 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
