Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
I have a AEG F3A dishwasher, the overflow pipe on the water reservoir drains a substantial amount of water on each fill, i have replaced the reservoir due to build up of scale but the leek is as great as ever, any ideas?
joe_lishman
  • 192 Answers
SOURCE: Favorit 43070 vi leak
I assume that this leak is from the flat tank on the side of the machiene. Any water leak to the bottom of the machiene puts the washer in ANTI FLOOD mode with the pump out motor activated. You can remove the flat tank by disconnecting the hoses to it and pulling it upwards. If you find a small leak just run it over with a hot soldering iron to melt closed the small leak. Also note that this tank has a small outlet pipe that deliberatly discharges water to the anti flood device (polystireen float / micro switch at the base of washer) in case of a fault (blocked pipe / leak etc).
Posted on Jan 19, 2010
SOURCE: AEG Favorit 420 Freestanding dishwasher
i have 4220 and i replaced the drain pump, fixed, located underneath to right at the front
Posted on Dec 28, 2007
joe_lishman
  • 192 Answers
SOURCE: aeg dishwasher will not drain
The washer has a drain motor in line with the outlet pipe. The motor must turn when in outlet mode. This motor has an impeler that turns at high speed to pump out water in the outlet mode. The motor could be faulty or the lelectrical push on connectors to the motor loose. One can remove the motor and coonect it directly to the mains voltage for a few seconds to check if it spins (also make sure that nothing is blocking the impeler from spinning).
Posted on Jan 20, 2010
joe_lishman
  • 192 Answers
SOURCE: My Aeg dishwasher keeps coming up witha C2 fault code
The pump out motor in line with the outlet pipe could be faulty. Remove the moto and connect it to the mains for a few seconds. The motor should spin and the impeler inside the motor should spin freely. If the motor is faulty it would not work and must be replaced
  • 10865 Answers
SOURCE: AEG Favorit 8081 displays error
Hello. When the water does not completely drain away, it usually means that there is a partial blockage in one of these areas:
1. The small drain pump located under the tub, accessable by removing the lower front panel.
2. The drain line going from the DW pump to the plumbing under the kitchen sink.
3. The garbage disposal, or the trap under the sink.
Check these out and you will find a chunk of bone, or glass or some other debris which is partially blocking the draining action. J.
Posted on Sep 04, 2010
AEG Favorit 44090i Dishwasher will not fill with water
There may be a filter after the aquastop pipe which is blocked. This is usually at the back of the inlet valve. Also, the inlet valve may no longer work.
Nov 07, 2014 | Dishwashers
Overflow reservoir
Defrost water trays are often made of flimsy plastic and likely to crack. Yours may have cracked. Another possibility is that the tray may have become mispositioned so that the water is not draining into it. The improperly closing door may have to be adjusted.
Nov 01, 2013 | AEG Dishwashers
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
New Whirlpool Dishwasher filler overflows.
New Whirlpool Dishwashers will NOT accept the same "volume" of water that was desired by the same products of 25 years ago. Therefore the old 3/8" ID copper supply is too large and will overflow the tub filler/aireator (out the air vent holes). I just installed a new dishwasher supply kit consisting of a new 3/8" OD stainless braded hose with an ID of about 1/4". This delivers less volume than that recommended (in the installation manual) and therfore does restrict the flow a bit. However, the flowrate is adequate and the new dishwasher now works perfectly with no water overflow on the floor . . .
Dec 26, 2009 | Dishwashers
Hi, I have an aeg 60870 dishwasher showing error code 30 and the pump is going all the time, even when you open the door, any suggestions of things i could try please?
Sounds like the Anti-Flood system activated (polystireen float at base of machiene coupled to a micro switch) the purpose of this system is to put the drain pump on and stops any other function on the machiene. The anti lood system activates when any amount of water appears on the bottom (caused by leaky pipe / blokked pipes / spills etc.) . Dry the water and rectify the leak. This should solve the problem.
Dec 21, 2009 | AEG 24 in. Favorit 60870M Free-standing...
AEG Favorit 60820 sensorlogic .30 code water problem
You can unclick the top part which gives better access to the lower part with the blockage. Hot water, pipe-cleaners, cable ties, bits of wire can all be employed to get the grease out.
Jun 06, 2009 | AEG 24 in. Favorit 60820W Free-standing...
Code i30 has been activated - can i solve it my self?
on several of models the water reservoir , the plastic house on the left side must be cleaned, and the big hose in the bottom from reservoir to the center is filled with fat so the water fills to slowly and it runs over in the reservoir overflow hole and down in the bottom. this , little by little fills up the aqua stop sensor system. This causes water in the bottom of your machine and water block system to trig..No not on hose but a float in the base of machine. Tilt washer on side to drain water out of base allow to dry and should cure the fault 30 prob.
remember to disconnect from the mains electricity before doing this..also clean out any hoses connected to this...as the fats accumulate it clogs the lines and water slowly starts to fill in the bottom which activates the float and thereby triggering the fault .30code..this should save you a call out charge
.Hope this helps...please rate me...the Fang
Mar 27, 2009 | AEG 23 in. Favorit 86070Vi Built-In...
LG LD12AW2 Dishwasher overflowing
On the LG LD-12AW2 model, there is a float assembly just behind the wall where the water inlet port is located inside the unit.
When that float (or the micro-switch inside it) fails, water will continue to flow in without stopping . That causes the overflowing.
Post back here if you are looking for more specific guidance.
Good Luck!
Dec 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Aug 23, 2008 | AEG 24 in. Favorit 40850 Free-standing...
Dec 26, 2007 | AEG 24 in. Favorit 40310 Free-standing...
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
102 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
