Question about Samsung TXL2791F 27" TV
Shrinking picture The top and bottom of the picture shrinks leaving a squashed image.
I stopped by a local repair shop a got some helpful advise.
Posted on Jun 08, 2008
  • Gorhob Perkins
    Gorhob Perkins Dec 24, 2013
    Thanks so much for sharing
Dvdfab registration key
Its illegal for anyone to provide serial keys for programs that have retail values set on them its Pirating
There are lots of freeware alternatives on the internet
fab dvd free
DVD Shrink and DVD Decrypter are two programs that can be used to backup DVDs.
DVD Shrink reduces dual-layer DVDs in size so that they fit on single, blank DVD media.
DVD Decrypter is used to burn that file to disc after the video has been authored in DVD Shrink.
Open DVD Shrink, click "Full Disc" on the toolbar, then insert your DVD into the disc drive.
Click "Open Disc," then select the DVD drive, and click "OK."
Click "Main Movie," then remove any "Audio" or "Subpicture" (subtitle) streams that you don't need by disabling the tick boxes.
Click the "Extras," and decide if you want to remove any.
If you do, set the "Video" drop-down menu to "Still Image."
Click "Backup" then select "Create an ISO image" from the "Select backup target" drop-down menu.
Select "Browse" and then choose a temporary location for your ISO image to be stored.
Click "Quality Settings," and make sure "Compress video with high..." is selected.
Click "OK." Close DVD Shrink when the ISO image has been created.
Open DVD Decrypter, click "Mode," then "ISO," then "Write W."
Click the folder icon and locate the ISO created with DVD Shrink. Insert a blank DVD, and then click the burn button in the bottom-left.
You will now have backed up your home movie DVD.
Oct 13, 2013 | Computers & Internet
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
Picture gets smaller from left to right (tunnels)
if the image shrinks and not just the size of the image, reset the settings to factory default through the menu. if it is just the screen and it crops the image as it shrinks, it may be that the light tunnel has collapsed and needs replacing.
Aug 28, 2009 | Mitsubishi HD4000 Multimedia Projector
Picture size
You will need a photo-editing software in order to shrink the image file. If you have a more high-end photo editing program such as photoshop, you can simply go to image > image size, and then input a lower resolution.
Otherwise, you can shrink it using microsoft paint. Open the image file in paint, then go to the image menu, and select the resize/skew item. Keep in mind that your phone only has a 400x240 resolution, so any photos larger than that will not show any better on your phone. If you took this photo from a handheld camera that is 4 or fewer years old, you'll probably want to shrink the photo to 20-30% of its size. Then, just save the photo as a new file, and make sure you save it as a JPEG in the drop-down save menu, or your phone may not recognize the format.
Jun 23, 2009 | LG Vu CU920 Cellular Phone
Latest version. DVD Shrink. Nero8 (Todays downloads) On two Laptops. Didn't have this problem with PC's.. Shrink working ok. Nero 8 Burning dvd's. Lap tops read /Play fine. Home dvd players to home TV...
try not to do anything or open other program while its dvd shrinking or burning....bcoz dvd shrinking and burning occupies lot of memory cache and cpu usage.
Sep 15, 2008 | Computers & Internet
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Usually, when a picture collapses some but not all the way, it indicates that an electrolytic capacitor has gone bad in the verrtical circuit. If the top of the picture shrinks, suspect the pump-up capacitor, but if the bottom shrinks then the coupling cap is probably going bad. This is quite an easy thing to correct, so have a qualified tech service the set.
Sep 01, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Samsung TXL2791F 27" TV Logo
268 people viewed this question
Jerry Greenberg
Jerry Greenberg
