Question about Dell Inspiron 1501 Notebook
Wireless router I just purchased a Dell inspiron 1526 with a Built-in Dell 1395 wireless networking mini-card (802.11b/g); standard Wi-Fi Catcher to quickly locate wireless hotspots; Do I also need a router to connect to my modem or how does it work?
    Genius:
  • 3,587 Answers
Well..the wireless will pick up any signal..if you want one inside your place, you'll need a signal converter(wireless router) and a cable or dsl(phone com) internet service providor.
Posted on May 28, 2008
DELL Latitude E6510, wifi button was OFF, now it is not working.Wifi is showing red cross. Please help how t0 turn it ON? I think it is Hardware issue. Can I fix it through Windows? Windows 7
Information Technologies
Share
Enable / Disable an Enterprise Laptop's Wi-Fi
Wi-Fi, short for Wireless Fidelity, is networking technology that allows you to connect to the Internet. If you have a wireless-enabled Latitude computer you can connect to the Internet when in range of an access point called a hotspot.
When not in use your Latitude's wireless card should be disabled. By disabling Wi-Fi, you will receive two benefits:
Start-up times will be much faster.
If the wireless card is ON and you are out of the office (not connected to your normal, wired connection), the laptop will try to use the Wi-Fi network during the login process to run the various start-up scripts, etc. It will eventually time-out (fail). By having the wireless card turned OFF, the start-up process will be much faster.
Computer will not continually search for a wireless network (and waste battery life).
If you are in the office (connected to your normal, wired connection) or in a location where there is no wireless hotspot, you don't need to have the computer waste processing power by looking and looking for a wireless hotspot. By disabling Wi-Fi, you will gain a little more power for your other tasks. In addition, you will maximize your battery operating time by disabling wireless activity.
NOTE: After your Latitude has started up completely, you can ENABLE the wireless card and connect to a wireless hotspot. For example, a wireless router at your home or at a local coffee shop. If you have connected to this hotspot previously, the wireless card should connect automatically for you.
NOTE: Once you have the wireless card enabled, before you shut down the computer, you should again DISABLE the card. The computer will then be ready for the next time you turn it on with wireless turned off.
Enable / Disable with Hardware Switch
The more recent Latitude models have a wireless switch to enable or disable wireless network devices and the
Wi-Fi Catcher Network Locator.
Dell Latitude E6420 and E6520 Series
These laptops have a small switch on the RIGHT side of the keyboard. The switch is toward the front of the laptop. The Wi-Fi Catcher™ icon will is above the keyboard. You will see a lit radio tower if the wireless switch is enable
Oct 17, 2016 | Dell Latitude E6510 Notebook
Bluetooth peripheral device driver
Sai Ch Krishna,
Depending on the system. The bluetooth would have to have been purchased at point of sale. The wireless and the bluetooth are turned on by a wireless switch on the side of the computer. If needed you can reinstall the drivers. Also, make sure bluetooth is turned on in the bios. Below is more information.
Wireless Switch
Wireless Technology The Latitude D630, D631, and D630c system ships with a wireless feature called the wireless switch. It is located on the left side of the system next to the IEEE 1394 connector. When used in combination with the Dell 38482; Quickset utilities, this switch enables or disables the wireless LAN, wireless WAN, and Bluetooth cards in the system or searches for all wireless networks in range.
To scan for a Wi-Fi wireless LAN, slide and hold the switch in the momentary position for a few seconds. The Wi-Fi Catcher network locator works whether the computer is turned on or off, in Hibernate mode, or in Standby mode, as long as the switch is configured through QuickSet or the BIOS to control Wi-Fi network connections.
Because the Wi-Fi Catcher network locator is disabled and not configured for use when the computer is shipped, it must be enabled and configured through the Dell QuickSet utilities to control Wi-Fi network connections.
Wireless Switch LED Settings
The LED on the wireless switch works even if the system is off. A user can activate the switch and have it scan for networks without going through a complete boot process. The switch can be set to detect for only certain wireless signals, such as WLAN only, WWAN only, Bluetooth only, or any combination of these. This is set in the BIOS under the Wireless section.
The LED indicates the presence of a network as follows:
  • Flashing green - The system is searching for a signal.
  • Green - The system has detected a wireless signal and has good strength.
  • Yellow - The system has detected a wireless signal, but it is moderate to weak in strength.
  • Red - The system failed to detect a wireless signal, or the wireless signal is extremely weak.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 27, 2013 | Dell Computers & Internet
Dear sir, i can not see the wireless icon on my laptop
do you have the drivers for your wifi card installed properly. if not then go to manufactures website and download driver software for your wifi unit, are you using xp or vista? find device manager and see interfering hardware.
Dec 02, 2010 | Dell Vostro 1500 Notebook
I have a inspiron 1545 i want to ask if it have a blutooth
Wi-Fi Options:
Dell Wireless 1397 802.11g Mini-Card
Dell Wireless 1515 Wireless-N Mini-Card
Intel® Next-Gen Wireless-N Mini-card
Bluetooth Options:
Dell Wireless 365 Bluetooth® Internal (2.0) mini-card
You'll need the mini-card option.
Oct 31, 2010 | Dell Inspiron 1545 Notebook
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
Getting wireless to work on my Dell Inspiron 1000
find switch on laptop it is wi fi network adapter switch on laptop turn on it.
Then also check your wi fi drivers are installed.
if driver are not install for wi fi downlaod from here in netwrok
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_CEL_1000&os=WW1&osl=en&catid=&impid=
then install wi fi then check.
Jul 14, 2009 | Dell Inspiron 1000 Notebook
Unable to connect to the Internet
Check to see if your wireless card is displayed under “Network Adaptors” in “Device Manager”. You can access the "Device Manager" by going to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column. If it is detected and there are no alerts or errors, try uninstalling the wi-fi card, reboot the laptop and reinstall the drivers.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 04, 2008 | Dell Inspiron 5100 Wireless Mini-pci...
Wireless Router
Yes you can, you just have to connect to the network wherever you are and provide the password for that location if it has security.
Jul 28, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Wireless networking mini-card
Its already in the machine, based on your description.
May 15, 2008 | Computers & Internet
Inspiron 1526 running windows XP Pro
ALL POSSIBLE XP DRIVERS for Dell Inspiron 1526 are bundeled together and is available for download at the following URL
http://rapidshare.com/files/290508217/Inspiron_1526_XP_Drivers.zip
ALL XP DRIVERS FOR INSPIRON 1526
Regards
-SHrimant Patel-
Apr 14, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 1501 Notebook Logo
175 people viewed this question
Alun Cox
