Question about LG 47LC7DF 47 in. LCD HDTV
Resolution my set says 1080P capabilities but setting s only go to 480 and 1080I What is I and P and why cant I get 1080P
  • Anonymous Jan 03, 2009
    how do i change the resolution to 1080p ...i cant access the picture/screen option of the menu .it.is grayed out
  • wendytwo Jan 26, 2009
    hi, i find that the small print on the stations or my satilite guide is slightly blurred on the LG 47" LCD, is this normal? someone told me to go and put it to sharp, but the only sharp i found was the sharpness in the color setups, it didn't help.
What cables are you using componet cables are only 1080i compatible the hdmi is 1080p that is 1 reason it could be
Posted on Jul 11, 2008
  • 65 Answers
Got to go through your settings and set it to 1080 p if it did not come pre set to that setting..it should have....
Posted on May 28, 2008
How do i set the pixel to 1080 on my new 40h3e tv?
First you have to make sure your set is capable of 1080P. Next, you have to make sure your source can generate 1080P. Then you need to check your cables. If you are trying to run 1080P on a coax not designed for delivering those resolutions then you need to switch to an HDMI, RGB, DVI or 15HD connection. After all of these checks 1080P should come up in the menu as an options.
Dec 25, 2014 | Televison & Video
Need to set it 1080p
It may not be possible unless it is capable of that resolution. A 720 p only TV cannot increase to 1080p
Jan 04, 2014 | Vizio L32 32 in. LCD HDTV
How do I get my tv on 1080ip
no offense but it does not look like it is capable of 1080p or 1080i. if it is, simple go to the menu and in setting find the video settings and the resolution setting if any, this is where you would make that change if possible- im sure you know you need an hdmi cable for full hd- some tv set will auto set their resolution to the best that the connected device will output, the only place the option will be is in the tv menu look for it there, but your hosting device must put out at 1080p or 1080i for the tv to render that resolution unless its up-converting which most sets aren't...... good luck questions ask
Mar 28, 2013 | Televison & Video
I connected the cable box to my LG tv with new HDMI cables and the picture is noticeable smaller than the size of the screen. Before, I had the cable from the wall connected directly to the tv and the...
Your cable box and TV are set to different resolutions. Check the setup on both and make sure everything is the same (ie 720p to 720p or 1080p to 1080p) Make sure your cable box can give you 1080p (Nice set, BTW!!). HDMI is supposed to automatically take care of the settings, but it does not hurt to double-check.
Depending on the manufacturer of the cable box, there may be screen setting for "letterbox" which should be selected.
Some TV channels, when redirected through a cable box, simply will not display full resolution (1080p) programming. Your cable TV provider can tell you which channels are displayed in high resolution.
Finally, make sure your cable provider gave you the correct box. Older boxes are not capable of providing 1080p resolution, and since you own a 1080p set, you deserve nothing less!
Jan 30, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
Tv is showing 480p and we want it at 1080p on our new Toshiba 40XV648 40-Inch 1080p 120Hz HD LCD TV Cinema Series.
After searching the owners manual I find that there is nothing mentioned about the screen resolution i.e. 480p to 1080p.
This set is capable of your desired resolution and as far as I can tell it auto selects because it senses the input video and decides which is the best setting for that source.
It's important to understand that you need 1080p video to use it at it's full capabilities. It won't give you a 1080p resolution from a VCR or a standard DVD player. You need a DVD player that is capable of producing a 1080p encoded video. Some satellite receivers are capable of that but you need to make sure you know what resolution that you are sending to the television.
Local TV stations won't usually broadcast HD at 1080p. Your best bet is to use a DVD player that is capable of that high resolution for your best picture.
Please note that what it says in the owners manual about "Resolution" has nothing to do with the 480p, 720p or 1080p signals, your set selects that automatically it will start by selecting the 1080p then goes to 720p then 420p it's dependent on the video you send to the set.
Please note the "resolution" function is actually like a "sharpness" control.
Your video input (tuner, VCR, DVD, games and etc.) is likely your problem.
Mar 30, 2010 | Televison & Video
My new Blu-Ray player will not send out an HDMI signal, except when I turn it on. It shows the Blu-Ray sign, then stops sending out any signal. is this a common problem?
This is not a common problem.
It sounds like you are receiving signal from the DVD player, but are having a resolution issue. After the splash screen is when the resolutions setting can affect your output. What this sounds like is the DVD player is set to 1080P and the TV is only capable of 720P or 1080i. If there is a resolution mis-match, connect a composite cable to the TV and set the resolution of the DVD player to AUTO, then check to see if you have an image from the HDMI connection.
If your TV is capable of 1080P and if this solution does not fix the problem, and all other outputs from the player perform the same, the unit is faulty and should be returned if still under warranty.
Hope this helps!
Jan 11, 2010 | Insignia NS-BRDVD Blu-Ray Player
My tv is Samsung TOCa750. How do I set it up for 1080p and 120Hz?
Resolution such as 1080p,1080i etc. set by your source of the signal, for example, if your cable box set to 720p that is what you going to get from the TV. Cable box is ont capable of resolution more then 1080i because there is nobody broadcast in 1080p yet. Only way you can get 1080p is BD player, upconverting dvd player or media player. 120 Hz is just a frame rate convertor - takes stendard 60Hz and doubles number of frames to 120. So, you will see 120 frames per second instead of 60.
Oct 29, 2009 | Televison & Video
Everything is connected, i can hear it, but cant see it
The previous answer is partly right. Are you both using HDMI, or are you changing connection method. If you change method, you must reset the graphics settings, which can be a bit tricky without a screen. Turn off your PS3, then Press AND HOLD on the Power Symbol for some time, or until you hear the beeps, and the flight flashes green, then, it should work.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
No Display
If your resolution on your TV isn't capable of 1080p it will not show anything on screen. You should set the Blu-ray player to max resolution of your tv.
Hope this helps.
May 27, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Invalid format message on my 42 lg flat screen
Check the resolution capabilities in the manual. It sounds like you either have your DVD set to 1080P which some TV's don't do progressive scan. Set the DVD or whatever to lower resolution like 1080i or 720i. It depends how you hook it up though because if you have it connected HDMI or DVI you can usually do this but with analog you usually can't change the setting.
Aug 18, 2008 | Televison & Video
LG 47LC7DF 47 in. LCD HDTV Logo
98 people viewed this question
Computer Repairing
Computer Repairing
