Question about Dell 1320c Laser Printer
My dell 1320c printer started blinking green on the front panel and will not print. I have rebooted, shut down, pulled out tray, opened side panel, opened front. I do not have a paper jam. This happened mid way thru printing a batch of papers. This is a brand new printer.
SOURCE: photo tray doesn't work
hp f 4235
Posted on Dec 25, 2008
SOURCE: Dell 1320c printing error "no paper detected"
I had the same problem. I removed the paper tray, turned the printer on its side and manually moved all the working parts on the bottom of the printer - rollers and switches..
When I reinserted the paper tray, everything worked fine.
PS. I ordered and returned a new paper tray from Dell, that was not the problem.
Posted on Apr 06, 2009
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
  • 108 Answers
SOURCE: Paper jam message
check the paper tray to make sure paper goes up. Also check to see if there are any obstructions in the paper path.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Posted on Jul 31, 2009
MUKHTAR
  • 2022 Answers
SOURCE: dell colour laser 1320c printer prints one page
in your printer properties set the paper size according to your printer paper size.
Posted on Nov 27, 2009
Cannot print to Dell 1320c printer
check printers on computer select your printer as default
May 02, 2016 | Dell 1320c Laser Printer
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Sep 19, 2014 | Brother HL Office Equipment & Supplies
1320c Dell Printer has blinking orange error light. How to fix this? Have looked for jammed paper, checked ink cartridges, rebooted, etc....Will not print.
If the light is flashing, it might not be the PHD, but you might be having a problem with the PDL emulation. Just go the control panel, right click the Dell printer. Select printer properties, not properties. Go to the advanced tab and check print directly to printer instead of spool print documents. This should work.
Apr 13, 2010 | Dell 1320c Laser Printer
Wrong size paper error Dell 1320C
if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 20, 2009 | Dell 1320c Laser Printer
Dell colour laser 1320c printer prints one page
Nov 27, 2009 | Dell 1320c Laser Printer
Says door open, but is shut
Sounds like a bad sensor. Look for paper obstructing the small sensor just inside the manual feed tray, check for a lot of dust anywhere on the under-carriage above the trays that could be causing the issue. But if the sensor is just bad, you'll need to probably take it to a certified technician.
Aug 24, 2009 | Dell 1320c Laser Printer
Jan 09, 2009 | Dell 1320c Laser Printer
Paper jam.
I simply removed the tray for better access to the jammed paper.(I am a novice)
Dell 1320c Laser Printer Logo
498 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
