Question about Singer 7462 Mechanical Sewing Machine
How do you change the belt on a Singer 7462?
The belt has either broken or come off because you can press on the foot control and hear the motor running, but the Needle or Presser foot does not move. The Bobbin winder shaft is the only thing visible that moves. The only way to make the Needle move is to use the Hand Wheel. What is the easiest way to open it up to check if the belt is broken? Do you know what the part number is for the Belt?
Thank you,
Glenn
    Problem Solver:
  • 26 Answers
By removing the top cover, or the turning wheel cover,
you will be able to see the belt.
If the belt is not broken, then try to adjust the belt tension,
by adjusting either the height of the motor, or the tension wheel.
Posted on May 28, 2008
Where is the light bulb on singer model 7462?
Here is the parts diagram.
Page 4 the 3rd leftmost item 87502 is the LED light circuit board.
http://parts.singerco.com/CPpartCharts/7_7999/7462.pdf
I would start with page 11 diagram to take off the arm/head end cover because that's most likely where it is, just above the needle and foot, slightly off to the side.
Jul 26, 2016 | Singer Sewing Machines
Bobbin case for 7462 singer how do u put in the machine
Open Up The Door Below The sewing Foot. Lift Lever And Then Pull Out the Bobbing Case Replace Bobbing And Put Back Together
Feb 02, 2014 | Singer 7462 Mechanical Sewing Machine
All of a sudden my Singer Inspiration 4206 stopped working. When I press the foot peddle it only makes a swinging sound like when you're only swing a motorcycle but not driving it. If I turn the hand weel...
If the swinging sound is from the motor, right side just below your hand wheel, possibility your motor belting is loose or broken. If you don't have mechanical skill / experience, suggest to get your local technician to fix it.
Nov 10, 2013 | Singer Inspiration 4206
I have a Singer 7462 and when I try to load a bobin, the machine makes a nasty grinding noise and the needle slowly moves up and down and ultimately all of the lights on the stitch selection panel flash...
Ok, this is pretty common. Disengage the machine (as if you were winding a bobbin) run the machine at high speed for 5 minutes.
The motor is dirty and this will clean it out. You should hear the pitch of the motor change as the minutes go by.
Aug 24, 2010 | Singer 7462 Mechanical Sewing Machine
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
I lost my power cord for the singer 7462 part # 77234
Best to contact your nearest Singer dealer, or try calling a nearby service dealership for any brand, as we quite often have used foot controls or even access to replacements, even the ability to make them up on occasion.
Apr 03, 2008 | Singer 7462 Mechanical Sewing Machine
How do you remove cover from Singer 7462
I found that by turning the machine over on its back I could lift the front cover from the bottom and get it over the tension knob.
Mar 29, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
249 people viewed this question
Top Singer Sewing Machines Experts
mystery_soul
Level 1 Expert
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
