Hello ! My Whirlpool AWE 5550 top load 5.5 kg model washing machine. It was suddenly stopped after few minutes running. Now, my washing machine is not switch on . Please give me solution.
vest6
  • 196 Answers
SOURCE: washing machine stops at rinse cycle
Sounds like a faulty lid switch. The switch will not allow this unit to drain/spin if the switch is faulty.
Posted on Jan 12, 2008
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
  • 47 Answers
SOURCE: Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
Posted on May 14, 2009
SOURCE: I have a Whirlpool coin operated top load washing
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Posted on Sep 27, 2009
SOURCE: GIVING ELECTRIC SPARK INSIDE THE WASHING MACHINE DURING RUNNING
washing machine motor sparks during spinning
Posted on Oct 03, 2009
Whirpool awe 7728/1
It's Sensors may have stopped working. Call Customer Service Engineer.
Mar 29, 2014 | Whirlpool Washing Machines
I have a front loader model 850 (4.5 kg.).I select programme #5, load the machine and initiate wash cycle. Water is introduced for a few minutes but programme does not proceed. Machine remains...
I just love the way you write. I can tell you are not from the U.S. lol. more than likely your timer/controller is faulty . The little motor than turns it inside is broken.
Oct 29, 2010 | Whirlpool Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
Hello. I have a two years old Whirlpool washing
Unless you look underneath it will not be easy to confirm but please check the following.:
1. check if the motor has failed, the housing has come off.
2. checckif the belts have failed and brought it off the pulley.
3. check if the main spindle , pulley has come off from the main shaft.
4.check if theere is any foreign material struck in between the tub and outer cover. Checking with manually must confirm.
5. check aftert he above had been looked into to see if any other issues are visible or audible.
Hope these tips helps.
Aug 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Code F 40
Hello homefolks
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Your washer starts to wash and code come up it stop then starts runs for a
few minutes then code comes up again and does this over and over
can't finish a load. Model # 2709
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works! Waiting for your reply!
Please remember to leave a rating when you are done!
thank You huuum
Sep 25, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool washing machine ,
Hello bill197
Welcome,
You said, when you start the machine the program will run round and round it well not stop
but the machine will not do a wash.
How old is the washer
And the model is GHW9150P..??
Try this,
Lets try this,
This can reset the system!
Unplug the appliance and wait a 5 minutes then restart it.
Please remember to leave a appropriate rating when you are done!
Thank You
Huum
Sep 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
AWE 2516 The lock status is on. Not able to wash
what is the brand and model number of this unit if you hace an owners manuel look up control lock feature
Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My machine runs for 5 seconds and stops for 15 minutes
The spinning motor are not turning / try it manually /if okey / the timer contactor is malfunction.
Jan 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
