Question about Nokia 6720 Classic Cell Phone
The key bottom not working and number 1,4,7 - Nokia 6720 Classic Cell Phone
  • 3 Answers
REMOVE UR KEYPAD AND BYE NEW KEYPAD
Posted on Oct 06, 2010
    New Friend:
Key 1 4 7 * proplam
Posted on Nov 11, 2012
  • thona_lonely
    thona_lonely Nov 11, 2012
    nokia 2700c not bottong key 1 4 7 *
I lost my product key so my laptop(toshiba) is not working
Try to check for a part number on the sticker at the bottom of you laptop. The part number's format would be X12-12345. Contact Microsoft Support at 1-800-936-5700 and have them generate one for you. They can generate a product key based on the part number. Note that you might be charged 10$ for this.
Otherwise, try accessing Safe Mode by tapping F8 repeatedly while booting and ran a utiliyt called "Magical Jellybean"
http://www.magicaljellybean.com/keyfinder/
It will allow you to retrieve your product key and use it.
Mar 07, 2011 | Computers & Internet
Where is the number lock on this keyboard?
As with most laptops there is no number lock key. you dont have the number pad like most desktop keyboards. you have a (fn) key this works for all the keys that have a square around them it may be blue/white/purple, and is located on the bottom left should be the second key on the bottom left row right next to the ctrl key. but once again there is no number lock key.
Feb 21, 2011 | Dell Inspiron 1545 Notebook
I need to know how to get to Table Set on the TI-85 because I need to find the x intercepts on the graph, but I can't find it. How do I get to it?
try this one:
(first). Set up a function in the TI85. how?
Step 1. Press the [Y=] key to open the function editor.
Step 2. Type in the function you want in the Y1= line.
Step 3. Press [2nd] [QUIT].
(second). Create a table of numbers using the Y1 function.
Step 1. Press [2nd] [TBLSET] to open the table setup menu. On the line "Indpnt", highlight "Ask" and press enter. On the line "Depend", highlight "Auto" and press enter.
Step 2. Now press [2nd] [TABLE] , type in a value for "X", and press [ENTER].
Step 3. Continue typing more values for X to fill up the table.
(third). How can I see more decimal places for the numbers in a table?
Answer:
Step 1. Use the arrow keys to move the highlight over the number you are interested in seeing to more decimal places.
Step 2. Read the number at the bottom of the screen. You should be able to see anywhere from 9 to 14 significant figures for your number.
(fourth). Delete the numbers in a table by:
(The following procedure will work when the table setup has been set to ask for the values of the independent variable.)
Step 1. In the table screen, check the bottom of the screen to make sure that the cursor is not blinking at the bottom of the screen. If the cursor is blinking, press the [ENTER] key to stop the cursor from blinking.
Step 2. Use the arrow keys to move the highlight to the first number in the first column of the table (the "X" column).
Step 3. Press and hold the [DEL] key to delete the numbers in the first column of the table. The entire table should become clear with this procedure.
Thanks! I wish it can help you..
Feb 16, 2011 | Texas Instruments TI-85 Calculator
My thermostat is not working. It might be locked. It's blinking with all of the information it holds flashing on the screen. The part number is: tstatccnhp01-c My heat is no longer working. Can you...
Instructions
  1. 1 Unlock a partially locked screen by pressing any locked key, which will bring up the "Screen Locked" message. Next press an unlocked key, which will likely be the temperature up and down arrow keys. This will unlock the screen.
  2. 2 Press the "System" key from the home screen. Five blank touch keys, flanked by the "Done" and "Cancel" keys, will appear. Hold down the middle key for about five seconds. The Advanced Settings menu should come up.
  3. 3 Change the User Setup Number, found in the bottom left of the screen, by pressing the middle arrow keys up or down. Set the number to "0670," the universal unlock code.
  4. 4 Turn to the arrow keys on the right side of the screen. Press the keys up or down to change your options. Selecting the number "0" will unlock the screen, while choosing "1" will partially lock it. You can fully lock your screen again by selecting.
Read more: How to Unlock the Screen on a Honeywell Thermostat ' eHow.com http://www.ehow.com/how_7667347_unlock-screen-honeywell-thermostat.html#ixzz19ktDWSq8
Jan 01, 2011 | Heating & Cooling
If i press function key then all the keys work good otherwise keys just type numbers.
You have the number lock in the ON position.
The function key is usually of a different color (usually blue or green) look for the key with has the words Num Lock of the same color as the function key usually its the same key as the ScrLK (scroll lock)key. While holding the function key press the number lock key then release all keys and try to type.
Most computers have a light that indicates when the number lock is on just like the Caps lock on a desktop its on the keyboard, on a laptop the lights are either above the keys or on the bottom of the screen, look at the lights and you should see a number 1. if its on then follow the steps above until it turns off.
Good luck
Oct 10, 2010 | Computers & Internet
How do you enter negative numbers on a TI-30X iis calculater?
On the bottom of the calculator near the zero and the enter key it has the symbol (-) that is a negative number symbol
Nov 22, 2008 | Texas Instruments TI-30XA Calculator
Sony ericsson w910i keys
mine has done that with the ok, L-select, R-select, end call, start call, deleate, and numbers 1, 4, 7
Aug 26, 2008 | Sony Ericsson W910i Cellular Phone
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Keying in street addresses
To find streets that are numerical, not names, enter the address normally to start. Enter the State, City, and House Number. When it asks you to enter the street, look at the bottom of the keyboard. You will see a key marked 123. Press this key, and numbers will show up instead of letters. Type in just the numbers (25 for 25th Avenue, etc.) and hit Done. The street should show as (25th (St., Ave., etc)). Press the correct entry.
Dec 04, 2007 | Garmin StreetPilot c550 GPS Receiver
Nokia 6720 Classic Cell Phone Logo
111 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
