Question about E-Machines Emachine C2684 Power Supply **FREE ** Power Supply
Remove cabinet to get to hard drive
I want to change the hard drive, how do I remove the cabinet, is it riveted to frame?
  • glade May 28, 2008
    It worked, there was a retaining clip in addition to the 2 thumbscrews which was difficult to manuever, but with a pliers I got it to release OK, and went back together OK.
    Thanks for you help
  • 77 Answers
There should be 2 thumbscrews on the back part of the case where the side panel would slide back and off. On some other cases, there is a button on the bottom you need to press to have the side panel swing open.
Posted on May 28, 2008
How to replace a quarter window on 95' Ford thunderbird LX. Passenger side quarter window and what tools will I be using.
Remove the door panel, remove the window trim, remove the window regulator, Remove the window frame(push down ,then pull out from the top), Remove the broken glass from the seal, install window. Put back together in reverse order. You will need a Phillips screw driver, a drill and 1/4 bit, a 10 MM wrench or socket, 1/4 rivets X 1/2 inch long and rivet gun that handles up to 1/4 inch rivets.
May 03, 2015 | 1995 Ford Thunderbird
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Aug 10, 2011 | Fisher and Paykel 24 in. DS603H SS...
I need instructions how to remove hard drive
Use the camera function on your cell phone; take picture of all cable connections
disconnect all cables to your computer
disconnect thumbscrews/screws holding computer cabinet shell at the back of computer
slide the cabinet shell forward exposing chasis frame. Lay computer on its side
important: Ground your body to the chassis frame (prevents static discharge damage)
Locate harddrive; with a magic marker ink one side to each of the two plugs and their sockets that are connected to the hard drive.(take picture maybe easer)
This is called making withness marks; it gives you a reference and orientation when you put things back together; the smaller plug is the power plug; the larger plug is for data.
Remove screws that secure harddrive to frame; Ground new harddrive to chasis; replace harddrive.
Nov 24, 2010 | HP Pavilion m7640n PC Desktop
Cv shaft replace
This is usually the same on all front wheel drive cars..
Remove the wheel
Remove the brake caliper
Remove the brake rotor
Remove the spindle nut
Remove the wheel bearing assembly (usually 3 bolts)
-The next step may be optional, depends on the car-
Unbolt the lower ball joint (under the A-frame, some are riveted, if so, drill them out and chisel or just chisel them off with a metal chisel, sometimes you can cut the rivet heads off with a sawzall then pry it apart from the a-frame)
Pull the wheel bearing assembly from the spindle of the CV half shaft.
(Sometimes you need a wheel puller)
Once its loose, all you have to do it yank it out, and push the new one in. Make sure the new one pops in and is seated firmly.
Reverse steps for re-assembly. If you took the ball joint loose and it was riveted, use hardened steel bolts and nuts with lock washers to replace it, or buy a new ball joint, they aren't that expensive and it will come with bolts.
Good luck
May 09, 2010 | 1992 Nissan Stanza
How to replace the windows in an Audi a4 2002 years
front or rear.front doors have to be stripped to frame.frame must be removed from door,lay it somewhere clean & soft.drill out rivets holding regulator to frame & remove from glass,refit new one using new rivets.nb when removing frame/glass from door,you will see wedge shaped spacers,make sure they go back o the same way.
Jan 12, 2010 | 2002 Audi A4
2001 ford explorer sport
support vehicle under A frame remove wheel. loosen nut on top of ball joint.seperate spindle assembly from ball joint w/ball joint seperating tool AKA pickle fork.remove nut.ball joint is riveted to lower A frame-chisel off or drill out rivets.install new ball joint w/nuts &bolts supplied with it
Sep 22, 2009 | 2001 Ford Explorer Sport
Need to replace a broken window on rear passenger 1999 jeep chero
This information can help you to fix it:
- Section-08s-Power-Window-Systems-Ewj8s
- Section-23-Body-ewj23S (Rear Door, page 41 and next).
Good luck (remember rated this help).
Sep 09, 2009 | 1999 Jeep Grand Cherokee
R & R power window drivers side Need to replace power window regulator on 96 Lincoln Town Car drivers side. Need instructions on how to do this.
I am in the process of doing this now to my 96 Lincoln Towncar. Today I removed the door panel. Hidden scews that attach the door panel are at end end of the door pull strap. The plastic end pieces are removable and each have a screw underneath securing the top of the door panel.
Hidden behind the water shield material at the top of the door are two nuts that retain the top connection of the window lift. I am going to razor cut a straight line through the water shield material to insert a socket to remove the two nuts and then put duck tape over the razor cuts rather that pull the water shield material from the door frame.
Started drilling on the left rivet to detach window from the regulator and quit for the evening.
Have three rivets to drill to detach the pwoer window motor from the door frame.
Two more rivets at the bottom of the door to drill out to detach the lower window regulator from the door frame.
Do not know how I am going to remove the right rivet of the bracket that hold the window yet. Looks like a would need a long drill bit to reach through the door frame to make contact with the rivet.
The replacement rivets that came with my window regulator are to big for my rivet tool. Could end up using nuts and bolts. Sure would make it easier for the next window regulator replacement.
Hope I have some good luck using the drill tomorrow. kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkddddddddddddddddddddddddddddddddd
Mar 06, 2009 | 1996 Lincoln Town Car
How do I remove the cabinet on a Kenmore Model 11022882101 top loading washer?
You need to remove 2 screws in console. They might be in back, on ends or in front ends. If you can't see any, they are under the console end caps. To remove end caps, pry off by pulling caps towards outside from center part of cap. Pry toward you and towards outside. Then remove 2 screws and flip console up and back. Unplug connector to washer cabinet. Remove 2 gold colored clips by inserting straight screwdriver in them and prying back. Make not of their position first. Now tilt cabinet toward you and slide forward and off base.
To replace, tilt cabinet and slide under frame in front. Now lower cabinet on to frame, making sure cabinet is on frame on sides. Re-install clips by placing them in position and pushing down with palm of hand. Plug in connector, lower console and install screws.
Nov 21, 2007 | Washing Machines
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Computers & Internet Logo
83 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
