posted by Anchises on May 28, 2008
The blue display is failing.
Generally it goes off 10 seconds after turn on and remains off, until it has been turned off for a period.
Is it possible to replace the LED/Bulb ?
or is it possible a logic driver problem ?
Comment by Anchises, posted on May 28, 2008
Thanks . I'll try that :)
A.
A.
Best Solution
Most likely there is a bad connection either at the display itself or in the power supply. If you are comfortable working with this equipment and can solder, try resoldering the pins for the display itself first.
Keep us posted.
Dan
Keep us posted.
Dan
Rating Locked! (?) Anchises has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Philips MC235 Shelf System
Email this problem
Email this problem
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
Cant get the Unit to respond to...
Hi In moving house i lost the... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
