Question about Miele Washing Machines
W 3821 Miele Washingmascine Softtronic Error code F 225, F 228, F 231 Intake of water is ok, but cannot serve the water later when washing and stops with technical alarm or when we try to get out the water
2 Suggested Answers
  • 3 Answers
SOURCE: miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Posted on Aug 11, 2009
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
How to reset miele wasmachine softtronic W3624
it may have a suds lock on it due to too much soap you may need to flush it
Jan 13, 2014 | Miele Washing Machines
I have a Miele Incognito G843 SCVi Plus. In a wash mode, the cycle stops in the first serveral minutes before soap is dispensed and the Drain/Intake light flashes. In Rinse and Hold mode the unit makes...
Hi
First check if the drain hose is not clogged and try to clean it as it can be that the hose is clogged and the water is not draining properly. After that check if the drain pump filter is fine and not clogged, try to clean that as well. After this check the metal filter, impeller cover and the air gap unit. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Dec 30, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
What is error code 3 on the Miele dischwasher?
I dont think that the error code is 3 it must be 13.
If it is 13 then, this error is a flow meter error. You will need to pull the dishwasher out and it on the side there is no way to reset it it will need to be replaced fairly common issue.
Remedy is to open the stop clock fully - clean the water inlet filter - th e water pressure at intake is lower than 30kPa (0.3 bar)
Aug 29, 2010 | Miele 24 in. Touchtronic G694SC Built-In...
My miele wont wash it starts up then stops an wont drain out then the water intake light comes on
Hi If appliance fills then starts to wash then stops and starts. Then most likely cause is debris in circulation motor. This will require appliance and motor to be removed
May 21, 2010 | Miele 24 in. G643Vi Plus Built-In...
F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Apr 20, 2010 | Miele Premier-Plus Built-in Dishwasher
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
New printer Kodak ESP 5 Error code 3821
ok i guess i need more information regarding the error code you are recieveing .... exactly what are you trying to do that prompts this error code to pop up ?
Aug 19, 2008 | Kodak Office Equipment & Supplies
Softner tray always full of water after washing cycle has finished, model is meile softtronic w418
Does your softener go into the machine at the appropriate time? That is, towards the end of the wash? If so good; it does not matter if the tray is full after the wash. Disconnect your hoses at your faucet to check if the water pressure is good; you could clean out the small screens while you are at it. Refit carefully.
Rate me pl........... if helped.
May 30, 2008 | Miele Washing Machines
Washing Machines Logo
293 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
