Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer
Washing machine works fine but i have grease leaking out on the floor. It has been doing this for quite some time with no effect on the washers operation. where would the grease most likey be coming from?
  • 5,911 Answers
More than likely this is coming from the gearcase (transmission). Even though it does not immediately affect the operation of the washer, eventually it will. This is a symptom that the gearcase requires replacement. Eventually, the gearcase will begin to fail. It may begin with slower spinning, leaving your clothes wetter than usual. Or, it may start making loud grinding noises. Sooner or later it will stop. I'm not trying to sound discouraging. You can continue to use it until it fails, or replace it. A new one costs approximately $160. The repair is not terribly difficult and I can give you step-by-step instructions. An appliance repair company may charge over $300 with parts and labor. Let me know if you wish to pursue a repair yourself. I hope this helps you.
Posted on May 28, 2008
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
My Kenmore series 70, top loading, washer has a mold smell.
thaty have this one stuff called affresh its used for frontloaders but you can use it for toploaders too it works great
Mar 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer
your lid switch is bad.you can take a pen and push it up and down to hear if it clicks.you may want to take it off and see if it has split.very easy to do.if you need help i can walk you thru it.
Mar 09, 2009 | Kenmore 24032\24036 Top Load Washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
76 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
