Question about Candy DFI Plan Built-In Dishwasher
Candy cdi 4015 dishwasher starts but then stops with E2 error. Have checked water inlet and unpluged it from the mains for a reset but that did not solve the problem.
  • 209 Answers
SOURCE: Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Posted on Oct 07, 2007
  • 5 Answers
SOURCE: di67 s dishwasher
Try tilting your dishwasher forwards. Be warned that water will escape from the front. I have had this problem and paid an engineer to come and tell me this. If your machine is not completely level water collects at the front and does not empty. This then causes the machine not to work. Good Luck
Posted on Jan 15, 2008
  • 249 Answers
SOURCE: Candy cs455 m dishwasher tripping out power
check heating element
Posted on Mar 21, 2008
  • 1462 Answers
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Posted on Nov 20, 2008
SOURCE: Candy CDI 45 E4 code
I have E1 code on Candy dishwasher CDI 45
Posted on Sep 29, 2010
Just installed, shows error code E2, is not heating water
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
May 22, 2015 | Water Water Heaters
Delonghi Dishwasher
Can you please tell us the exact model of your dishwasher? What you can try initially is unplug the power cable of your unit for about 10 minutes, then plug it back in. See if that clears the error. Will give you follow up about the E1 error.
Oct 26, 2008 | LG 24 in. LDF 7811 Stainless Steel...
My Candy DFI Plan shows E3 and stops washing after 10-15 minutes. The problems started because electronics( I swithed with new) than I change the water pump, the heater, the thermostats and when is on,...
E3 - Water heating time out or fault
The dishwasher has failed to heat with water in a reasonable time or has failed to detect the water heating element.
Check water heating element wiring
Check wiring to main control module
Dado
Jul 28, 2014 | Candy DFI Plan Built-In Dishwasher
My candy CDI45 is not working, it just keeps beeping and saying E2. Any tips on getting it working again would make me a happy lady again.
Hi.
E2 is called water safety level error. Unfortunately the problem is often caused by either a defective pressure switch or by a defective control board. The problem is quite common in SMEG built dishwashers like your Candy.
All you can do is disconnecting power for a couple of minutes, by either tripping circuit breaker or disconnecting power cord. That will reset control module. While power is off remove water (if any) from the bottom of the appliance.
If that does not do the job the parts must be tested and the appliance must be repaired replacing defective part.
Regards.
Ginko
Aug 18, 2011 | Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
All cycle lights flash and then the machine stops. I tried turning of and unplugging, tried the switch on/off circuit. Pretty much tried everything. How do I reset my Miele G2140 dishwasher?
Well first of all you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
Good Luck!!
Thanks
Mar 04, 2010 | Dishwashers
Dishwasher stuck´s in program
Well to Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
If resetting not work then you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Good Luck!!
Jun 21, 2009 | Dishwashers
My dishlex dishwasher overflows
The only part that physically allows water to enter a dishwasher (upon receiving power from the control) is the inlet water-valve. I would test the inlet water-valve located directly where you in-coming water line is connected to.
Shut-off power to the dishwasher and remove the 2 prong connection to the water-valve solenoid (small, black, batter size). Test the solenoid for continuity; if bad, replace the entire inlet water-valve (cost about $20)
Jun 15, 2008 | Candy 24 in. CD623 Free-standing...
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Candy DFI Plan Built-In Dishwasher Logo
524 people viewed this question
Top Candy Dishwashers Experts
 Evgeniy_Getz
Evgeniy_Getz
Dado
Tom Chichester
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
