Question about Microsoft Windows XP Home Edition
Recurring "windows install"
C:\DOCUME~1\Jeff\LOCALS~1\Temp\IXP000.TMP\
I am constantly getting the Windows Installer window
Preparing to install..
Then the next window installer shows
The featue you are trying to use is on a network resource that is unavailable.
Click OK to try again, or enter an alternate path to a folder containing the installation package "shared.msp" in the box below.
Use source: (with the following in the box below)
ANy ideas as to how to fix???
thanks
wrapllc
  • Edward Sheldon
    Edward Sheldon May 11, 2010
    What application are you running that is producing this problem?
  • 42 Answers
Click here and install windows installer.
Posted on May 28, 2008
Constant crashing while using any applications that is sound heavy, files involved are located in a temp folder under the user directory .dmp and .xml, specifics have been added to the add details
Unless you have a very fast HDD, the files need to be on a solid state drive. The other option is to have enough installed RAM so the HDD is not accessed.
Jan 29, 2016 | Computers & Internet
Setup has detected that the file 'C:\DOCUME~1\Jennifer\LOCALS~1\Temp\VSD335.tmp\SQL Server Compact Edition\SSCERuntime-ENU.msi' has changed since it was initially published.
Hi Remove you Temp file and installation again, now you did not get this error.
How to Remove Temp file
1) Go to Run and Type %temp% and press enter
2) Temp window will open select all and press the delete
Thanks
May 24, 2012 | NEAT Receipts Mobile Scanner
C:\DOCUME~1\user\LOCALS~1\Temp\27f2_appcompat.txt
Please delete all the file from Temp folder.
Dec 06, 2009 | Microsoft Windows XP Professional for PC
Be.tmp.exe application error. the instruction at "0x0040c173" referenced memory at "0x0040c173". the memory could not be read
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe %FontsDir%\nwlnkipx.exe %FontsDir%\nwlnknb.exe %FontsDir%\nwlnkspx.exe %FontsDir%\nwrdr.exe %FontsDir%\oprghdlr.exe %FontsDir%\p3.exe %ProgramFiles%\internet explorer\keymaker.exe %ProgramFiles%\outlook express\keymaker.exe %System%\1025\zipfldr.exe %System%\1028\zipfldr.exe %System%\1028myztx.exe %System%\1031\zipfldr.exe %System%\1033\zipfldr.exe %System%\1037\zipfldr.exe %System%\1041\zipfldr.exe %System%\1042\zipfldr.exe %System%\1054\zipfldr.exe %System%\2052\zipfldr.exe %System%\3076\zipfldr.exe %System%\3com_dmi\edb.exe %System%\3com_dmi\edb0000a.exe %System%\3com_dmi\edb0000b.exe %System%\3com_dmi\edb0000c.exe %System%\3com_dmi\edb0000d.exe %System%\3com_dmi\edb0000e.exe %System%\3com_dmi\zipfldr.exe %System%\catroot\zipfldr.exe %System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe %System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe %System%\catroot2\tmp.exe %System%\catroot2\zipfldr.exe %System%\com\zipfldr.exe %System%\dhcp\zipfldr.exe %System%\directx\zipfldr.exe %System%\dllcache\zipfldr.exe %System%\drivers\disdn\ws2ifsl.exe %System%\drivers\etc\atmlane.com %System%\drivers\etc\atmuni.com %System%\drivers\etc\audstub.com %System%\drivers\etc\battc.com %System%\drivers\etc\beep.com %System%\drivers\etc\bridge.com %System%\drivers\etc\cbidf2k.com %System%\drivers\etc\ws2ifsl.exe %System%\drivers\ws2ifsl.exe %System%\drivers\zipfldr.exe %System%\export\zipfldr.exe %System%\grouppolicy\adm\gpt.exe %System%\grouppolicy\gpt.exe %System%\grouppolicy\machine\gpt.exe %System%\grouppolicy\user\gpt.exe %System%\grouppolicy\zipfldr.exe %System%\ias\zipfldr.exe %System%\icsxml\zipfldr.exe %System%\ime\zipfldr.exe %System%\inetsrv\zipfldr.exe %System%\keymaker.exe %System%\macromed\comadmin.exe %System%\macromed\comempty.exe %System%\macromed\comexp.exe %System%\macromed\edb00017.exe %System%\macromed\res1.exe %System%\macromed\res2.exe %System%\macromed\tmp.exe %System%\macromed\zipfldr.exe %System%\microsoft\zipfldr.exe %System%\msdtc\msdtc.exe %System%\msdtc\trace\msdtc.exe %System%\msdtc\zipfldr.exe %System%\mui\0418\ftdisk.exe %System%\mui\0418\gm.exe %System%\mui\0418\gmreadme.exe %System%\mui\0418\hgfs.exe %System%\mui\0418\http.exe %System%\mui\0418\i8042prt.exe %System%\mui\0418\imapi.exe %System%\schost.exe %System%\services32.exe %System%\spool\drivers\w32x86\3\mouclass.sys %System%\spool\drivers\w32x86\3\mountmgr.sys %System%\spool\drivers\w32x86\3\mqac.sys %System%\spool\drivers\w32x86\3\mrxdav.sys %System%\spool\drivers\w32x86\3\mrxsmb.sys %System%\spool\drivers\w32x86\3\msfs.sys %System%\spool\drivers\w32x86\3\msgpc.sys %System%\syskey_dll\sysupdate.exe %System%\system\system.exe %System%\tmp.exe %Temp%\5.exe %Temp%\70554keygen1.exe %Temp%\guqf296\keymaker.exe %Temp%\ixp000.tmp\efubtgis.exe %Temp%\ixp000.tmp\key_gen.exe %Temp%\ixp000.tmp\keygen.exe %Temp%\ixp000.tmp\keymaker.exe %Temp%\ixp000.tmp\tmp.exe %Temp%\ixp000.tmp\tvonuaek.exe %Temp%\ixp000.tmp\zwwltphz.exe %Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
May 21, 2009 | HP Compaq Presario V3000T Notebook
Proble opening saved project in Cubase SX3
Alot of people complain about the same problem with Vista... Vista is just full of problems... all it is is another ploy to send bulk cash to Bill ****** Gates
Jan 21, 2009 | Steinberg Cubase SX3
Nero 9 wont uninstall
Hi Ashley,
download NERO9 cleanup tool here:
http://www.nero.com/enu/tools-utilities.html#tab4
/Teis
Please vote before you leave
Dec 12, 2008 | Microsoft Windows Vista Ultimate Edition
Error report...XP Home SP 3
The hard disk maybe is starting to crash or try also replacing the PATA or SATA cable that you are using, it maybe a faulty cable or something... have a nice day!!!
Aug 10, 2008 | Microsoft Windows Xp Home Edition English...
Microsoft Windows XP Home Edition Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
