Question about Garmin iQue 3600 GPS Receiver
I am not getting any signal for months, on one of my satellite
Hello. My name is Abdul. I have 2 satellites. I am receiving signal for one of my satellite, therefore it is working fine (Nimiq 1). However, I am not getting any signal, for a few months for my other satellite (Echo Star 3). I just bought a new LNB switch, but that did not fix the problem. I also moved the satellite, but that also did not work. Can you please email me at rambo_159@hotmail.com, to tell me what can I do to fix this problem, Also can you please email me and tell me. how to put my satellite back in the proper direction, if it is misplaced now? Thank You for you help.
  • 24 Answers
Satellite tv cannot work thru regular splitters so make sure if u are using one it is a good one . Check all your connector to make sure there is no little wire touching the coper one , then try moving your dish while someone is checking the signal intensity in front of the tv . If u do all of this , im sure ur gonna get it working in no time
Posted on Feb 25, 2009
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
I don't have Satellite signal! I tried to acquiere satellite signal with my Garmin Nuvi 1350! The screen always says locating satellites but nothin happens! The satellite bars are not green!What can I do...
Try fully charging the unit and leaving it stationary for about 20-30 minutes if you still dont lock satellites try giving the unit a firmware updates using Garmins WebUpdater software here is a link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 350 GPS Receiver
Hello- using dish 500 with twin lnbf, 311 receiver. 119 locked in easy with 70 signal . When trying to find 110, I cannot get a strong enough signal to lock. 129 signal shows strong along bottom of point...
Hi CharlieO my name is Mike of DISH Network and I was reading over your post and seenwhere your 110 satellite is not locking in or on your install summary screen. Iwould be more than happy to help with this issue and to research further I willneed to look at the account to look what satellites they have setup on youraccount. I will need your account number or your phone number; I will leave mye-mail so you can contact me directly. Michael.houston@dishnetwork.com
Jan 30, 2011 | RCA DISH Network(r) 311 Satellite System
What is the solution to bad signals from satellite cable during bad weather
Hello, my name is Nick Franta with DISH Network Customer Support.
Weather issues can happen with satellite signal. If you are experiencing heavy snowfall, wiping off the DISH of any excess snow will help the signal.
If you have any further questions let us know!
Dec 16, 2010 | DISH Network 322 DTV Receiver
Cant get my check swith to show satellite
Hello, this is Matthew Gonzales with DISH Network customer service. If you are not getting satellite signal, the problem can several different things, but here are a few things you can try. First, try a hard reset. To do a hard reset, you unplug the receiver from its power outlet, wait 15 seconds then plug it back in. The next step would be double checking you satellite cable. On the back of the receiver there should be a cable connected where it says "Satellite in", make sure this cable is secured from the receiver to the wall. After you do these steps, try running a check switch test (menu-6-1-1-check switch-test). If you are still not receiving satellite signal, a technician will be needed at the home to fix the issue. If this has not been resolved, please feel free to email me at matthew.gonzales@dishnetwork.com.
Nov 24, 2010 | DISH Network 301 DTV Receiver
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Dec 31, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Recording
Check your settings, click on the "heart button" You should be good to go. I LOVE my stiletto 2. I've had it for a few months. Good luck.
Feb 16, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Garmin iQue 3600 GPS Receiver Logo
127 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
