Question about Fishman Loudbox 100
Hi, i just got Loudbox100 from US,do i need a power converter or it is fine to use it just with the adaptor?I am from Europe.
  • Fishman Master
  • 5,603 Answers
If the adapter does NOT show it handles your voltage and frequency of your mains then you need to get an adapter designed for for the Loudbox and the mains you have.
DO NOT try to use a "convertor" driving the adapter you have.
Posted on Oct 06, 2010
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
Keyboard wont play with ac adaptor
Hi, Assuming you have tested with another adaptor then invariably it is a broken solder joint on the power input connector.
Re soldering will work but eventually the same thing occurs.
Set the connector in epoxy resin (Araldite) or better still mount a new connector in the case and wire with flying leads.
All the best, Chris the Fader.
Apr 04, 2014 | Casio Ctk 496 Electronic Keyboard with 61...
I have a Yamaha PSRE413. on/off does not work with adaptor, but works with batteries
If you are using the correct adaptor then the most likely reason is that the socket where the adaptor plugs in has broken away from the circuit board and will need to replaced/resoldered.
if you need a socket Google : Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
OR if you have used the wrong mains adaptor and the polarity was reversed you may have damaged the diodes / voltage regulator on the power input.
Jan 24, 2013 | Yamaha Music
Can i use the ps21us power supply in europe without a transformer?
not unless its set up for 220volts also, some of the older models have a switch you can flip to make that change, the newer ones don't, most everything in Europe is 22volts,, they do have adapters with voltage step in them, so shop around, they can be pretty cheap depending on the wattage required.. hers a few you can check out
http://www.amazon.com/Travel-Voltage-Power-Converter-Adapter/dp/B001AHTEEU
Aug 07, 2011 | Shure Distribution Shure PS21US Power...
Bought from usa to australia changed to recomended fuse, fuse blows as soon as turned on the unit was brand new any ideas ?
hi,
You have to check the working voltage of the adapter of you device. If it purchased from US then it will be 110V. I think the Line voltage in Australia is 220V.Also You have to check is there is any input voltage selector in the in its adaptor . If it there you have to change it to 220V. If there is no such selector then you have to buy a 220v to 110v converter .Then connect the out put of that converter to to your device. You can by this converter at any electronic spare part shope near to you. Or you have to by a new 9V 1.3Amps AC adaptor. When you going to by the converter or a new adaptor take the device. If so they will explain you how to connect the converter or adaptor . By changing a fuse you can't change the operating voltage. If The adapter is designed to use in 110V then the fuse will blow. If you change the fuse and make more experiment with it it will make the full system useless.
ok
Aug 05, 2011 | Lexicon MX200 Multi-Effects Processor
Can this unit be easily converted from 110V to 220V for use in Europe?
im pretty sure they sell a converter kit for pretty much anything, so i wouldnt see why not
May 16, 2011 | Peavey XR 8600D Class D Powered Mixer
My adaptor use to work fine now it wont work I found out it was the piece on the back where the adaptor plugs into, If I jiggle it and move it sometimes the power light will come on but it works fine with...
You can get that fixed if you can find someone who can solder. The jacks wear out over time on a lot of things. The jacks themselves are worth about $1 but it is the labour to open the case and solder a new one in.
The contacts in the jacks are spring loaded so these can wear or get damaged etc. So eventually they won;t make good contact and you get your problem. You see this a lot on laptops. You can twist or apply pressure on the plug until you get it to power up. This is more luck than anything when it works and eventually it will get to a point where it won;t connect anymore. This really is a simple repair but finding someone to solder the new jack in is the problem.
Feb 02, 2011 | Casio Keyboard Power Adapter
Fishman Loudbox 100 Logo
171 people viewed this question
Top Fishman Music Experts
Matthew Spark
Matthew Spark
Norma Garcia
Norma Garcia
Are you a Fishman Music Expert? Answer questions, earn points and help others
