Philips 42PF5321D/37 Error Code
I have the 4 red blinking lights error which you said was most likely the SBB. I found the replacement you said for $250. I can also get it off of ebay a little cheaper. Any further advice? I opened the back and I do have a green LED light on a small circuit board on the main power board.
  • gpspencer77 Dec 31, 2008
    My model 42PFL7422D/37 is giving me a blinking error as well. It flashes slowly 6 times and then fast 3 times and then repeats. Can anyone help???
4 Suggested Answers
  • 52 Answers
SOURCE: Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Posted on Aug 14, 2008
phil_frye
  • 295 Answers
SOURCE: My 42PF5321D/37 will not turn on, just flashes a
Most likely a power supply problem. If it's covered under the warranty take it in right away and have them fix it. If not a good Philip's service shop can fix it. They may have a flat fee repair charge?
Blessings,
A/V Guy
Posted on Nov 19, 2009
  • 11800 Answers
SOURCE: philips plasma 42pf5321d/37
4 blinks is an error on the I2C bus 3 - the one that holds VIPER (the protection system), Stand-by Processor, and NVM. Since this is triggered by the processor when the NVM can't contact the Viper or it's not powered (the 12 volts line to it is missing) the digital board was operational and it was changed for nothing.
Most likely the defect is in the power source and you will have to replace it. To help you use this service manual for a very similar unit
http://www.scribd.com/doc/6528782/Philips-42pf7320
Posted on May 13, 2011
Philips 42pf5321d/37 light blinks 4 times. Tv will not turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 25, 2017 | Philips Televison & Video
Will not shift gears & light blinking 5 times
500 rubicon trans problem. - ATVConnection.com ATV Enthusiast ...
atvconnection.com/.../honda/117842-500-rubicon-trans-problem.html
Sep 17, 2003 - It has low gear and reverse only will not up shift in any mode. ... Had the same problem with mine, went to my local honda shop and he had ... My lightswould flash and the trans. wouldn't do anything, had to shut ... Code 5 - Angle Sensor System (Motor lock i.e., angle sensor, wiring, .... All times are GMT -5. Honda Electric Shift (ES) Problem Solved
Mar 25, 2012
My Recon 250 ES Shifter Problems
Jun 28, 2010
HONDA 450 ES FOREMAN SHIFTING PROBLEMS - Page 4
Nov 20, 2005
recon 250 es shifting problem
Oct 10, 2004
More results from atvconnection.com
check engine light blink 5 times rsx ATVs Questions ... - Fixya
www.fixya.com > Forum > Tags > check engine light blink 5 times rsx
Question about 2012 Big Red MUV ... Check engine light blinking on Honda big red muv Check engine light slowly blinks ... My 2014 honda foreman 500 es 4x4 neutrallight blinks 4 long times and 2 short times and will not shift into gear.
Honda blink 3 times ATVs Questions & Answers - Fixya
Feb 08, 2016 | Honda 2012 Big Red MUV
Noticed when laundry room is dark you can see a blinking red light under the area of the lint trap on Frigidaire stackable washer/dryer model FFLE1011MW1. Just curious to what that may be.
I did some research on this. It appears the blinking red light is to indicate there might be a problem. The "blinking" is actually an error code. A certain number of "blinks" is indicative of certain types of errors. This is similar to a cars "check engine light". A car is scanned to get the code, which can help lead to the problem. I found a common source for dryer codes according to the blinking red light here:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134859700e.pdf
I hope this helps :-)
Jan 28, 2016 | Frigidaire Washing Machines
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
I have a Philips 42pf5321d/37 that won't turn on.
send me a email sonny@tvcircuitboards.com and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
Ford explorer , car keys replacements. I have lost my ignition / alarm keys and need inexpensive replacements please. Thank you in anticipation David Byrne
I think you can use the sbb key to pro for a new key.
Before running SBB key programmer, you need insert the blank new key into your car keyhole;turn on ignition switch;Insert SBB 16-pin interface into your car OBD2 diagnostic seat. SBB key programmer copies chip according to car model.
http://chinasinoy.com/upload/pro/sbb%20car%20model%20list.pdf
Oct 04, 2011 | 1998 Ford Explorer
Lost the key, tried spare that realized only unlocked the doors in the ignition and the theft light started blinking. Is still blinking and now have original key but key wont turn in ignitionr
you can use the sbb key to copy a new one, Before running SBB key programmer, please insert the blank new key into your car keyhole;turn on ignition switch;Insert SBB 16-pin interface into your car OBD2 diagnostic seat. SBB key programmer copies chip according to car model, and it program key not clone key, it only needs to insert SBB. It is easy to do, you can DIY, if you don't know about the knowledge of the car repair, you need call for help of locksmith....
Sep 01, 2011 | 1998 Ford Explorer
My both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
May 26, 2010 | Epson Stylus Photo R200 InkJet Printer
Same as jasonvonk mar 15 2010 I get error code 37 after device and menu buttons pushed. red lite blinks 4 short pause and 4 short again Jim
37 is lamp or dmd failure. i don't find anything on 4 red blinks.44 error code which is 4 blinks, and then 4 blinks in disconnected DVI cable from light engine.
Mar 25, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
365 people viewed this question
Top Televison & Video Experts
