Question about Dell Dimension 8300 PC Desktop
How do i get the brightness bar to not appear in the middle of my screen
RCA tablet too bright
Swipe down from the upper right corner. In the middle of the screen, you may see a button appear for a few seconds, tap it. It may give you access to a slide with which you can adjust the brightness of the screen up or down. If you dim it too much, you may not see a screen! Here is a page showing how to increase brightness. --However, it should serve to show you where the controls are.
http://www.instructables.com/id/Fixing-lost-brightness-on-an-RCA-tablet
Dec 30, 2017 | Tablets & eReaders
How do u brighten up the screen on the zte lever
go into settings then display then you can alter brightness or you can drag down from the top of screen with two fingers and the brightness bar should appear then you can change the brightness .
Dec 24, 2015 | ZTE Cell Phones
How do you change the brightness of the screen?
First, make sure your VGA driver is up to date.
At the right down part of your screen, right-click on your battery bar, scroll to "Adjust screen brightness"
Look down, at the middle of the screen, you will find screen brightness there.
I hope this helped.
Regards.
Aug 21, 2014 | Computers & Internet
How to adjust screen brightness
follow the steps below;
I hope this helped.
Regards.
Aug 21, 2014 | HP Compaq 6710b Notebook
My monitor is very dark, where do I find the control for brightness
  • Press on the "Fn," or function, key. It is located in the bottom-left corner of the keyboard, typically next to the "Ctrl," or control, key. Do not depress it.
  • 2
    Press on the "F8" key, which is located in the middle of the Presario's top-most row of keys. You should now be holding down the two keys simultaneously. Small illustrations of a sun and half moon often accompany the F keys allowing you to adjust screen brightness.
  • 3
    Monitor the progress bar that appears on your screen as the brightness increases.
  • 4
    Release the two keys once you have achieved the desired brightness.
  • Mar 07, 2011 | HP Compaq Presario V2000 Notebook
    My screen become blank, one thin Horizontal bright line in middle of the screen appears
    You have what we call 'frame collapse'. This has many causes and without fault finding, I cannot pin point the exact location of the faulty component.
    Feb 13, 2018 | Toshiba MV20FM3 20 in. TV/VCR Combo
    Screen Noise
    replace DM or try to fix it.
    http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
    http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
    http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
    http://hdtvoice.com/voice/showthread.php?t=32186
    Jan 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
    Why are there vertical lines or bars on the monitor screen when I record a movie?
    Recording a movie of a subject that is brightly lit by the sun or some other very bright light source can cause vertical lines or bars to appear in the image during playback. This is due to a CCD phenomenon called "smearing." Note that lines or bars appear in movie images only, but not in snapshots. Smearing does not indicate malfunction of the camera.
    Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
    Dell Dimension 8300 PC Desktop Logo
    19 people viewed this question
    Alun Cox
