Connecting a DVMRe to a PC
Hi, I want to connect my GE Kalatel DVMRe Triplex to my desktop pc. The DVMRe manual states if contecting directly to the PC to use a Cross Over Ethernet Conection. The problem is the ethernet port on my PC is being used by DSL modem and wireless router. Or can I connect the DVMRe to a wireless router and config that router as a repeater so it will talk with the wireless router that is currently connected to my PC? As you guessed I am not computer savy, help. Thanks
    Genius:
  • 1,027 Answers
The best way to configure this would be directly from the laptop so I would suggest the appropriate cat 5 cable and a pcmcia cardbus network adapter or a usb network adapter.
Link
Link
Posted on May 28, 2008
  • 77 Answers
I have done what you are talking about with making the one router act as a network bridge. It is a pain in the **** to do but with enough time it can be done. The main things you need to do are:
  1. Configure the 2nd router as a bridge/access point.
  2. Disable DHCP on that router and give it a static IP address on the same subnet as your main router.
  3. Use the same exact wireless encryption for both routers. I believe I used WPA2 and set the passwords for both to be the same key.
  4. Pray.
LOL. It is a pretty involved project and took me a little bit. The only reason I did this in the first place was I promised my gf that I wouldn't spend 100$ to get my XBOX360 online and since I had a spare wireless laying around I decided to see if it could be done. I'll see if I can dig up a few sites I visited that helped me along the way. Good luck!
Chris
Power supply DVMRe
The DVMRe uses a 12VDC, 4.0A supply. with center +
It's a standard barrel-type connector.
Note that if the supply isn't capable of 4 Amps or better, the unit will turn on, then go back off immediately, then try again forever
Dec 07, 2011 | GE Security DVMRe-16CT-1T 16-CHANNEL Color...
Hello, I have a dvmre-10cd I can ping but can;t connect through browser. Any suggestions?
Do you know the ip address of the dvr?
Are you trying to connect through a router if so is it wireless?
If wireless have you done the necessary port forwarding?
Mar 22, 2011 | Kalatel Dvmre-10cd-7 10ch Duplex Dvr...
My GE Security DVMRe-16CT-1000 16-CHANNEL I power
Sorry this thing it garbage now.The hard drive have bad sectors on the boot up.This can't be repair except replaced the hard drive.Not worth to fix,if have to replaced the hard drive.
Jun 15, 2010 | GE Security DVMRe-16CT-1T 16-CHANNEL Color...
Connecting a dvmre to a wireless router
Everything sounds ok. Try to add more port in your port forwarding. Actually, even if you don't forward port 80, by default its already open because that is for internet access. Research more port that your dvmre is using. You may want to isolate the problem by connecting your dvmre directly to the modem and check if it works there. If not, maybe your ISP is blocking some port the your dvmre is using.
Feb 11, 2009 | GE Home Security
Unable to connect remotely to dvr unit
I'm presuming you are using Internet Explorer. You may need to change your browser's security settings to solve this problem.
Using Internet Explorer, click on TOOLS, Internet Options, Security, Local Intranet, then move your slider all the way down to Low and click Apply.
Dec 07, 2008 | GE Interlogix Dvmre Pro 10 Channel Triplex...
Dvmre triplex
I would switch monitors and see if the problem still exists. Sounds like the monitor not the Dvmre.
Aug 07, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Operating disk
Go to this site and download WaveReader software.
http://www.gesecurity.com/portal/site/GESecurity/menuitem.11620ebca5cc0a06574efe10140041ca/?vgnextoid=4f9fe4997e789110VgnVCM100000592d7003RCRD
Jul 25, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Config DVMRe to PC
  1. Main Menu
  2. Communications
  3. Ethernet Settings
  4. Enable
  5. On your pc click start, run type in CMD, click OK
  6. at the prompt type in ipconfig, hit enter
  7. write down the ip address, subnet, etc.
  8. On pc open network connections
  9. create new connection
Jun 05, 2008 | Computers & Internet
Help me!
I have strongly recommended that change your power supply with the same specification voltage and amp. I have installed so many GE DVR's most of DVR's restart when the power supply is not working properly or HDD have bad sectors. I also recommend use the scan disk on you HDD for proper checking of your HDD.
FROM
AI
Jan 29, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
