Question about Garden
Fuel cuts out under load, primer button slow on release,
  • 3 Answers
Clean or replace fuel filter.
Filter is located in the gas tank, on the end of a small rubber fuel line.
Use a large wire, with a hook(1/8 in. radius inside)on the end, to pull the filter far enough out of the
tank to remove the filter assembly.
May be difficult to re-install filter assembly because fuel line is short (it will stretch 10 to 20 % of it's
length).
Posted on Oct 07, 2010
My craftsman push mower won't start. Have replaced filter and spark plug. Still won't start
how many times have you pushed the primer button ? on the bottom there is a valve push this up and fuel should come out, try these, prime pump 10 times then press fuel release then 10 times on the primer and try then.
Jun 05, 2017 | Craftsman Garden
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
After running for a bit it wont start, the primer is < a 1/4 full just sucking air.
this sort of sounds too me as A fuel line routing problem / as sometimes happens when replacing a old fuel line one doesn't get it back right as it was before and maybe runs line instead by a part that gets hotter than others , this causes fuel to boil in a hot saw and create a air pocket , this makes it near impossible to get liquid fuel to pass by it and blocks up the works , other thing it could be is that primer bulb has a tiny crack inside and allows air to enter and not fuel (heavier) ive seen that happen a few times as well
Aug 31, 2015 | Husqvarna 240 Chainsaw 16" Bar -free...
Replace fuel primer rubber button on Briggs Stratton engine
check for clogged fuel line or clooged stone filter in the gas tank.
Sounds like the Bulb is working fine it just can't draw up fuel
Sep 19, 2012 | Garden
Briggs and stratton 875 series
Engine hunting is fuel starvation, dirty fuel, partly blocked main jet.
Jun 02, 2012 | Swisher T14560 T - 60" Trailmower with 14...
Poulan prolink pp335 will start runs for approx 1 min then dies , noticed primer bulb retracts slow after being pushed in
This is classic fuel blockage, start by changing the fuel filter in the fuel tank, if no better check fuel hose has not collapsed or become trapped, if no better remove the carb, under the pump cover ( alluminium cover held with a single screw ) under the diaphram is an internal filter, clean or replace.
Mar 04, 2012 | Garden
My Toro 20016 will start but will only run for a minute. If I hold the primer button down all the way it will continue to run but will die if I release. I have cleaned the float and there are no leaks in...
You will need to clean out the jet on the bottom of the carburetor. The fuel is not being sucked in to engine. Check the needle and seat to make sure fuel is flowing in to the carburetor.
Jul 18, 2009 | Toro Lawn Mower With Toro Power Tools
The mower speed slows marginall y (only) but
You need to disassemble the carburetor, check fuel line, fuel filter, and buy a carb, kit. Replace all appropriate parts such as, gasket(s), diaphragm, etc. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean small portals in carb. Reassemble and start.
Jim
Jun 09, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
