Question about Dishwashers
When turning on time display it flashes E4 and makes draining sound? What's happening and how do I fix it?
  • gerardand352 Oct 06, 2010
    sorry its a Heller HWD121ss and its empty ie. no water visible inside
    Sorry for late reply I went to bed I will look into it today thanks for the info
  • 19,396 Answers
Hi.
On most dishwashers E4 means overfilling, naturally to be sure, the make and model of dishwasher is needed.
If problem is overfilling, the appliance will stop with water in the tub after overflow has been detected.
The remedy is tripping the circuit breaker, and with power off drying water from inside the tub. If th(or simal) device, it is also necessary to reach the overfill device and empty water, the device is located behind panel at bottom of the dishwasher.
Here a document.
Regards.
Ginko.
Posted on Oct 06, 2010
  • 1 more comment
  • Ginko
    Ginko Oct 06, 2010
    Hi I think that this is the same as Baumatic and Hotpoint. Let me have a look.
  • Ginko
    Ginko Oct 06, 2010
    Hi Gerard.
    I have done some research.
    Heller is built by GAF appliances, and there is no available service documentations online.
    The error E4 is either overflow or insufficient pressure. This are the error codes reported by the several kinds of control boards mounted on different dishwashers.
    Trip the circuit breaker.
    Check if there is water under the kick panel at the base of the appliance, and if possible check if the water hose at the back is kinked or blocked.
    Restore power.
    Because of the scarce documentation available, I think that the best thing to do is contacting the manufacturer: contact GAF.
    Best regards.
    Ginko.
  • Ginko
    Ginko Oct 06, 2010
    Note: if when you see the E4, you also hear an humming noise, then I was correct, the machine is sensing overfill and the humming noise is caused by overfill protection keeping the drain pump on.
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Flashing F2
see the details and fix it. God bless you
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
•check the drain filter pumpfor foreign objects
• If the above does not correct the problem replace the pump
Jul 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My Singer stylist 7258 is giving an E4 error code. It wont work at all, just give an odd sound and a high pitched sound then stops, flashing E4 on the display screen. It is only 2 months old and I live...
the brand new stylist I just bought at a thrift shop for $15.99 had a sticker on it stating, "Broken, you fix, parts in back"... I got the lady to get the parts in the back, which was the box it came in and all the accessories. Took it home plugged it in and E4 came up. I took of the nose guard with the one screw on the side, reached in and turned the coggs gently, viola, it works great.. The little servo or motor if you will got stuck when turned off in a zig/zag decorative mode. eazy fix, great machine,
hope this helps..
Michaelalan Quilting
Oct 26, 2011 | Sewing Machines
I have a comfort aire pac-121 and the display is reading e4 and the ac is not working. i can't find a manual on line. How can I fix the problem? thanks andy
I have the same model, though several years old, and on mine E4 simply means the reservoir is full. Try emptying the reservoir tank and then turning the power on again. If the drain hose outlet isn't angled down, the water drains into the tank, which will need to be emptied regularly. (For constant use, may need to be emptied several times a day.)
Jan 15, 2011 | Comfort-Aire PAC-121 Air Conditioner
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Dishwashers Logo
150 people viewed this question
Top Dishwashers Experts
