Question about Brother Office Equipment & Supplies
UNABLE TO CLEAN IS COMING UP REFER TO MANUAL I HAVE NOT GOT ONE PRINTER IS MFC 620CN
Mix-it-up
  • 832 Answers
SOURCE: brother mfc 620cn
http://www.fixya.com/support/t213408-keep_getting_error_message_unable_clean
Posted on Oct 23, 2007
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
Joed911
  • 4338 Answers
SOURCE: printer has unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
Then with the power on, pull the plug from the wall for several minutes. The plug it in and power the unit up.
Here is the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 20, 2008
  • 159 Answers
SOURCE: Brother MFC-620CN printer unable to clean error
Often means something is blocking the printhead from traveling all the way left & right. Look carefully in there, especially under the ends, for a scrap. It may be black with ink and hard to spot, but if you see it, a minute with some tweezers may fix everything.
Sometimes the timing strip gets knocked out of its sensor, so the machine can't detect whether it's moving when it turns on the motors, so it locks up with that error. Getting to that is a bit trickier. Open the top and pry out a couple of skinny plastic covers that hide cables. One of those covers acts to lock in the lever that holds the top section up; once you've removed the cover, you can unsnap the lever from the bottom end, allowing you to stand the top (scanner) section straight up. Take a good look at the cables & how they're laid. The flat white one is especially delicate, and must not be reinserted crooked. Unplug those cables and pull them out of the way so you can remove the top cover they're laid in. There's also a ground wire to unscrew.
The top is held on with what - six or seven screws? Keep track of which goes where. I think the front edge is caught by a plastic hook, also. Free it by prying with a small screwdriver, and lift off the top cover.
The whole printer mechanism is now exposed. You can see the 1/4-inch (6mm) wide strip of film that's stretched tight across the entire width of the printer area. The gray in that strip is hundreds of fine vertical lines. A sensor in the printer head carrier shines through those lines and counts them to keep track of where it is at all times. If you find the film strip laying flat across the top of the printhead, just lift it carefully and lower it into its slot in the sensor. It should be vertical and straight. Don't get ink or fingerprints on that strip; it can be cleaned - very gently - with a damp cloth.
Put the cover back on, install those cables, the lever that holds the scanner up, and the little covers, and try it out.
If it's not a paper scrap or that timing strip, it's probably too expensive to mess with, but check with the closest service center listed on Brother's website. If none appear to be close enough, don't be shy about calling one of the closest ones and asking if they have another branch that's not listed on Brother.
Posted on Dec 24, 2009
SOURCE: Printer unable to clean. Have follwed
Try this...
Go into maintenace mode by pressing ( Menu * 2 8 6 4 ) within 2 seconds. You should be in the maintenance mode now. Press 80 and scroll down to purge count, if the figure is more than 6000, press 2 7 8 3 to reset the purge count. The printer will restart and everything normal. Good Luck
Posted on Aug 04, 2010
Unable to cl;ean
Hi Ada,
Go To Below official Brother Printer Video For Your problem,
Still having Problem Then follow Us For
Brother Printer Support
Jan 29, 2014 | Brother MFC-620CN All-In-One InkJet...
Reads "unable to clean"
REINSTALL AND INSTALL PRINTER DRIVER.
FILL THE INK.
MAY BECAUSE OF PAPER JAM.
CHECK YOUR CABLES.PLUG IT PROPERLY
Jan 27, 2011 | Brother MFC620CN Home/Office Color Inkjet...
Brother MFC-620cn displays "Unable to Clean" error I have unplugged for hours and it will not clear. All ink cartriges are full and my status monitor indicates they are full. This came about after I did...
Your MFC has reached its limit of cleanings. The ink absorder box is full and needs to be replaced. Check the brother website for an authorized service center in your area.
Mar 29, 2010 | Brother MFC-620CN multifunction Color...
I am getting a unable to initialize Error in Brother printer
uninstall then reinstall the printer after you reboot. don't forget to load the drivers.Hope that helps. good luck
Sep 03, 2009 | Brother MFC620CN Home/Office Color Inkjet...
Cleaning
cleaning here is more like the head cleaning from the print manager.
Jun 16, 2008 | Brother MFC620CN Home/Office Color Inkjet...
MFC-620CN
sure..you can go through this link, and enter model number, then ask for user manual.
Mar 10, 2008 | Brother MFC-620CN All-In-One InkJet...
63 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
