Question about Janome Sewing Machines
I need a needle screw for a 9200D overlocker. Where can I find this part?
    Genius:
  • 1,788 Answers
I would call Janome at 1-800-631-0183 and order directly from them so that you get the correct needle screw.
Posted on Oct 06, 2010
Replacing needle on Singer overlocker.
The manual should have instructions. Most overlocker needles have a screw that holds each needle in place. Just loosen the screw with the screwdriver that came with your machine, slide the old needle out (note which direction the flat side of the needle is facing), insert the new needle as far up as it will go, and tighten the screw. Don't lose those screws or drop them inside the machine. If you remove a needle so you can serge without it, be sure to tighten that screw so it doesn't fall out.
Mar 02, 2017 | Singer Sewing Machines
Overlocker u2345
Be sure you are unscrewing the needle screw sufficiently to allow the needle base to fit (be careful to not drop the screw as it is very small and will have a tendency to disappear!).
Also, most overlockers come with a needle installing tool which is basically the cleaning brush with a small hole drilled through handle where the needle point is held during installation. Makes it easier to get the needle into the little hole in the needlebar.
Also, be sure the flat side of the needle is facing the correct direction.
Looks like this:
Sewing Machine Needle Holder Applicator Tool Brush
Feb 09, 2016 | Sewing Machines
My needle holder in my Euro-pro ep550 will not tighten to hold the needle in the machine. how ill i buy another needle holder to fit my machine
if you take the serger to a sewing machine shop and show them the problem, they can check to see if the needle holder needs to be replaced or just some new screws
Sep 06, 2014 | Euro-Pro Sewing Machines
I have just snapped the needle on my Husqvana overlocker 905 how do I change the needles
The serger came with a tool just for that purpose. It may be a small screwdriver or it might be a hex or Allen wrench. Locate the screw that holds it in, insert the proper tool and turn counter clock wise until the needle will slide down, remove and replace with new needle, then tighten, clockewise the screw. You are done
Jul 05, 2014 | Sewing Machines
How do I change a needle on my husqvana 905 overlocker
Each needle has a small set screw holding it in place. Just above the needle from the front you can loosen the needle by using a T6 (Tork 6) screw driver (if you don't have the original tool that came with the serger) to loosen the needle. Before loosing the screw, I would put a piece of fabric or paper over the needle plate to catch the needle (or part) to keep it from falling in the machine. Turn the screw counter clockwise (to the left) to loosen. Insert the new needle and tighten. It's not necessary to remove the screw entirely, just loosen it and the needle usually just falls out.
Good luck.
Jul 05, 2014 | Husqvarna Sewing Machines
Janome 9200d overlocker
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Aug 18, 2013 | Sewing Machines
My janome 9200D overlocker has stopped sewing.
it's possible that the machine has gone out of time & needs to be serviced
May 29, 2012 | Sewing Machines
My manual got lost, need to remove needles, I bought a Empisal Model S4D Overlocker but the manual or CD got lost and I need to get one
look on you tube for overlocker parts instruction.generally the needle is removed by loosenening a little screw which is pushing on the needle from the from.
sewingmanual.com has manuals for sale
Sep 14, 2010 | Yamata FY812 Mechanical Sewing Machine
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
