Xerox phaser 6180 MFP displays errorr message and code BLK CRUM ERROR 093 925 restart printer problem occurred when a fax was being received
    Novelist:
  • 217 Answers
This error message points to either
1 A corrupted chip on the toner cartridge.
2 The wrong chip on the toner cartridge. There are several printers that take the same basic cartridge, the difference being the chip.
If you have just bought the cartridge, return it for replacement.
Posted on Nov 25, 2015
5 Suggested Answers
MSG-CPC
  • 1325 Answers
SOURCE: Xerox Phaser 6180 doesn't like
hi
go to this link, you can view a video on hoe to install ink cartridge (near bottom of page after selecting link) .. also, you can search the same link to get some answer as to what the erro you experienced could be.
http://www.xerox.ca/office/printers/colour-printers/phaser-6180/sprt-enca.html
Posted on Jan 12, 2011
  • 395 Answers
SOURCE: I have a Xerox Phaser
Here is the solution I found to match exact your model and error codes
Error code 093-951 is related to print cartridge crum error magenta
Solutions include:
If the printer is connected to a network, check the Print Cartridge level using CentreWare Internet Services (CWIS) and replace the cartridge, if necessary. See the Related Items below for additional information.
If the printer is connected to a computer via USB, replace the Print Cartridge, if necessary. See theRelated Items below.
To check the Print Cartridge levels using CWIS:
NOTE: If necessary, print a Configuration Report to obtain the IP address of the printer. See theRelated Items below.
  1. Open an Internet browser window.
  2. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on the [Status] button. The Status window will be displayed.
  4. Click on the [Supplies] link. The cartridge levels will be displayed in the Toner Cartridgessection.
  5. If necessary, replace the Print Cartridge (you mentioned you removed the toner only, so check the level of toner to see if you need to replace it)
  6. When finished, close the browser window.
And
  • Power off the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
  • Wait at least 10 seconds.
  • Power on the machine. Press the power switch to the (') position.
  • Error 52 means Remove the Duplex Unit (if installed), check for paper under the upper tray, and turn power off then On.
  • Hope this helps
  • Thanks
  • Posted on May 05, 2011
    SOURCE: Xerox Phaser 6180 MFP-D password
    The default password is "00000" If this password does not work you can follow the following to reset it:
    1. Power OFF the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
    2. Press and hold the [OK] button on the Control Panel.
    3. Continue to hold the [OK] button and power ON the machine. Keep the [OK] button held down until the Ready screen is displayed. The password is now reset to the default Control Panel password, which is 00000.
      NOTE: There will be no confirmation message during or after the machine's power on sequence. However, if the procedure was performed correctly, the password has been reset.
    Posted on May 29, 2011
    • 217 Answers
    A cartridge CRUM error indicates that either the cartridge chip is faulty, or it is the wrong type for THAT printer.
    There are 7 vairants of this printer under different makers names and model numbers. If you've just changed a cartridge it has the wrong chip on it. Either you've bought, or been sent the wrong item - contact your supplier.
    If you have had this cartridge in the printer a while, that cartridge chip has become corrupted (could happen if there's a power problem during a 'write' operation to the chip. A replacement cartridge will cure this.
    Posted on Sep 24, 2015
    How do i fix error bk-crum error 093-925 - using geniue carttidges
    If you have just installed these cartridges and got this message immediately, Make sure that these are the correct cartridges.
    The cartridges for the Xerox 6180 are identical to look at, but have different part numbers, and crucially different chips.
    There are also pagepack/Eclick versions of these cartridges.
    If your printer is a 'pagepack' version of the printer, it needs pagepack/Eclick cartridges, and will give an error if normal cartridges are used. Similarly, if your printer is a 'normal' version, and you put a 'apgepack/Eclick' cartridge in it, you'll get an error.
    If you've had the cartridges in the printer and used it WITHOUT getting the CRUM error message, the counter chip has become corrupted. This can happen if there is a power problem during a chip 'write' operation.
    The error message points to the Black cartridge.
    Sep 22, 2014 | Xerox Genuine Phase 6280n 6280 6280dn...
    09-800 Invalid Toner Cartridge Message
    Verify that you are using oem Xerox toner cartridge. If you're using an Oem Xerox cartridge and still getting this error it could also be the Crum Board, part number 140N63302.
    Apr 11, 2013 | Xerox Phaser 3635MFP/X Multifunction...
    Xerox Phaser 6280 Y CRUM ERROR
    The yellow cartridge either has a corrupted chip, or the wrong chip, or its a cartridge from a different model of printer.
    Xerox 6180 and 6280 cartridges LOOK the same, apart from the label and part number - the chip is different.
    Feb 08, 2013 | Xerox Phaser 6180N Laser Printer
    ERROR 093-951
    http://www.refillbros.com/en/manuals/p1643-xerox-phaser-6280-service-manual?page=199
    see this page for detail and how to repair
    i hope this helpfull, if you think this helpfull please rate very helpfull
    thanks for using fixya
    Jan 23, 2011 | Xerox Phaser 6180N Laser Printer
    Xerox Phaser 6180 doesn't like the black in cartridge and displays Error 093-925 CRUM Error. I'm on a deadline and can't have my printer down. What's up? I paid $24 and got no experts to chat with me.
    hi
    Jan 12, 2011 | Office Equipment & Supplies
    Xerox 6180 MFP N error 016-782 Windows 7 x64
    did you get a solution to this problem. i have the exact same situation.
    Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
    Phaser 6180 error code 033-762 Fax not recieving
    possibly junk fax feature is ON which assumes every fax you receive should have sender fax numer pre-registered, otherwise it just rejects the fax sent from an un-registered number
    Jan 05, 2010 | Xerox Phaser 6180N Laser Printer
    Xerox phaser 6265 displays engine service 8300
    From the service manual:
    Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
    1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
    2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
    after the power has been turned off and then on? If so, go to step 3.
    3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
    4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
    5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
    Jun 23, 2009 | Xerox Phaser 6250 Laser Printer
    546 people viewed this question
    k24674
