Question about M-Audio Studiophile BX8a Speaker
M-Audio MX8a tweeter replacement
I have a tweeter I'm trying to replace but not sure how to get it in. I've take the screws out from the parameter of the back of the speaker...do I need to take out any more to gain access? Then how hard should I expect to pull to release the back? Thanks, Artfoonman
  • warmachine00 Jan 17, 2009
    im having the same issue. some crackle in the speaker, then sound goes in and out. if i tape down or hold the sub with my finger, the sound stops, and the speaker stays on. im guessing the bass is shaking a connection loose, which i can solder myself, but i cant get access to it --and ive take all the screws out.
    New Friend:
Remove the six hex screws from the plastic front speaker housing. It\'s the piece with the speaker\'s make and model imprinted.
Gently pry the cover off. The blue LED light can be easily freed by gently prying it loose from the back of the plastic housing. You\'ll notice the two wires connecting your tweeter. Don\'t pull too hard on the cover while the tweeter is still attached to prevent detaching the wires. Instead, take very short, stubby Phillips head screwdriver and remove the two screws holding the small plastic brace against the back of the tweeter. It\'s a tight fit. Don\'t pull too hard on the wires! Next, push the tweeter out from the front, touching only the extreme outer rim. Or, use needlenosed pliers to grip the heat sink on the back of the tweeter and gently pull from the back. The tweeter has a very powerful magnet. Find a small but robust rectangle made of ferrous metal. Large enough to span the front diameter of the tweeter. When the speaker magnet grabs the little metal plate, adjust the plate until the buzzing stops. This means of course that you have to turn the power to the speaker on.
Posted on Dec 08, 2013
M-Audio MX8a tweeter - Where can i purchase a replacement?
You may not find an exact match, but you should be able to find a suitable replacement that is the correct size and impedance from SimplySpeakers.com :
Replacement Speakers
I would recommend replacing both L & R tweeters, especially if its not an exact match replacement.
Jan 19, 2015 | M-Audio Studiophile BX8a Speaker
Hey.. I just bought a Bx8 studiophille.. Unfortunately I got cheated.. One of the speakers tweeter is not working.. Can you give me a solution.. Where can I get it replace??
How sure are you that't you tweeter and not a contact cable or, sunce they use cheap xhinese capacitors on the m-audio, just a capacitor has dead. Don't buy a tweeter, since they very often die and check the inputs , especially TRS amd rca and unscrew the the backplate and you'll notice that the cables and connectors used are cheapio. So it worth to check the pcb,s if you see broken caps. Which wouldn't surprise me , since their cheap once. And before buy another tweeter, first try it out on another small amplifier, to see if it works. Buying a new ine is the last fase, they ask high prices for a 10 dollar unit. Where did you buy it and how old is the unit?
Greetings richard
May 09, 2014 | M-Audio Audio Players & Recorders
Where can I source a replacement tweeter for cerwin vega e-712
the exact replacement tweeter can be purchased from midwest speaker company
google it
Sep 27, 2012 | Cerwin Vega E-712 Main / Stereo Speaker
How do I replace the tweeter on Mordaunt Short Avant 906i speakers?
Hi - Just reading your problem with the 906's and removing the front cover to replace the tweeter. Did you ever solve the issue? because I tried today and I can't budge the silver cover once the screws have been removed. My email address is chris.clemons@btinternet.com if you can help - thanks
Feb 16, 2012 | Mordaunt Short 906 Rear Speaker
How do i tell if my problem if the high freq diaphram or the cross over
The crossovers in professional speakers don't fail that easily. It could be a blown tweeter. To confirm remove the metal grille-- remove the screws of the Horn Tweeter -- remove the cable connectors on the tweeter terminals ( Red and Black wire ). Now if you have a multimeter put it in Ohms range and touch the probes on the tweeter terminals-- It should show a reading betwwen 4 to 8 Ohms depending what is written on the back of the tweeter magnet. If you do not have a Multimeter you can take an ordinary cell/battery ( 1.5v ) from a TV remote and touch the terminals of the Horn Tweeter with the battery. + to the tweeter + ( a small red dot or mark will be there on the tweeter ) and -- to the tweeter -- . When you touch the terminals or give 1.5 volt supply the tweeter will make a scratching noise.
If you do not hear the scratching noise - it indicates a blown tweeter coil and will need replacement.See link below for spares:-
http://legacysoundservice.com/catalog1/product_info.php?products_id=1417
But if it does, you are in trouble and will need professional help from a electronic technician.
Could be blown HF Amplifier, suspect the crossover last. They seldom fail.
Revert back for more help
Apr 02, 2011 | JBL PRX515 Speaker
NEED TO CHANGE OUT OLD TWEETERS IN MY 2001 GRAND CHEROKEE HOW IS THIS DONE?
just got to pull the dashboard where the tweeters are after that just replace the tweeters and just make sure to plug in color with colo and everything should be fine
its a simple proccess all you might need flat head screw driver to pull the dash board up its only the very top part of the dash
and another screw driver to remove the tweeters and them put them back
Dec 06, 2010 | Car Audio & Video
Blown tweeters on pair of The Amazing Alphas
check on radio shack maybe there got something that fits your necesities
Feb 06, 2010 | Audio Players & Recorders
Replacement KEF Coda III TWEETER Type SP1087
Go here and find a nice substitute. Many to choose from and it may be better to purchase a pair of them rather than have mis-matched ones. They should be inexpensive enough for you, as low as $2 up to $480. You just need the size of the mounting hole to find a replacement though.
http://www.parts-express.com/speakers.cfm
Nov 21, 2008 | KEF Audio Model Three Main / Stereo...
Tweeter and door speakers to fit a Lexus EX 300 w/Levinson factory system
I found that they can hold up to 6 1/2" speakers and 2" tweeters. I'm not sure the specific mounting depth but i can almost assure you there wont be any 6 1/2" speakers that require a whole lotta space
Feb 22, 2008 | Cdt Audio Eurosport ES-100 Car Tweeter
Open Questions:
See all M-Audio Studiophile BX8a Speaker Questions
M-Audio Studiophile BX8a Speaker Logo
573 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
