Question about Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool
How to remove chuck from dewalt xr2 drill, i have removed screw but it will not budge alan shiels
  • 268 Answers
You will need to use an allen wrench and a hammer to remove it.
Here is a link that will explain with illustrations how to do this.
http://www.ereplacementparts.com/article/890/How_to_Remove_a_Drill_Chuck.html
Hope this helps
Posted on Oct 28, 2010
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
Can the chuck be replaced on a 18v dewalt?
Hello russ_rome,
Here is the solution from the Dewalt website.
Firstly check to see if the chuck is secured with a screw, if you have a screw follow steps 1-3 else follow steps 2-3.
Step 1: Screw will have a left-hand thread and must be turned clockwise to undo it.
Step 2: Once the screw has been removed place a suitable Allen Key in the chuck and tighten the jaws.
Step 3: You should then tap the end of the Allen Key to ease the chuck off (the chuck has a conventional thread so unscrew it in an anti-clockwise direction).
Some of our high spec cordless drills will need to be serviced need to be taken to your nearest service centre to have a new chuck fitted.
Regards
Alan Hood
ami-man
UK
Jun 10, 2010 | Dewalt 18 Volt Compact Drill Kit
How to remove the chuck?
open the chuck fully and it shoudl have a screw inside. Unscrew it, but be carefull, these screws are usually reversed - to uncsrew, rotate it clockwise. Once done, put allen key into chuck (short side in), fasten the chuck to hold allen key well and hit the key with hammer - counterclockwise direction. You might want to verify this procedure with someone else as I have no experience with Dewalt, but this way it works for Makita, Metabo, Narex, ... then why not for Dewalt? Juraj
Jun 06, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
Seized chuck.
I would continue to use the rust remover/penetrating oil products, put a pair of vice grips on the chuck grip and use a hammer to tap the grips. Hopefully this will free it up. It's not very elegant and you probably have already tried similar methods but it's the best idea that I have. Also you could soak the chuck portion in penetrating oil (chuck submerged only) overnight. Good luck!
Mar 01, 2010 | Dewalt 18v 1/2" Compact Drill/driver Kit...
Hello. My DC728 keyless chuck took a dive. I had
the chuck is screwed also to main shaft. counter clockwise to remove.
Nov 28, 2009 | Drills
I have a DCD940KX 18v Dewalt drill driver with the one click drill chuck. It does not keep drill bits or screwdriver bits from spinning. They spin with the slightest bit of pressure on them. My questions...
this is not a common problem with dewalt. I have been using them in my construction business for years and only heard of this once or twice. I would go to their web site and get the number for their customer service. They stand behind their products and im sure they will help in every way they can to repair the drill
Nov 26, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Can't remove the chuck retaining screw.
The screw is a LEFT HAND THREAD and also is LIKELY a Metric size!
Make sure you use a Metric Allen wrench.
Jul 08, 2009 | Makita 6408K 3/8" Variable Speed,...
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool Logo
328 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
