Question about LG LRBN20510WW Bottom Freezer Refrigerator
Black refrigerator finish
I bought a new LG black fridge in the Fall. I made the horrible mistake of putting a rubbery "fake blood" on the front at Halloween. The blood came right off but left an oily looking mark where it was all the way across the top of my fridge. I have tried everything to get rid of the spot and now the front is loosing the gloss look and has swirls in it. I am so upset! Anything out there that I can use to get it glossy again?
Thanks
Claire
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Not sure if this will work but you can give it a try. Get a hair dryer and heat the area. Hold it away from it though and see if it works. It is worth a shot.
Sgt 48
Posted on May 31, 2008
How to replace the front control board on an LG LFX31925ST
if you retained the OWNER'S / USER'S MANUAL , the removal instructions for that particular part can be found in there . if you can't find them in there let go of your MOOLAH . put aside your DIYship which could result in more expenses for you. call people who are trained in such job. thanks.
Aug 01, 2012 | LG LFX31925ST Stainless Steel Bottom...
Screen is dark and pixalated
If u have warranty means then claim it.................
Jul 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Tip
U-Line 75R: Replacing Thermostat when unit will not run
<span>I am reposting <b>Don Willis's</b> EXCELLENT but hard to find tutorial on how to replace a thermostat on a <b>U-line 75R</b> as a HOW-TO Since he spelled "refrigerator" incorrectly (Refidgerator), </span><span>Google cannot find it easily! I followed these instruction and finished in about an hour. </span> <span><br /></span> <span>Got the thermostat part on eBay from a venfor called Part Peddler.</span> <span>The U-Line part number is 2766-S, cost me about $30,shipped.</span> <span><br /></span> <span>Don's post follows, my comments in {} brackets: </span> <span><br /></span> <span>The light worked so it was getting power. </span> <span><br /></span> <span>I used an electrical tester (pencil like device I bought at Lowe's) to figure out that power was making it to the thermostat (black wire) but not after the switch (blue wire). </span> <span><br /></span> <span>To change the thermostat. </span> <span><br /></span> <ol> <li><span>Take covers off the front bottom (one flathead 1/4" hex screw) and back panel (about 10 flathead 1/4" hex screws) of fridge.</span></li> <li><span>Unscrew the old thermostat (2 screws). Leave black and blue wires on it so you will know where to put them on the new one.</span></li> <li><span>Take out glass shelves on inside. Unscrew back panel {note: there are spacers that will fall out} . There are 2 phillips screws {on nuts} that hold the end of the thermometer to back panel. {I removed one and loosened the other to free the "coil" thermostat) reach hand under the back panel and feed the thermometer back through hole and out back of fridge. You will notice a putty like substance that fills in the hole in the back where the thermometer gets fed through. Make sure you keep it to fill in the hole in the back. </span></li> <li><span>Feed new thermometer {coil} end through hole in the back {I found that using a Phillips head screwdriver to guide the coil through was useful} and install to back panel {using those two Philips screws and nuts}. </span></li> <li><span>Put the putty back in the hole from the back to insulate around it. </span></li> <li><span>Feed the electrical end of thermostat through bottom of fridge</span></li> <li><span>Take the wires off the old one and attach to the new one. </span></li> <li><span>Attach the thermostat to its mounting location </span></li> <li><span>Reinstall all the screws in the front and back and you are in business.</span></li></ol><span>Had a hard time finding someone to service it. They wanted $200 to come out to the house + parts and labor. The new thermostat cost $33 at All Brand appliance. I am from Mass and picked it up in Brockton. I emaile dU-line and they sent me the new part number. The allBrandappliance site had the old part number (2766-s) I am notan electrician and this was a few hours work.</span>
on Apr 10, 2011 | U-Line 75R Refrigerator
I have a Hotpoint HSS25GFPH white side by side refrigerator. We're buying a new house with black appliances. I don't want to buy a new refrigerator so I'm contemplating painting the whit
Paint? unless you have a spray booth, and are good at such things, I would avoid that...
I would go with a vinyl or similar adhesive sticker. There are companies that do whole fridge front stickers with artwork/nature pictures etc. Google "refrigerator stickers" and you might find one that will do, just plain black.
Apr 24, 2012 | Hotpoint HSS25GFP Side by Side...
Everything in and outside our fridge is getting a black soot on it?
This sounds dangerous, I suggest you hire a pro to look into this.
Nov 21, 2017 | LG LFX25971ST Bottom Freezer French Door...
How do I change the water filter in the refrigerator?
down in the front grill at the bottom of the fridge you will see the filter and just the the left of it you will see a button. push the button in and that will pop the filter out a bit. pull it out and put the black cover that was on your old filter and put on your new one. then just push it in
Mar 26, 2010 | Whirlpool GC3NHAXVY Stainless Steel Side...
Our new Samsung fridge has horrible tasting water
add water filter system to the unit ..
if it is not the water from the unit that bad then filter change might need to be done...or a new filter need to put inside.
Dec 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer and fridge tempeture increasing.
The black " tank " is the compressor . Will the fan by the compressor run ? If not , that is the problem ( fan motor ) . Are the coils clean of dust , lint , pet hair , etc ? The brand and model number would have helped . Since the compressor is hot , means it should be good . The fan motor must be working , to help keep the compressor cool . Also , the back cardboard or metal panel must be in place when finished , or the fan will draw outside air instead of front air over the coils and compressor .
Aug 30, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Black pearl fridge finish
Goo Gone made bt Magic american corporation it uses citrus to remove the tape.. for everyday use whirlpool makes an Appliance cleaner that work great..
Sep 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LRBN20510WW Bottom Freezer Refrigerator Logo
62 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
