How to back up my hard drives and create a boot up disk
  • 32,281 Answers
You can make an image of your hard disk and copy it to a CD, use this to restore your computer.
There several programs that can do this.
I like Nortons Ghost. If you prefer something else do a Google search for this type of programs.
Posted on Oct 06, 2010
Need a new hard drive but have no windows vista disk
You don't.
Do you have backup software? If so, do a "disk and partition" backup. This essentially creates an image of your system, even if you have multiple hard disks. Decent backup software (I won't mention any brands except the one I use: Acronis) will allow for a boot time recovery of your entire system, either by inserting a post-bios command -- which will appear on your screen before windows startup with a message like "Press F12 for system recovery", or you should press whatever key your system allows for boot order and boot from the recovery disk you can create from the software.
You can even now immediately create a Windows backup to an appropriately sized USB mounted disk (even the terabyte ones are relatively cheap) and a Windows Recovery Disk...the recovery disk should be inserted and use boot order F-key...good luck
Dec 28, 2013 | Gateway DX4200-09 PC Desktop
Tip
Restore win 7 from system image on toshiba portage m200
This should apply to other brands and models...
the original problem: bad hard disk, need to restore from win 7 image disks however The portage m200 lacks an optical drive and cannot be booted from usb (only options are to boot from LAN or from a specially created SD card).
Solution:
you will need a second pc that can boot from an on board or peripheral optical drive. Swap the second pc's hard drive for the one that you are restoring. Now boot the second pc from the restore disk and follow the onscreen instructions. Once completed the pc will try to reboot and you will get an error about how windows couldn't repair start-up. Now power down and swap the hard drive back to the portage. You should now be up and running, much easier than trying to create a boot-able sd image or boot from a PXE server.
on Oct 10, 2010 | Toshiba Portege M200 Tablet PC
Dell inspiron mini screen says "bootmgr is missing
You need to reboot the computer using the disk you made from Windows Backup and Restore. Watch your boot screen and look for "boot opions or boot order (words to that effect).
If always super important to create a Windows Startup Disk/Repair disk as soon as you power on your computer and go through the initial setup.
The next most important task is to create recovery disks. The ultimate task for any laptop or desktop computer is to create a system image backup onto an External Hard Drive. Why? Whenever you get infected or experience a major problem you are copy the system image back to your main drive and everything is in the state it was when you made the backup.
Files should be backed up on regular basis and having an External Hard dDrive always plugged into a USB port makes this a very simple task.
Apr 15, 2013 | Computers & Internet
How to completely erase the hd
A hard drive is the brain of a computer. However, over time, that brain can become overworked and overly saturated with old software and outdated information. It becomes clogged and needs a fresh start. By erasing a hard drive, you can give your PC that fresh new beginning. With a few steps you can erase your hard drive manually, without the aid of expensive software.
Make sure your data is protected before you proceed. Whatever you do not save will be lost once you erase the drive. Use a CD or jumpdrive to save your information. Boot with a system disk. Before you continue to erase the hard drive, use the system to create a system disk. Use a 3-1/2 inch floppy disk and format it with the command "format a: /s"; this will create a bootable disk that contains system commands. Place it in the drive of your system and turn it off, then back on. Reformat the hard drive. Once you've booted with the system disk, type "format c: /s"; this will reformat the hard disk, virtually destroying the old hard drive you used to know. Depending on the of the drive, the formatting may take a fairly long time. Once the formatting is over, use the command "fdisk" to create partitions (which are logical sections for your hard drive's storage). Given the newer hard drives and operating systems of today, you can fdisk the drive and use all of the space. or if you dont have a floppy drive Download a disk wiping utility, such as Darik's Boot and Nuke (DBAN) or KillDisk. DBAN is an open-source product, while KillDisk is available as a free, closed-source download. http://www.dban.org/ http://www.killdisk.com/ Once you download the file, save it to your computer somewhere easy to remember. Insert a blank CD into your computer and use a CD writing program to burn the hard disk wipe utility to the blank CD. If you are using Windows Vista or 7, there is a built-in utility that will perform this task. Back up the data on your computer that you want to save, if necessary. Insert the CD that you created into the computer that is attached to the hard drive you wish to erase. Power on the computer and choose the setup option to boot from the CD. Once you have booted from the CD, you will enter into the hard disk wipe utility. Depending on which utility you chose to use, this screen will vary, but the choice you want to select is to erase or wipe a disk drive. Choose the hard disk that you wish to wipe and confirm that you wish to permanently erase the data on it. Before confirming this, you may wish to physically double check and ensure that you are erasing the correct drive. Once you start the erasing process, it cannot be halted, paused or reversed. You will have to wait for anywhere from a few hours to even a few days for the process to complete, depending on how large your hard drive is.
or you could just reinstall another operating system this will automatically delete the old wrong one you installed.
Hope this helps.
Jan 02, 2013 | Western Digital WD Scorpio Blue WD5000BEVT...
My acer aspire 5538G won't boot, i get a message saying error PXE-E61: media test failure check cable PXE-MOF exiting broadcom PXE ROM operating system not found.. and i am unable to use disk to disk...
Your computer is attempting to boot over the network (something that only works with a server on the network) PXE E61 Media Test Failure Error
You can get this message if the boot device order is wrong in your computer (go into bios and check) but more often, the computer has tried to boot from the hard drive and dvd and failed before trying to boot from the network. It sounds like the hard drive has been failing for a long time and is now so bad the disk to disk no longer works. Replace the hard drive and reinstall using the recovery DVDs you created. If you didn't create them, you may have to contact Acer for a set.
May 05, 2017 | Computers & Internet
Hard disk not aacept formet
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
this will erase you operating system you have to have a operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
Dec 03, 2010 | Samsung SpinPoint V80 SV0802N 80 GB...
How do i reformat my pc?
This is a pretty drastic process and takes several hours. If you have system slow downs and ongoing bugs you may be able to repair with software tools (see here), however that said, on with the show.
The procedure will decimate the data on your C: drive, so it's crucial that you back up all the data you don't want to lose.
Don't forget items like e-mail data and address books (see: How to backup e-mail.). Back up all your documents including your "My Documents" folder and all the data you've stored on your Windows Desktop which you'll find in c:\Windows\Desktop or c:\Windows\Profiles\<yourname>\desktop, where <yourname> is your Windows log-on.
Don't worry about backing up programs that you can reinstall later, unless you want a complete backup of your C: drive in the event of a problem.
Now, create a boot disk. Creating a Windows 98 boot disk is easy. If Windows 98 came factory-installed with your machine then one may have been supplied with your documentation. If not, you can create one through the Control Panel. In Windows, go to Add/Remove Programs and click the "StartUp Disk" tab and click the "Create Disk" button. It will create a boot disk on a blank floppy for you with CD-ROM support.
This is important, as you'll need access to your CD-ROM drive to do a new Windows98 install.
Once the boot disk is created, test it to see if you can access your CD-ROM drive. To do this reboot the machine with the floppy disk in the floppy drive and when the machine restarts choose "Start with CD-ROM support".
At the prompt type d: and hit the Enter key. If the machine responds with D:\> you are in business.
Next type "format c:" without the quotes (and hit ENTER).
The C: drive (main hard drive) will then be wiped clean.
Once the reformat is finished put your Windows CD-ROM disk in the CD-ROM drive, and type "D:\setup" at the prompt.
Once Windows is finished installing, reinstall your backup software and restore your data to the hard drive.
And Thanks.
Mar 05, 2010 | Microsoft Windows 98 for PC
Error in loading Operting System
you can download and create a "repair" disk that will be able to scan your hardware without the need of windows. click here to download the disk, unzip it and create a disk.
follow the directions in the setup menus.
from the sounds of it your boot sector has become corrupt
good luck
Mar 12, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jaddude
Jan 07, 2009 | Dell Latitude D600 Notebook
New 160 gig hard drive, can't load XP on Fujitsu S6210
Insert the new hard drive in your laptop, boot up and go into the BIOS.
Check if the hard disk setting is set to Auto (detect). Check the system configuration and see if it detects the hard disk.
If there is a hard disk diagnostic utility within the BIOS, run it to check the hard disk.
You can also test the hard disk by booting up with a boot floppy disk, run fdisk.exe to see if can display, create a partition, and format the hard drive etc.
If not of this works then it is highly possible that you have a faulty disk controller in your laptop.
Dec 18, 2008 | Fujitsu S6210 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
