Question about Apple iPod nano
Ipod Button issues
The sensativity of the buttons on my ipod is starting to worsen. Often I have to press any given button half a dozen times to get it to work. Please advaise.
  • 8,596 Answers
I also am experiencing this problem with this player. Mp3 players are not yet instantaneosu devices - there is still quite a bit of lag time between when you press a button and when it responds; part of this cannot be corrected. The best thing to do for now is to reset the player, and don't press the "backwards" button especially too many times in a row. Backwards and forwards work better when the song that is currently playing is paused.
-Tha Mp3 Doctor
Posted on May 28, 2008
I've removed the cable from iPod to soon from a sync .... now ipod has frozen and nothing is working on iTunes at all
You need to Perform a Hard Reset on iPod Classic..To perform an iPod hard reset , start by toggling the hold switch from off to hold, then back off again. Press and hold down the Center button (middle of click wheel) and the Menu button. Continue to hold these buttons down until you see the Apple logo on the iPod screen (approximately 6-8 seconds).
If the hard reset doesn't work the first time, try it again a couple more times. Sometimes it works the second or third time around.
If the iPod hard reset is still not working, try connecting your iPod to a power source, or computer, and then doing the hard reset.
*For older iPod models, you may need to hold down the Play/Pause button and menu button, rather than the Center button and Menu button...Take care..
Sep 10, 2017 | The Audio Players & Recorders
Frozen forgot password
Press and hold the top button until the iPod Touch turns-off. It may display the "slide to turn-off" notice, but ignore this and continue to hold the top button until the screen goes black.
After this, release the button and then again press the top button and the home button at the same time briefly to start your iPod Touch.
It will take much longer than usual to start up when starting after a reset like this. After the restart after reset, your iPod Touch should work normally.
Jan 03, 2012 | Apple iPod touch
Help my ipod touch is a 16gb n older version and its gt 5808849 minutes left. what cn i do?
Have iTunes open and your USB cable plugged into the Computer "BUT NOT THE iPOD"!
Turn the iPod off- Press and hold the sleep/wake button at the top left corner for approximately 10 seconds until the screen says slide to power off.
Force into recovery mode Press and hold the home button (in the front on the bottom) for approximately 10 seconds until you get the image of a USB cable pointing towards the iTunes logo on the screen. If you do not get this, try holding the home button down and at the same time plugging the other half of the USB cable into the ipod waiting for a message in iTunes
Follow instructions in iTunes Once you plug the iPod into the computer, you should get a message saying "iTunes has detected an iPod in recovery mode, it must be restored to be used." At this point you hit the restore button in iTunes and wait for the iPod to be restored
Apr 03, 2011 | Apple iPod touch
How to defreeze an ipod and how to make the computer recognize the ipod?
Make sure the HOLD switch on the top is in the "off" (unlocked) position i.e. the orange indicator should be hidden from view. If the iPod is switched on then try pressing and holding down the play button on the clickwheel for a few seconds and see if it switches off. If it is now switched off, press and hold down BOTH the centre button and the menu button on the clickwheel for about 10 seconds. Try this a few times and if it still doesn't resolve the issue, connect your iPod to the data cable onto your PC/Laptop and start iTunes. You can then use the RESTORE facility within iTunes to return your iPod to its factory settings. WARNING! This will remove any existing tracks you have stored on the iPod.
Oct 19, 2010 | Audio Players & Recorders
My iPod Touch is speeding up, downloaded podcasts are starting to sound like a chipmunk cartoon. Any ideas?
With podcasts on the ipod touch you can vary the speed of play. From normal speed to 1.5 times, 2 times and half speed. Just under the play indication is a button which is probably reading 1.5x or 2x press this button and you will be able to change the speed back to 1x. Hope this helps.
Mar 26, 2010 | Apple iPod touch
I don"t have the 4 digit code for Ipod Touch 16GB and can't use
try following the solution step by step as it is a couple of times if it didn't work for the first time.
Sep 03, 2009 | Apple iPod touch
Frozen
Start by resetting the iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
If this does not work to resolve your issue, please do let me know :)
Jul 02, 2009 | Apple iPod nano MP3 Player
My ipod 30gb saw sitting for a long time and it will not start
Look for a reset button on the IPOD, if there is one then press it. Charge the IPOD fully, then press the reset button again and it should start up...
Jun 03, 2009 | Apple iPod MA446LL/A MP3 Player
My ipod doesn't loads the data and also it doesn't connects to pc
First, I would start by attempting to reset the iPod. Below I have posted a step by step on restoring an iPod just in case you need the information. If for any reason at all this does no resolve your issue, please do let me know :)
Apr 15, 2009 | Apple iPod nano 3rd Generation
Ipod is frozen...will not even connect to the computer.
Try this which should reset your ipod: First, toggle your hold switch back and forward and put it back to the off position. Then press and hold the menu button and the center button simultaneously for about six seconds and the screen should go blank and the apple logo should appear. After that it should work.
Feb 16, 2009 | Apple iPod classic MP3 Player
Apple iPod nano Logo
20 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
