Each time I enter a dvd into the tray after a few seconds it opens the tray and says on screen no disc ?
  • Televison & ... Master
  • 17,130 Answers
Possible failure of the optical head unit assembly
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked, but the best is to clean manually the laser head eye with a cotton bud, do it very softly and without any pressure of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
But if any of the above seems otherwise we must recheck with possibilities of the processor board
Posted on Oct 06, 2010
My dvd player tray does'nt open when it should and when i insert a disc to play, it only plays for a few seconds then it stops but the disc continues to spin
Hello
The laser pickup unit of your DVD player may either be faulty or dusty. Just put in a cleaning disc into it and play it for at least three times, and check. If it does not help you, the laser pickup unit of your device should be replaced with same type and number. Just check the loading belt too. OK.
Dec 16, 2011 | Zenith XBV443 DVD Player/VCR
Tip
INITIALIZE THE DVD PLAYER -FIRMWARE UPDATE
FIRMWARE UPDATE
1. Turn the power on and remove the disc on the tray.
2. To put the DVD player into version up mode, press [9], [8], [7], [6], and [SEARCH MODE] buttons on the remote control unit in that order. The tray will open automatically.
The DVD player can also enter the version up mode with the tray open.
3. Load the disc for version up.
4. The DVD player enters the F/W version up mode automatically. If you enter the F/W for different models, "Disc Error" will appear on the screen, then the tray will open automatically.
5. After programming is finished, the tray opens automatically.
At this time, no button is available.
6. Remove the disc on the tray.
How to Eject Manually
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Jan 19, 2016 | Denon DVD-1740 DVD Player
How to make my Samsung HT-BD8200 region free?
1. Open the disc tray and remove any discs
2. Close the disc tray
3. Switch Off Player and Unplug from mains wait minimum 30 seconds - this resets the memory, and RAM of the DVD/BlueRay
4. Make sure your TV is on as usual, and Reconnect to mains
5. Turn on your DVD/Blueray player with remote and wait for the "no disc" message to appear
6. PS! As quickly as possible, using your controller press - ENTER 8 4 2 6 9 ENTER
7. You have been successful when a blue box appears in the top left-hand side of the TV Screen, displaying the message "DVD Region Free"
You may have to attempt the "ENTER 8 4 2 6 9 ENTER" sequence several times before you get the Region Free message if you're not quick enough.
May 08, 2011 | Samsung HT-BD8200 Theater System
I have a DVD Recorder, Lite-On LVW-5005X. I have been having sporadic problems with the disc tray not opening for some time. But usually after repeated attempts, it would open. I have recorded and...
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Dec 10, 2010 | Lite On LVW-5005X DVD Recorder
Need unlocking code to make region free for lg dr4812w
Open Tray.
Press '0' 7 times.
Region Free message comes up. Press Enter to select 'Yes' and the machine is now Region Free.
OR
Make sure there's no disc in tray.
Open tray.
Press ENTER.
Press 0-0-0-0.
Press Pause.
Turn Off.
Wait five seconds.
Turn on.
Jul 04, 2008 | Televison & Video
Unlock Code
http://www.digitalfaq.com/downloads/dvdhackarchive/lg5000.zip
Unpack the zip file and burn the folder to a disc.
I used Nero...
1. Burn the folder 'RMTM0000' to a CD-R making sure that the directories stay in order.
2. Insert the disk to your player
3. It loads..... After a few seconds it opens the tray
4. And a Region Select menu will come up.
5. Press "0" on the remote for multi-region. Then press the pause key (or maybe the enter key).
* Region 0 MUST appear in both of the definitions on screen
OR
Power on
wait "no disk" to appear
open tray
press 0 four times
"region edit" and "region code" appear with the default code
press 0 for region free
enter
"region code" should now be 0
pause
power off
Jun 30, 2008 | LG Televison & Video
Heed to unlock an samsung dvd ht-x30
1. Remove Disc from Tray.
2. Switch Off Player
3. Wait 30 Seconds, Then Reconnect Mains.
4. Turn On player with Remote Control. Wait for player to Finish Loading and Display 'No Disc'.
5. Press Enter on Remote Control. (There will be No On-Screen Response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be No On-screen Response.)
7. Press Enter on the Remote Control. Player will Automatically Turn Off.
8. Turn Player On.
9. Open Tray
10. Close tray.
11. Turn Player Off then On Again.
12. Player is Now Region Free
May 05, 2008 | Televison & Video
Won't recognize disc-cd or dvd
The pick up or in other terms laser is faulty if its not under garrentee start by opening the tray and clip of the tray`s cover open the writer and clean the lense with a ear bud and then test it if no response it gets more technical or its time to replace, i hope these tip help you
:)craig
Jan 09, 2008 | LaCie 300722 DVD±RW Burner
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
