Question about Fujitsu Siemens (MHT2040AS) 40 GB Hard Drive
What is the precise maximal minimal and average transfer rate in MB/s of Fujitsu MHT2040AS YTTN manufactured 2004-04
    Problem Solver:
  • 18 Answers
Here is the specification sheet on the HD:
http://www.fujitsu.com/downloads/COMP/fcpa/hdd/mht_datasheet-ext.pdf
Answer is: Tested at 100/MBs, your speed may vary.
Posted on Oct 06, 2010
How to minimize and maxmize the window with the keyboard
minimize - press ALT, SPACE, N
maximize - press ALT, SPACE, X
Oct 02, 2010 | Computers & Internet
Tip
Close All Windows Programs instantly
A cool tip to minimize and maximize all your active windows programs. You can do all using your mouse, but if you want to do this with keyboard then simply press Windows key+M to minimize all active programs and later maximize it using Windows key+Shift+M.
If you want to minimize the all active windows programs one by one then use the shortcut by pressing Alt+Space+N keys and sequentially maximize the active windows programs using shortcut Alt+Space+X keys.
on Jul 07, 2010 | Computers & Internet
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
HOW MUCH RAM WILL IT SUPPORT
This model has two memory slots, it has 512 MB in one of the slot. The maximal memory to support is 1GB for each slot and 2 GB total.
CompQ
May 11, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
What type of drive is st380011a is called
This drive is an Ultra ATA drive. It requires an IDE connection to the motherboard.
Here are the specs:
ST-380011A
Barracuda 7200.7
FORMATTED CAPACITY (GB) __________________80
ACTUATOR TYPE ____________________________VOICE COIL
CYLINDERS __PHYSICAL______________________
HEADS ______PHYSICAL______________________2
DISCS (3.5 in) ___________________________1
MEDIA TYPE _______________________________THIN FILM
HEAD TYPE ________________________________GMR
RECORDING METHOD _________________________EPRML 16/17 ZBR
INTERNAL TRANSFER RATE (Mbytes/sec) ______up to 85.4
SUSTAINED TRANSFER RATE (MB/sec)__________up to 58
EXTERNAL TRANSFER RATE (Mbytes/sec) ______up to 100
PIO/DMA/UDMA MODE (max) __________________4/2/5
SPINDLE SPEED (RPM) ______________________7200
AVERAGE LATENCY (mSEC) ___________________4.16
BUFFER ___________________________________2MB
Read/Write Multiple, Read Look-Ahead,
Multi-Segmented
INTERFACE ________________________________Ultra ATA/100
SECTORS PER DRIVE (LBA mode) _____________156,301,488
TPI (TRACKS PER INCH) ____________________94,600
BPI (KBITS PER INCH) _____________________up to 595,000
AVERAGE ACCESS (ms seek/read/write) ______/8.5/9.5
SINGLE TRACK SEEK (ms seek/read/write) ___/<1.0/<1.2
MAX FULL SEEK (ms seek/read/write) _______//
MTBF (power-on hours) Office _____________600,000
SHOCK (G's, 11ms/2ms):
operating (Read/Write) __________/63
abnormal ________________________
nonoperating ____________________/350
ACOUSTICS (bels)
fluid bearing (typ/max-quiet/max-perf) _<2.2//3.5
POWER DISSIPATION (watts) ________________
POWER REQUIREMENTS: +12V START-UP (amps) _2.8
POWER MANAGEMENT (Watts):
ACTIVE _______________12.5
IDLE _________________7.5
STANDBY (typ/max) ____0.9/
Mar 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I need to know what kind of hard drives and other hardware i can use with a HP Compaq D530 Socket 478
HERE shows an overview of the specs for the HP d530 series. Shows IDE type HD's.
Technical Specifications - Hard Drives
7200 rpm SMART III Ultra ATA/100 Hard Drives 40-GB Capacity 40,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 78,165,360 Operating Temperature 41° to 131° F (5° to 55° C) 80-GB Capacity 80,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 156,301,488 Operating Temperature 41° to 131° F (5° to 55° C) 160-GB Capacity 160,000 MB Rotational Speed 7200 RPM Interface Ultra ATA/100 Height 1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including setting) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 320,173,056 Operating Temperature 41° to 131° F (5° to 55°C)
Feb 21, 2010 | Computers & Internet
My laptop has problem with viewing folder..when i open the folder it maximize and minimize by itself.( like blinkin)continously nonstop..i cannot open my document, my computer even control panel
You have a virus or trojen, download Spybot "search and destroy" and run it , It's a donation based site that's been around as long as the net, It doesn't sound like a bad one, but they can cause damage if left untreated. Also update and run your Virus program.
Apr 09, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
Xp audio driver for fujitsu amilo
Downloads results for AMILO La 1703 CLICK HERE FOR AUDIO DRIVER
CLICK HERE FOR SUPPORT PAGE AND ALL THE DRIVERS
VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed)
Title: VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed) Date: 04.10.2006 Size: 7,17 MB Version: 5.10.01.1080 Manufacturer: VIA Technologies Status: Released for AMILO La 1703 Language: all.gif Supports all languages Operating systems: [Supported] Windows XP
[UnSupported] Windows XP Media Center Edition (WHQL)
Minimize up.gif Use in the following products: minus.jpg AMILO La 1703
Jul 03, 2008 | Computers & Internet
Maximizes & minimizes screen while scrolling or using pointer on Vista
change mouse out buy replacemnt goes under the plastic housing not to bad to change 20 bucks on ebay
Feb 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Transfer Rate is LOW!
If you?re getting odd noises coming from the hard drive you may be suffering from read errors. Windows has a utility called chkdsk that can test the hard drive readability and perform repairs in some cases. -Click on Start, then Run. -In the Open field enter ?chkdsk /f /r? and click the OK button. -You will be prompted by and error that chkdsk cannot run but will ask if you want to schedule it to run the next time the system restarts. Enter ?Y? . -Restart your computer, -Chkdsk should run after your system reboots. It will check the integrity of your hard drive and ?repair? any spots on your hard drive it can?t read. Actually what it does is move the data in the spots it can?t read and then marks the spot so that Windows does not use them in the future. The process should take a couple of hours, depending on how much information is stored on it. Let us know what you find and don?t forget to rate this posting.
Mar 04, 2007 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
Fujitsu Siemens (MHT2040AS) 40 GB Hard Drive Logo
338 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
