Question about Kettler Stockholm Outdoor Table Tennis Ping Pong Table
What are the faults in table tennis? - Kettler Stockholm Outdoor Table Tennis Ping Pong Table
Need to order replacement parts for prince fusion table tennis
How can I order replacement parts for my Prince Fusion table tennis table (PT4200S)?
Sep 13, 2013 | Prince Fusion Table Tennis Table
How do we close 1 1/4" gap between two sides of table
You probably have either (a) not properly extended the legs all the way, or (b) have attached some of the cross beams on the wrong side.
http://www.sears.com/prince-fusion-table-tennis-table/p-00601215000P
click on this link and you can move the magnifying glass over different parts of the picture to see up close what the table should look like in the correct and finished position.
Dec 15, 2012 | Prince Fusion Table Tennis Table
Need directions on how to put table tennis together
I suggest you contact Franklin Sports directly and ask them to send you assembly instructions. Here's how you can do so: http://franklinsports.com/franklin-sports/contact-us/
Oct 09, 2012 | Franklin Sports 2288 Deluxe Table Tennis...
When was table tennis (ping pong) first introduced to the Olympic Games?
Tabletennis was first introduced in the 1988 Seoul Olympic Games in South Korea.
Aug 05, 2012 | Sport & Outdoor - Others
Is there a difference between ping pong and table tennis?
No,they are the same thing. Until the early 1900's, it was called ping pong andthen the named officially changed to table tennis.
I'm in my 50's, can I start playing table tennis?
Definitely! You should know that Table tennis is asport for all ages, and it is never too late to get started. You should know that in the year 2008, Olympic table tennis canbe called the Veteran Year as 38 year old Gao Jun and34 year old **** Chendirectly qualified for the 2008 Beijing Olympic Games on the women's side. Andon the men's side, 45 year old David Zhuangwon the right to attend the Olympic Games as the USA' sole male representative.
Jul 09, 2012 | Sport & Outdoor - Others
How can I find a table tennis coach?
You can search for a coach in this list: http://www.usatt.org/coaching/coaches_list.shtml they are all members in the USATT (usa table tennis association) and you can find them by state.
How do i restore the surface of my outdoor ping pong table
Use painters tape to cover the white lines of your table tennis table.
Use sandpaper (150grit) to smooth the surface. This will level any bumps or scratches. Fill deep cracks with wood filler, let it dry and sand the table again.
Make sure that the table is clean before you begin the painting procedure.
Use chalkboard spray paint about 8 inches away from the table and spray each side. Allow 8 hours for the paint to dry then repeat with another coat. Next day, repeat the process so you have 3 layers of paint. Chalkboard spray paint helps the ball bounce to the correct height and speed.
Remove the painters tape after the last coat and allow the table to dry for at least 24 hours.
Hope this helps, vote me if so :)
Jun 30, 2010 | Kettler Stockholm Outdoor Table Tennis...
Kettler tennis table has rusty legs, one is very bad
To stop this much rust - go to any hardware store and buy (I forget the exact name) a "paint" called Rust Stop. It will stop the rusting and turn the existing rust into a hard black surface that you can then paint.
Apr 02, 2009 | Kettler Stockholm Outdoor Table Tennis...
Kettler Stockholm Outdoor Table Tennis Ping Pong Table Logo
162 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
