Hi Friends, I'm using Blackberry 8520 Mobile .. Before working my mobile "Whatsapp" but now not working come to this message "verification requires a working wifi or cellular data connection but we couldn't find either one" What problem please help me..
Hello, I think your Blackberry cell phone is locked to a specific network you need to unlock it,You can get unlock code at cheapest rate by BLACKBERRY CURVE 8520 UNLOCK CODE provider. *Visit BLACKBERRY CURVE 8520 UNLOCK CODE
Is this also a new SIM card in the Curve or did you use that sim in other phone before? You need to be sure you have the CLIP service active on your sim card. CLIP service is feature that can identify the number of an incomming call. If you are sure and if you try and put the sim card to another phone and you can see the infoming call numbers, look in the settings menu - call settings and make sure all "call identifier" submenus are active.
Possibly you have no contacts save or stored on your phone. Pleas copy contacts from your sim by
Go to Contacts.Press the Menu Button ( which acts like right-click )Select Sim Phone Book. This will list out all the sim contacts.Click the menu button.Select Copy to all contactsAfter those steps try to ask someone to call you to see if the incoming calls are named. Hope this helps.Thank you for Using Fixya
hi jenny202 You need to go into the phone section hit the bb menu key and set the display to all . Also if yout using a gmail on the phonr iy will sunc your contacts to your gmail and not sidplay then on your phone. You will need to look at the the settings .
Hi, There are two methods for unlocking Blackberry8520 by MEP number and by IMEI#. The simplest method for unlocking by IMEI#. You can find your Blackberry 8520 IMEI number by follow one of these steps.
1.By Pressing *#06# into the phone. 2.On your Blackberry cell phone, go to Options-->Status. 3.put the battery out,there should be a white sticker it will show your Blackberry IMEI #.
Enter http://blackberrymep.com and follow instructions there, it's the best solution for unlocking your blackberry, it's easy, fast, cheap i have tried many other methods, but i found it the best.
