AIR DRYER MODEL ENL-5-VARIO HOW DO YOU SET THE TIME AND DURATION ON THE DRAIN SOLENOID VALVE
5 Suggested Answers
SOURCE: Maytag MLG23PD Gas Commercial Dryer
605 5 quarters to start 712 12 minutes per quarter if yu want 1 quarter to start dryer change to 601. if yu want dry time to be 8 minutes change to 708 press whites and colors to select value and then press permanent press to go to next code.
Posted on Mar 25, 2009
SOURCE: new solenoid drain valve for cleveland steamer
The correct cleveland part # for your valve is 22221. If you have the correct valve there should be no extra ports. The steamer will flush itself when you turn it on, and periodically if there is the optional blow down timer installed. Hope this helps
Posted on May 04, 2009
  • 20 Answers
SOURCE: Kenmore model 665.17609300 type
Check your air gap on your drain. It should be located on or around your sink. Sometimes food and other trash will stop it up and will not let your dish washer drain. The cap should unscrew off .Good Luck.
Posted on Aug 13, 2009
ercupa190
  • 12223 Answers
SOURCE: Hobart Sr24h drain valve solenoid constantly
see the wirin diagram for test and see how to test:
Posted on May 09, 2012
How do you remove the drain valve?
About 687,000 results (0.87 seconds) Search Results
    Washer Drain Pump Replacement (Part #3363394) - YouTube
    ? 3:15
    https://www.youtube.com/watch?v=DwV71h86Gxw
    May 14, 2010 - Uploaded by RepairClinic.com
    Additional washing machine repair, troubleshooting tips, help with.... If you have this design of model then the pump we replace in the video .... machine is off or unplugged, the water valve is bad and will need to be replaced.
    How to replace a washer connection head - YouTube
    ? 3:30
    https://www.youtube.com/watch?v=2grrmHVDsCA
    Mar 26, 2012 - Uploaded by askthemaintenanceman
    A video on how to replace a washer connection head. ... washing machine shut off valve replacement , 1st time soldering ... HaveYou Ever Wondered What Is Behind Your Washer And Dryer Wall - Duration: 2:15. gregvancom 44,128 views. 2:15 ... How To Manipulate Washer Drain Pipes - Rough Plumbing ...
    Clean internal drain hose to help eliminate Front and Top ...
    ? 9:37
    https://www.youtube.com/watch?v=RUygUJGVP6E
    Dec 9, 2011 - Uploaded by Broit
    Smelly Washer Syndrome™ can be permanently eliminated soyou never have to ... Whirlpool washing machine drain pump replacement and ...
Jan 31, 2016 | Washing Machines
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
It does not drain water. Also smelt burning from the machine while washing.
Your drain valve solenoid burned up - the solenoid windings are shorted/burnt.
Fix: replace drain valve.
Aug 16, 2011 | GE Spacemaker Washer and Dryer Electric...
Doesn't drain from time to time.I am sure this has a pump,but can't hear it run.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Jun 25, 2010 | GE Nautilus 24" Built-in Dishwasher
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
Why won't water drain from tub?
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher will not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Control sector(This could be a timer module or control board)
Replace if defective (note: uncommon problem).
IF EQUIPPED, Check the drain solenoid.(Please disregard if your unit is not equipped with a drain valve)
The drain valve is typically near the motor although it can be located elsewhere. Look for a water hose running from the motor or underside of the tub. The hose should lead to the drain valve. The valve consists of the the gate arm mechanism and a solenoid (also called a coil). The gate arm allows the water to flow out of the dishwasher's tub through the drain valve. You should be able to move the gate arm up and down easily and smoothly. The gate arm also has two springs attached to it. If either of the springs is missing or damaged, they should be replaced.
The gate arm mechanism is engaged by the drain valve solenoid. The solenoid is connected by two wires. Label the wire placement on the solenoid before disconnecting the wires. The wires are connected with slip on connectors. Firmly pull the connector off of the solenoid's terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the solenoid for resistance using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 40 ohms when the probes touch the terminals. If the reading is infinity or substantially different from 40 ohms, the solenoid should be replaced asap.
Nov 16, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Water left in washer changed pump still happens
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Control Sector
GE Drain Solenoid Summery:
Nov 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
Champion vr3-8 auto drain blowing out when compressor turns off
IS YOUR TUBING CLOGGED, PINCHED OFF OR MAYBE DIRT-DOBBER NEST IN IT. THE WATER AND AIR IS SUPPOSED TO COME OUT THE SMALL TUBE POINTING DOWNWARDS BUT SOME EXCESS AIR MAY COME OUT THE SILVER VALVE ON TOP. THIS IS THE EXCESS AIR WHEN IT IS UNLOADING AND THE SILVER VALVE IS BASICALLY A TIMER. YOU CAN ADJUST THE DURATION OF THE BLOW DOWN TIME BY LOOSENING THE THIN JAM NUT AND SCREWING IT IN OR OUT. DO NOT BLOCK THE SMALL TUBING OR PINCH IT SHUT, YOUR COMPRESSOR CANT UNLOAD AND WILL START HARD. DONT REPLACE THE WHOLE DRAIN BECAUSE THIS AUTO DRAIN TAKES A REBUILD KIT THAT COSTS AROUND 20.00 TO 25.00 AND IS VERY SIMPLE TO REBIULD. YOU CAN CONTACT ME FOR PARTS, PRICING AND INFO AT JBRIDGERS@CA-EQUIP.COM OR WWW.CANDAEQUIPMENT.NET
Jan 15, 2009 | Air Tools & Compressors
Apr 19, 2008 | Maytag MLG23PD Gas Commercial Dryer
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
