Question about Gateway FPD1975W 19" LCD Monitor
Black screen Had a hydro blackout for 6 hours when, when I had restarted the computer and tried to turn on monitor I get a quick 1/2 second view of what looks like a test screen then the monitor goes black and nothing else. Is there a hard start for this monitor or a way to get this monitor to work again.
  • jagwyre May 29, 2008
    I took it apart last night and the ground in side was not hooked up at all.. So I hooked up the ground and pluged it back in to the wall and the same thing.. then just for the fun I tryed to hook it back up the my pc and on it came .. Weird I say
    I have a new card with 750gb vedio card.. and it is working good
    so who know..
    Sergeant:
  • 458 Answers
What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Sounds like an insurance claim.
Posted on May 29, 2008
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
ViewSonic VX1935wm Monitor says out of range
The problem is in the power supply inverter board, usually caused by bad capacitors, suggest a professional.
Mar 10, 2012 | ViewSonic VX1935wm LCD Monitor
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
I have view sonic VA1912WB 19'' black lcd monitor.. recently im acing problem with it..after i turn on the system the green light blinks and there is no display on screen.. after several(5-6)...
try another monitor on your system if you can barrow one somewhere to eliminate that it may be the computer... if it is the screen check the warranty on it at the view sonic web site... also check the cable from the comp to the screen to see if it is lose. try another cable or if it has hdmi dsub or dvi try those types as well. it may have a lose connector on the one your using...
May 20, 2011 | ViewSonic VA1912wb 19" LCD Monitor
Viewsonic VX710 Monitor scrren goes black
replace all caps on power supply board check values
should not cost more than 20 us. and 1 hour soldering
easy fix but new monitor goes around 100 us.
can you do it???
May 10, 2010 | ViewSonic VX910 19" LCD Monitor
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Blackout screen on computer monitor
Please try to check your VGA card placement to its slot, then check its cable connections, if still the same problem, try to connect your monitor to another PC & if it operates, then your VGA card is defective. regards
May 15, 2009 | Dell XPS Desktop with Intel Core 2 Quad...
Monitor screen blackout
check for any DRY SOLDER , specifically around the INVERTER TRANSFORMERS on the PC board . hope it helps
Mar 28, 2008 | Computers & Internet
Gateway FPD1975W 19" LCD Monitor Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
