Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
I have inherited a Bosch WVF2401. It doesn't seem to dry at all. Have been trying to dry small loads and after one hour washing still wet. Don't have a manual so have no idea which bits to clean out/check etc. Any help gratefully received. Thanks.
Noggin
  • 944 Answers
SOURCE: smelly washing machine!
The black cover you have removed should be the only "filter"/trap in the drainage system inside the machine. The eggy smell you described has to be caused by one of 4 things; 1. Smell coming back through the drain, indicating that there is no water trap - easiest way to check this would be to disconnect the drain hose from the wall, smell the drain and see if it is the same smell or not. if so, install a water trap, or arrange the drain hose in a loop to form one. 2. Decomposing organic matter in the wet system. There could have been something in a pocket or that accidentally got in with the laundry that has somehow got stuck somewhere - possibly in a filter but also limescale can trap dirt in the system and various items can get stuck in all sorts of places. This can be solved nearly always by running through the cleaning procedure described on this link; http://ezinearticles.com/?Cleaning-Your-Washing-Machine&id=109993 if it doesnt work the first time - try it again - sometimes it can take a couple of tries but nearly always works great. there are also stronger chemicals than vinegar that you can use to clean the machine with, (but they should only be used in extreme circumstances as other components can be degraded) white vinegar is usually all you need. To remove the vinegar smell afterwards if necessary - put a teaspoon or two of baking soda through the machine on an empty hot wash. 3. Decomposing organic matter in the dryer outlet duct (or possibly in the lint filter area, but unlikely, also possibly under the machine up inside where the workings are) - rodents and insects and moss and funghi etc all love the warm moist air that comes out of the dryer and they always can find a way into the duct - something dies or poops in the duct and the smell can be unbearable - easy way to check this is to look in the duct if you can, and see if the smell gets worse if you have the dryer on. Clean the duct out with mild dilute bleach if this is the problem. 4. Some liquid detergents cause a build up slowly in the system that smell quite sewage-like (possibly some powders too, but not so common) - try cleaning out the machine and switching to a different detergent to check if that's the case. Unfortunately the Bosch website manuals page is down today - they will have a manual for your model almost certainly - it is an excellent site; http://www.boschappliances.com/site_tools/documents.cfm try again in a day or two - and you should get a user guide downloaded. An overheating motor is unlikely to be the cause of this smell, "eggy" is not associated with motor or electronic overheating problems. Hope this helps, if you cant cure the smell with these tips, then unfortunately the machine has to be taken apart and the offending item cleaned out - if you fancy trying this yourself then please ask again and we could talk you through it, Good luck :)
Posted on Apr 14, 2007
SOURCE: Bosch Maxx 6 WFL 2061 Front Loader W/M
brushes usually available on ebay,
if the drum rotates but does not spin, this could likely be brushes or component problem (i.e triac or relay) on control PCB. - the latter was the problem i had and this was easily spotted as a blackened track on the Relay on the pcb.
Brushes should be ~£5. - check the existing brushes first before buying them.
fitting is easy, BUT a word of warning..which you probably know anyway..
before meddling though in the machine, locate the large capacitor and with electical screwdriver and discharge all the terminals to earth first! - YOU MUST DO THIS TO AVOID ELECTRIC SHOCK!! - even if the machine is unplugged.
remove motor & undo the back plate to release old brushes.
clean of motor of any excess carbon dust, - this can eventually cause arching if not cleaned away.
reassemble and fit all plugs back.
THEN TAKE 5 MINUTES TO CHECK WHAT YOU HAVE DONE BEFORE SWITCHING ON. -
Do not rush anything - take your time.
Posted on Apr 26, 2008
ngfam1
  • 639 Answers
SOURCE: have recently moved into rented
Hello Sarah,
ngfam at your service
bosch .com and download it!
or order one from them.
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
  • 223 Answers
SOURCE: LOOKING FOR USER MANUAL FOR WFT2400 BOSCH FRONT LOADING WASHING MACHINE
Try this website: www.bshappliancecare.com and I think you might find what you are looking for. Good luck.
Posted on Sep 26, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
Hi! re BOSCH washing machine WET 2820 Program will start, and then for 30 secs approx start normally, water starts to enter the drum. Then it stops, nothing happens. I have cleaned the soap dispens
BOSCH washing machine WET 2820 This video will show you how to change the door eal washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 07, 2011 | Bosch WET 2820 Front Load Washer / Dryer
We get the error code eo4 on our Bosch front loader, and it does not spin.
Hi, "E04" means the "suds or pump is blocked"
Bosch E04 Solution:
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say! I'd guess you could get wet.
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole to 6'oclock and it should come free.
  5. Once the door out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hands. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
  6. Pull out the trap that you just unscrewed and you'll most likely see the item that caused the E04 error code. There is an side of the trap that is marked that it needs to be installed facing downward, so watch for that when you put it back in.
  7. Read these direction upside down and backwards to put it all back together.
  8. Run a load and watch for leaks. You could leave the door off until you are sure you screwed the cap in tight enough.
Jun 23, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a E04 code and it won't spinout
E04" means the "suds or pump is blocked." Try ds..
  7. Read these directiosn upside down and backwards to put it all back together.
Hope this helps..
Thanks for using FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question.
Jun 06, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Washer just stopped, won't do anything, door is locked and I cant get it open its a bosch 900 rpm front load.
you can use a wet dry shop vac and attach it to the end of the drain hose to remove any water this will also unlock the door the check the drain pump for anything that would be blocking the flow of water
take off the small front cover to the drain pump pull the whit plastic zip tie and this will unloock the door.
Apr 10, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a bosch classixx 1200 when i wash a load of whites there is often a small amount of dark spots of deposit on the sheets if this is wiped off when wet it rubs into the material if we wait until dry...
Yes - I get this - you have to wipe the inside of the drum rubber ring - not just throught the groves but sludge seems to collect in between the rubber ring and metal drum; you will need quite a bit of kitchen towel!
Nov 09, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Have recently moved into rented flat complete with Bosch wvf2401 washing machine. I need a user manual as it seems to be trail and error getting it to dry .It also creases all my clothes v...
Hello Sarah,
Aug 25, 2008 | Washing Machines
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
170 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
