Question about HP 100_232_DJ_AIO_03_F2200_XPS_WW.exe
Can i set up a hpf2200 deskjet to work via wirless
    Prodigy:
    An expert who has answered 500 questions.
  • HP Expert
  • 510 Answers
No as this printer does not have wireless, it is USB only.
Posted on Mar 02, 2015
How to you get ur wii connect to internet ? do u have to have wirless internet
If you do not have wireless you will need this adapter to connect via a wired ethernet connection
http://www.nintendo.com/consumer/systems/wii/en_na/acc/wiiLAN.jsp
If you do have a wireless setup, enter the console settings and go to network settings and you will be able to set up the wii to access the internet via a wireless connection.
Apr 30, 2011 | Nintendo Wii Console
I have an acer aspireoneD255 and its not recognising erthnet connection on any modem so i cant configure it correctly also andriod will NOT set up
Hi
can you get wirless connection by sliding the switch over to the right
it is down on the bottom right of the laptop i believe
and when you plug the ethernet wire from modem to laptop via ethernet socket
it normally works just fine
Feb 22, 2011 | Acer Aspire One PC Notebook
I don't have the instructions that came with my HPF2200 printer/copier/scanner. I can print and copy, but I do not know how to scan.
You will place the document you want to scan into the printer and inside the system you will go to start, then programs, accessories and paint. from paint you go to file then click on from scanner or camera and your document will be scan and you can print it. Thanks
May 12, 2010 | HP Deskjet F335 All-In-One InkJet Printer
I can't connect to my HP Deskjet 460 via bluetooth, only via cable (usb). I have installed the printer via cable, and then I try to install the wireless connection via "Add a bluetooth unit" in the "My...
Is your Deskjet still in the default "Private" mode? If so, change it to the "Public" mode.
In the toolbox, go to the printer services tab and choose configure Bluetooth settings. Change the mode to public mode.
Go to --> http:/h10025.www1.hp.com/ewfrf/wc/document?docname=c00625408&cc=us&lc=en&dlc=en&product=466208
Feb 09, 2010 | HP Deskjet 460c InkJet Printer
Can connect to DLINK adsl2 router via wirless but
Make sure your LAN connection is not disabled,
make sure that you are getting a valid IP address form the router
If you need commands for this let me know, also which OS are you using
Jan 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
Want to get on internet with my lap top via wireless what card do i need for the inspirion 8100
first of all you need to check with your internet provider to see what modem you can use. a wirless 802.11g card (the farthest range) if your provider has a wirless modem i would get it from them. and a wirless modem/router. i use bellsouth wirless dsl and bought the equipment from them. if you have a wirless modem/ router already then you just need the card and configure it.
Jul 26, 2009 | Dell Computers & Internet
Wirless not working
hi!!!
did you try to re-install
the driver of your wifi?
Nov 12, 2008 | Acer Aspire 5315 Notebook
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Belkin 54G Wirless Router PRoblem
I tried 1 of those for wireless internet and ps3 for hours with no success. Returned it for a higher end model (around 100$) instant success all around..
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
110 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
