Question about Samsung CLX-3175FN Color Laser All-in-One Printer
Stampante multifunzione CLX-3175 dice sempre " errore di sistema spegnere e riaccendere" ma spegnendo e riaccendendo non si risolve nulle e dopo il riscaldamento ripropone il solito errore. Fatemi sapere cosa fare, grazie. Antonio
SOURCE: LA SPIA LAMPEGGIA SEMPRE ARANCIONE
Posted on Sep 03, 2008
anjana03
  • 361 Answers
SOURCE: samsung clx 3175 toner chip overide/reset?
we use chip and fuse for samsung cartage reset when it give us cartage empty message. before geetting thish we gets tonner is low .if recently we filled samsung dust/powder/tonner in cartage we no need reseter. in my practics while i need to put fuse (reseter) i put iton cartage after resetin suddenly i putout it from cartage and use old fuse. in this way we can use or not green chips? actuly it is difficult.
Posted on Jun 12, 2009
  • 22 Answers
SOURCE: CLX-3175 refill
Refill not recommended. Replacement is the way to go. You can pickup replacement toner cartridges from you local electonics store or where you purchased from.
Posted on Aug 14, 2009
komguy
  • 2306 Answers
SOURCE: My clx-3175 wont print black and white when color
All of the manufacturers do the same thing to get people to buy their toners, if any toner is empty you don't get to print even black. Sometimes empty toner can scratch a drum so that's the excuse they use for making them that way.
Posted on Feb 05, 2010
SOURCE: recognizing samsung yp-u3
my computer say when i go to connect it cannot connect i onli got it today do u know what i cud do??
Posted on Jul 22, 2008
Perdita di memoria dopo ripetute interruzioni di elettricita
Questo e comunemente un problema con un cattivo ariete bastone. Un aumento in precedenza probabilmente danneggiato e sta ora causando problemi come il computer tenta di utilizzare lo spazio di RAM danneggiata . Cioe se ho capito bene . Se vuoi dire che stai perdendo i dati salvati dopo un'interruzione di corrente questo e perche non e stato salvato nel disco rigido prima che l'aumento di potenza provoca il computer di spegnere .
Se hai spegnimenti ripetuti questo potrebbe essere un alimentatore difettoso .
Fissare al primo possibile problema : riposizionare ram prima , facendo in modo che tutti i collegamenti sono stati fatti . Se questo non risolve il problema in aumento che si sta spegnendo , sostituire la ram.
Possibile problema due : accendere autosave e accendere il recupero in programma o del sistema operativo , se disponibile , assicurarsi di salvare spesso .
Fissare alla terza possibilita : Primo controllo per vedere che non e la vostra presa a muro . Se si tratta di un computer portatile eseguirlo a batteria solo per vedere se ee la batteria che causa un guasto elettrico , quindi eseguirlo puramente off della tensione di alimentazione , senza la batteria. Alcuni portatili non consentono di fare questo pero, quindi potrebbe essere necessario portarlo da uno specialista di riparazione computer . Se si tratta di un desktop o laptop cercano una presa a muro diversa o lo prendono a casa di un amico o di un altro business . E 'possibile che hai un cattivo presa o cattivo cablaggio in casa che sta causando aumento.
Se non e nessuna di queste, scaricare uno strumento di scansione del disco rigido (come Acronis) ci sono molti che sono gratuiti online e controllare l'integrita del hardware utilizzando il disco rigido e costruito in SMART strumenti diagonistic.
Oct 14, 2013 | Computers & Internet
Funziona 10 minuti poi si accendono e lampeggiano insieme la spia verde timer e la spia rossa turbo, se spengo e accendo di nuovo riparte e si ripete il guasto sempre dopo 10 minuti
Ciao.
Il frigo ti sta dicendo che non riesce a rafreddare come dovrebbe. Il caso piu comune e' dovuto a sistema di defrost che non funziona.
Prova a eseguire un defrost completo, staccando la spina (o l'interruttore) e lasciando il frigo staccato con porte aperte tutta la notte. Se questo risolve il problema allora era il sistema defrost. Se il problema ritorna in un paio di giorni o settimane devi riparare il sistema defrost. Il sistema defrost e' situato dietro la parete in fondo, di solito nel compartimento freezer. Il sistema comprende un evaporatore, che e' una resistenza che riscalda le spire del condensatore per prevenire congelamento. Il sistema comprende anche un termostato e una ventola (non quella di refrigerazione, un altra). Se il problema sparisce con defrost e ritorna in un paio di giorni queste parti vanno controllate. I test si fanno leggendo le resistenze delle singole parti.
Se il defrost non risolve il problema, cause comuni per il guasto sono:
Condensatore sul compressore da cambiare.
Sistema ventilazione (se presente in questo modello) non funzionante.
Controllo elettronico della temperatura diffettoso.
Perdita di gas refrigerante.
Le parti relative ai guasti elencati devono essere controllate.
Inizia controllando se il defrost ha a che fare con il problema. Quella e' la causa piu comune per it tuo problema ed e' facile da diagnosticare, anche a livello utente. Usa il numero che trovi nel manuale per ottenere parti, per verificare stato di garanzia, o per ottenere un appuntamento con un tecnico.
In bocca al lupo.
Ginko
Aug 10, 2011 | Refrigerators
Why is my D5160 printer flashing red Exclamation sign?
sto cercando di stampare documenti ma non parte. ho sostituito la cartuccia di nero, ma il punto esclamativo rosso, lampeggia sempre. la sprngo manualmente,ma dopo si riacende da sola.che cosa ha?grazie
Feb 16, 2011 | HP Photosmart D5160 InkJet Printer
Ho cambiato le cartucce alla mia stampante mp 630,mi riconosce solo il giallo e il magenta,ho fatto una 20 di volte la pulizia ma niente
Ciao.
Assicurati d'aver rimosso il nastro adesivo dalle cartucce.
Controlla i contatti dentro l'alloggiamento delle cartuccie. Eventuamente pulisci i contatti con alcol e cotone idrofilo.
Fai un test usando altre cartucce. Cartucce difettose sono un problema abbastanza comune.
Se questo non risolve il problema, e la stampane non riconosce NESSUNA cartuccia, neanche le originali. Allora qualcuno dei contatti dietro la testina e' probabilmente rotto.
Questo tipo di guasto non e' comune, di solito sono cartucce difettose, sensore nell'alloggiamento sporco, o problemi software.
Controlla anche il software stampante, reinstallalo rimuovendo prima la stampante dal pannello di controllo. Assicurati d'aver seguito la procedura di rimpiazzo usando il software Canon. Il semplice scambio di cartucce puo dare adito a problemi.
Jul 01, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Come si sblocca la porta di ascolto di bit comet?
Anche se molti altri programmi di condivisione di file utilizzare la porta 1214 come punto di partenza e quindi porte switch da lì, Bitcomet possibile utilizzare qualsiasi porta. Secondo fonti riconosciute - "BitComet sceglie una porta casuale ad ascoltare quando si installa", ma un'altra fonte dice che "le porte di default sono TCP 6881 - 6999". Inoltre, come parte della di configurazione di, BitComet gli utenti possono selezionare il proprio numero di porta.
Quindi, poiché gli utenti possono scegliere quali porte BitComet usa, si stanno per essere combattendo una battaglia persa in quanto sempre un passo avanti.
L'unica soluzione è quella di consentire solo le porte che si conosce altri programmi utilizzano.
Spero che questo aiuti, wbwteam
Mar 21, 2010 | Computers & Internet
Problema di bloccaggio HP C5180, errore inchiostro 0xc18a0107
HOLA!
YO TUVE EL MISMO PROBLEMA CON MI IMPRESORA HP PHOTOSMART C7180 ALL IN ONE ,,,,Y LO QUE HICE FUE LO SIGUIENTE:
1.-ESTANDO ENCENDIDA LA IMPRESORA, DESCONECTE EL CABLE POSTERIOR(EL DE ATRAS DE LA IMPRESORA)
2.-PRESIONE LA TECLA DE "OK" Y "AYUDA" AL MISMO TIEMPO COMO UN MINUTO
3.-VOLVI A CONECTAR EL CABLE POSTERIOR
4.- LUEGO PRENDI LA IMPRESORA
5.- CAPTURE LOS DATOS QUE ME PEDIA, POR EJEMPLO: IDIOMA ESPAñOL, PAIS MEXICO, ETC.
6.- Y EMPEZO A TRABAJAR CORRECTAMENTE
MUCHA SUERTE, ESPERO LES SIRVA ESTO QUE A MI SI ME FUNCIONO! SALUDOS REBE!
Jun 19, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hi no harm in trying I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 15, 2009 | HP Photosmart C5180 All-In-One InkJet...
Scanner
Questo spesso succede quando colleghi la stampante prima di aver installato il software, o quando non installi tutto il software.
Devi installare tutto il software presente sul disco, controlla anche il cavo usb, un cavo usb difettoso puo far funzionare la stampante e non lo scanner.
Se non funziona, fai un system restore (recupero del sistema? non mi ricordo come si chiama in Italiano.
Dicevo fai un system restore da Avvio>>programmi>>accessori>>utilita di sistema...
Questa procedura riportera' il computer come stava prima che Windows installasse automaticamente i driver per la stampante.
Dopo il system restore installa tutto il software sul disco della stampante SENZA collegare la stampante finche' esplicitamente richiesto dal programma di installazione.
Se non hai il disco devi scaricare i programmi dal sito Lexmark, che pero e' in inglese, o chiedere una copia del disco al rivenditore.
Qui c'e' il sito web della Lexmark : Official Lexmark Drivers and Software
In bocca al lupo.
Nov 20, 2008 | Lexmark X2500 All-In-One Printer
Lettore cd/dvd acer aspire 5630
Ciao,
Allora, ho il tuo stesso pc e mi è già capitato il prob. Mi sè risolto formatando il pc ma non è minca finita qui..
dopo un mesetto mi si ripresentato. La coluzione defintiva è stato quella di sfruttare la mia garanzia per farmene spedire uno nouve di zecca. Ovviamente solo il pezzo guasto.
Se no puoi provare a smontarlo e pulire il lettore dvd con l'alcol (xkè evapora).
Tienimi al corrente per eventuali sviluppi.
Ciao
Jul 18, 2008 | Acer Aspire 5630 Notebook
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
1,715 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
