Question about Garden
We have recently purchaed a new Honda gasoline powered lawnmower Model HD510. The accompanying User Manual does not explain the fuel ratio. It does say to add 0.6 litre of oil before starting the engine, but no information on how much fuel. Also the diagram on page 5 has illegible numbers indicating various parts of the machine. Advice on these matters would be appreciated before we start the engine. Thank you.
  • 32,281 Answers
According to the specs. this is a 4 stroke engine, the oils is for the sump and the fuel it uses is straight fuel, not two stroke fuel mixture of oil and fuel.
Posted on Oct 06, 2010
Can anyone tell me the correct fuel/oil ratio please or know where i can download a user manual. Cheers
that makes it a two stroke
user manual
..what make of chainsaw and model
fuel oil ratio
depends on the brand and engine size
25 to 1 10 to 1 some the same ratio as weed trimmers
Jun 18, 2016 | Garden
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
Does 2stroke go in gas
If you are referrig to 2 stroke oil, the answer would be no. Generally speaking 2 stroke oil is mixed with gasoline at the appropriate ratio and is used in gas powered weed eaters and chain saws. A lawnmower for the most part is considered a 4 stroke motor. You only need to use gasoline in the tank. Make sure that at the end of the season the gas tank is pretty low or even allow it to run dry. This is simply to avoid the harmful deposits that old fuel can cause to gaskets. If emptying of the gas tank is not easy, you can add fuel stabilizer to ensure that the fuel is usable for the next season.
Jun 30, 2014 | Poulan Pro 22inch 625 Series Briggs ...
What is the fuel to oil ratio?
For most mowers it's just straight gasoline, but there are some that vary slightly. Check the manufacturer website to make sure, but again, most (about 90%) mowers take just straight gasoline.
May 20, 2011 | Garden
What motor oil do i use for my 2005 CR125 honda
You need to use a 2 stroke motor oil. Look for oils that say 2 stroke motorcycle oil, injector oil or smokeless. Do not use a standard automotive motor oil, your bike will smoke. It should be pre-mixed with your gasoline. I am relatively sure the ratio is 32:1, but you should check your owners manual to be sure. At this ratio you would use 4 ounces of oil to each gallon of gas. This ratio allows for an all-around use of your bike. If you are not going to use the bike at high speeds for extended periods, you may want to consider a different fuel/gas ratio - 50:1.
The above information is recommended for a Stock motorcycle.
Regards.
Jan 09, 2011 | 2005 Honda CR 125 R
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
What is the correct ratio for fuel mix for a ECHO weed trimmer..SRM-210
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Sep 04, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Fuel mixture appears to be too rich on myHonda lawnmower
There is an air/fuel ratio adjustment screw on the side of the carburetor. Turn this back and forth until the mower runs smootly.
May 04, 2009 | Garden
Oil
40:1 fuel mix ratio is good for this model. you put gas in the upper tank and 2 stroke oil in lower tank the mix pump will do the mix, if you are not sure the pump is working properly, mix 4 ounces of 2 stroke oil into 1 gallon of gasoline and put the mix in the upper tank, it reach the carburator by gravity
Nov 20, 2008 | 2005 Honda Dio
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
