Question about Logitech Media Multimedia Control Panel
KEYBOARD IS NOT WORKING WHEN I SWITCH ON THE SYSTEM IT THROWS AN ERROR AS KEYBOARD NOT FOUND
Select boot device Error after keyboard spill Wierd results
It is more than likely the motherboard has been compromised, you will see white spotted area's where the liquid has spilt. I have fixed a few boards using a stiff toothbrush and rubbing alcohol, but to be successfull this needs to done quickly. If you are able to clean everything off and it seems to work check out www.ebay.com Type make and model, refine search to keyboard.
Jun 26, 2012 | ASUS Computers & Internet
Will not turn on says door
There are 3 door switches arond the door that can throw up this error but if the 2 fuses are blown also it will throw up this error. You can ohm out any of the fuses or even the door switches but until you repair them it wont work. I have even found both fuses to be blown. If you are nervous about pulling apart your stove make sure whoever does is very familiar with this line of Kitchenaid. Hopefully this helps.
Jan 30, 2010 | KitchenAid KBMC140H Convection Microwave...
Keyboard error or no keyboard present, the
Have you tried to disable the PS2 keyboard and plugged in a USB keyboard..? You may have to go into the bios and switch on USB legacy support..
Nov 12, 2009 | ASUS P4B266 Motherboard
Logitech MX3200 Wireless keyboard connects but prints garbage
Yes, I have a solution. Throw the bugger away! This has been the biggest piece of garbage I have ever bought. It has loads of unecessary features like using the buttons for other things. I am sick of it asking me if I want to assign an action to a key. I want a bog standard wireless keyboard. Yes, I'll assign an action alright. I'll throw it through the bloody window!!!!!!
Jun 23, 2009 | Logitech Cordless Desktop MX3200 Laser...
Keyboard problems
Go to Control Panel --- then System -- then device manager -- under keyboard right click and go to update driver.
If that doesn't work, go into control panel and there should be an Icon for KEYBOARD. Check the "Key settings" and make sure it set to "Standard" and not custom or gaming.
Hope this helps!
May 27, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Keyboard and mouse is not working.......
It means that the computer doesn't see the keyboard and the bios is posting out with an error. Try another keyboard or disable the bios setting that defaults on keyboard errors.
Mar 26, 2009 | Compaq Computers & Internet
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. musekye318@yahoo.com
    Jun 30, 2008 | IBM NetVista PC Desktop
    16TRACK SONG RECORDING IN 'YAMAHA PSR3000'
    i have yamaha psr 3000...
    in my keyboard has some problem like system error...
    when i switch on my keyboard this problem is arises...
    please help me....
    Apr 29, 2008 | Yamaha Computers & Internet
    Keyboard and mouse problem!
    I've had this problem happen lots of times before. usually restarting the PC with the switch enabled to the PC that is booting will solve this problem. For some reason, sometimes the drivers don't load for the mouse and keyboard when starting up the PC.
    Dec 16, 2006 | D-Link (DKVM4K) (dkvm-4k) 4-port KVM...
    Logitech Media Multimedia Control Panel  Logo
    76 people viewed this question
    Top Logitech Computers & Internet Experts
    micky dee
    Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
