My washing machine - WD10263TP - stops working in the middle of the cycle and flashes with the sign dE coming on. The technician has just made me buy a new front for ?170 and the same problem occurs.
  • bouleorama Oct 06, 2010
    The machine was locked properly. The cycle starts and stops after a few minutes. The control board has just been replaced. Could it simply be the lock? I cannot understand why it would unlock itself in the process of washing ....
  • 10,515 Answers
This is a common error on this LG washer.The meaning of the DE error is listed below and the corrective actions. In a nutshell the door lock is not engaging correctly. If when you try to start the machine you hear the door click but then you get the DE message then the door lock is bad and should be replaced.
If the boot is clean and you have a new lock and the pump is clear you have a control board issue the control is bad not telling the lock to stay locked.Unfortunately, in this case you need to replace control board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 06, 2010
  • taran_2005
    taran_2005 Oct 06, 2010
    Thanks for your response!!
    This message is usually for faulty door lock assembly.You would need to remove the top panel and remove the door latch assembly in order to correct the issue.On the lower front panel there is a access hole take the cover off and remove the filter out of the pump it just twist out.Make sure there is no lint and other stuff there. Also, make sure that the pump is clear.Try opening and closing the door, sheck to see the gasket isn't jamming.
    Hope i helped you.
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
Aug 04, 2011 | Whirlpool AWM8143 Front Load Washer
DE comes on in the middle of the cycle and the machine just stops working
Hi
Thanks for using FixYa. DE is a door open error, you'll have to check the door if it's properly closed. Also check loose electrical connections at the door switch and PWB assembly. If everything appears to be fine then it is the door switch assembly that should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | LG Washing Machines
I have a fully automatic whirlpool washing machine H-65 model. Rcently, it is sterted displaying the error code-"dE" after finishing bthe wash cycle. That is, the machine does washing and drains the dirty...
Hello Ajithkumar,
"H-65" is not resolving as a MEANINGFUL
MODEL NUMBER...
Most Frequent Causes for dE - DOOR OPEN ERROR // Main control detecting a problem with door/lid lock system...
>> In the MIDDLE of a cycle...
I would first have to ask if you are IGNORING
the very VITAL INSTRUCTIONS to use only
"HE" (high efficiency) washing detergents...
IGNORING this very IMPORTANT instruction is
PURE NEGLEGENCE and can damage the machine.
I would suggest if you don't want to buy a replacement
machine... you treat this one according to the OPERATING
MANUAL.
Carnac the Magnificent
Aug 26, 2017 | Washing Machines
Washing machine comes up flashing with a de sign
LG machines with DE (Drain Error) Water has not drained enough in 5minutes...Probably due to a partially blocked pump filter....Repeat drain to empty machine and cleat pump filter,,,Access via small door at floor level, unscrew pump cover, and clear filter... Some water may be released. Leaning machine back can help!...Good luck..Nomess
May 17, 2010 | Washing Machines
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
