Question about Electrolux Refrigerators
Hi i have a 3 way electrolux fridge. it cools perfectly well on the electric mains, I've not tried the 12v, but it fails to cool on the gas. The gas ignites but fails to cool the system.
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
Posted on May 29, 2008
Electrolux refrigerator not working properly i have change new one picture i ve attach here thou sometime it run but after few minute it stop please suggest what should i check.
Hi, have you tried adjusting the thermostat control, if the fridge is not cooling enough you can set it to a lower temperature. There will be a rotating knob somewhere on your fridge that can turn the temperature down. Sorry if I appear a little confused, the fridge is supposed to stop after a few minutes of cooling, it should not be using the compressor all the time.
Maybe lowering the temp will soet the issue.
Jun 15, 2015 | Electrolux Refrigerators
Hi just bought campervan which has an electrolux rm 2200 fitted we are unable to use it on 12v but works well on mains.
was the engine running on vehicle when you tried to operate 12v mode. From the user manual it needs the fridge cooled down on gas or mains first and it will only operate at 12V if the engine is running to prevent vehicle battery running flat.
Aug 13, 2014 | Refrigerators
My caravan fridge will not work on mains or 12 electric but it dose work on gas
The 12v power supply on the fridge takes a lot of power, and can only be used when you're driving. (When the engine runs.)
Regards,
Jul 09, 2011 | Electrolux Refrigerators
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
Freezer working perfectly in our Electrolux enb35405s but fridge is not workingat all.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 28, 2011 | Refrigerators
I have a 2453 150 litre caravan fridge not working on 240 but works on gas. What maybe the problem and can i get a mobile repairer
It sounds like the electric heater is not working as you say it works on gas, so the expensive bit is OK.
An appliance engineer should be able to get the spares and fix it.
Mar 07, 2011 | Microwave Ovens
Electrolux 3 way fridge will not work on 12v or 240,switch lights up, ok on gas. can i repaire?or have i got to replace? i think the model No is rm4200 or rm4230
Hi My three way fridge has the same problem. Have solved the 12v problem as it was not wired to the 12v invertor. Do you have an on board battery supply? the 12v is usless and runs a battery flat in no time. Better off to use gas. Hope to have the electrician here next week to check 240v so will let you know if we find a problem. Graham.
Jul 07, 2010 | Electrolux Refrigerators
I have 660 hobby van and a electrolux fridge gas and electric, when you turn it on with electric nothing happens when you try gas i can hear it light but the fridge does not get cold please can you help
Hi , I am guessing this is a kind of RV. If it is, I am wondering if you just got it?? If you did just get it then I will say that those kinds of Refrigerators can take up to four hours to show good cooling. Just a thought. Wayne
May 21, 2010 | Electrolux Freezers
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Refrigerators Logo
358 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
