Question about HTC Touch Viva Cell Phone
I have a laptop that i tried to format and not able to boot or install OS again. so i've removed the notebook HDD and connect to other PC via usb cable. but then i'm not able to install OS on that from other PC. I want to install OS on an external hard disc using other PC. Is that possible.? do anyone know what to do.?
    Guru:
  • 528 Answers
Have you tried to set the BIOS boot sequence first priority(ODD) of your laptop?
try this
1. restart the system and while screen is turning on keep on pressing F2 then look on boot then the 1st should be ODD then once you did that press F10 to save and exit then try it again by rebooting system then press F12 while screen is turning on to install OS in you laptop
Posted on Oct 06, 2010
Bootmgr is missing
when you were uploading your OS and if an HDD or USB was connected or you have a complete system restore lying around somewhere, You're boot mngr is in there . Did you do a clean install? If so than your OEM and Boot options is in an EFI partition hidden on an internal HD and is Linux based. If you go to your MMC console and hit Disc Manager, you'll see something like 100 mb EFI , with no Disk letter assigned and also a MRP, Which is a Microsoft reserved partition.. Kookie stuff goin' on in that ASUS place.
Dec 14, 2012 | ASUS Eee 4G Notebook
When turning on my laptop (DELL Inspiron 1545) the set up starts until I get the message 'BOOMTRG is missing, Press CTRL+ALT+DEL to restart'. Along with this, there is a yellow flashing light
This is an error message your operating system boot manager file is corrupted or missing. A clean re-install may solve the issue. Sometimes you need to format the entire HDD to install the OS. Remove the HDD from the drive bay and connect it to another pc using an external 2.5" case via usb cable and select that HDD from computer and rightclick then format. Select ntfs if needed. Untick the quick format and click OK. it takes a while to finish. After format complete remove the HDD and refit it in your laptop and re-install OS as usual. Hope this helps.
Dec 05, 2012 | Dell Red 15.6" Inspiron 1545 Laptop PC...
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
There is no bootmgr after formatting the whole c drive
when you reformat the hdd it removes the boot manager reinstall the os for a new bootmgr
Feb 15, 2011 | Acer Aspire 7720 Notebook
1525 Dell Insp. - i"ve already formatted it once
hi
all you need to do is take the recovery CD that came with the system, isnert, reboot the system to load from DVD or CDROM. and copy the boot sector into your hard disk, C or whatever letter you have .
reboot system again, take the data installed on your HDD c letter , and create a driver letter, and then copy that data to the new drive letter.
Nov 16, 2010 | Dell Inspiron 1525 Notebook
HP Compaq 7300. Tried to load Windows XP but before installation cannot see HDD, yet in BIOS one can do HDD integrity check and akk ok. Where is the problem?
You need to format first. If install cannot see drive, drive maybe faulty, or need an F6 driver SATA.
www.custompcblog.com/.../installing-windows-xp-sata-hard-drive
Check out link above.
If you cannot, format and "See" the drive, then it is most likely faulty. To test you must get a SATA/IDE USB Dongle, they are a few dollars. Connect uo the harddrive you have taken out of the laptop, and connect up via the USB poet, on another PC. IF it installs and shows up, then the problem may lay with your laptop, however, at this point, if you want, and drive is blank or you don't want anything on the drive, use Windows, and Format the drive, NTFS, now. Then take it back to laptop and try to reinstall. IF it STILL will not "See" the drive, then the laptop is definitely faulty. if it does, continue on and install Windows. Remember to set BIOS to Boot from DVD first. and set back, at finish of install.
Mar 28, 2010 | HP Compaq nx7300 Notebook
My Laptop ASUS A8Jp ask for a HDD password
Hi
Have you tried Debug ? First run a Debug and that will remove everything from the HDD including the partitions and than do a fresh OS installation
Aug 30, 2009 | ASUS A8Jp Notebook
Continuous configuring
Did you try F8, safemode? You may have bad sector on HDD.
Check your date and time with bios page. Set your primary boot to HDD
try again. Otherwise, Remove all powers, Take off HDD, put on USB connection and check error by another computer (Must use same OS)
Open as D;\ > or some other as L:\ next to the C:\
Rigth clcik on go to Tools, scan with it., Install the HDD back to your laptop turn on, (Before any process do not forget to remove power and battery)
JMC
Aug 14, 2009 | Acer Aspire 5720-6661 Notebook PC
IBM Think Pad TDD
reinstall the OS, but first back up you files. you can remove the HDD located at the bottom of the Laptop. buy a cheap 2.5 inch usb to ide/sata enclosure and place your hdd on it. use a PC to transfer your files. then format the HDD. reinstall the HDD to your laptop and install the OS.
Jul 06, 2009 | IBM ThinkPad T22 2647 Notebook
After fdisk and format of hdd install of os freezes after 2min. when it says windos is starting, tried differant versions of windows does the same thing!!!! Please help!!!!!!
PXE media failure means the system is trying to boot via Network card not your hard drive. When you performed fdisk then formatted the disk, you might have not selected an active or logical partitioning to support the OS. Run the PSA diagnostics by holding the Fn button before turning on your computer. If it gives you an error, it means your HDD has gone bad and needs to be replaced. If it freezes during the the loading of files during the installation, it means that your RAMs are bad because the windows loader dumps all the information to the RAM chips. If it does hang during the installation of files, two points of failure are to be looked upon, the RAMs and the HDD. I recommend you reset the BIOS to the factory settings as to reset the boot priority so it does boot to HDD first, not to any of the bootable drives available on your computer.
May 15, 2009 | Dell Inspiron E1405 Notebook
HTC Touch Viva Cell Phone Logo
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
