Since it was moved the last time, my 42" rear proj tv developed a blurry area in the lower left corner (which i believe has increased a little upwards recently). i have been told that the rear lamps are probably out of alignment but it is cost prohibitive & illogical to spend so much $$s ( i can probably put another 100/200 & buy a new one! any suggestions!!!
In most cases, when you have a blurry spot in the corner after moving a proj. tv it is caused by either an adjustment needed to convergence in service menu or a crack in the mirror. The easiest way to find out which problem you have is to look inside. On most 42" sets the speaker grill comes off and the screen can be removed revealing the tubes and mirror. Some 42" sets you have to remove screen from behind set. Be careful mirror is very thin and fragile. Make sure if unit has a collapsable back that it is pulled into fully extended position. If you are patient enough and very careful only to adjust what needs adjustment, you can probably find the service code for your set online and perform the adjustments yourself. On older sets small door behind grill reveals analog convergence controls. Hope this heps fixya.
There may be dust on Lamp or at front screen. why dont you open rear cover of TV and give a close look?
