Question about Marley PJ1257 Heater
DF100TLK pcb burnt out Where can I get a
DF100TLK pcb burnt out Where can I get a replacement?
Indesit washing machine pumnp burnt out, replaced it but it still won't pump or spin. Does it need a new programmer or can the programmer be fixed?
You're absolutely right. If you look at the wiring diagram on the machine it is clear that the drain pump is powered by triac on PCB (part code C00270972).
I think it is definitely safer and probably cheaper to replace than to repair the PCB.
It is always a good practice to visually inspect PCBs that there are no visible defects such burnt out elements, etc. before replacing. Sometimes the reason for burnout PCB may be on a completely different side.
25580311-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Dado
Mar 16, 2015 | Indesit Washing Machines
Panasonic TH-58-PX60U GREEN LINE
if it does not go all the way across the screen, may be the buffer board controlling that area. you can usually visually check for burnt/overheated parts, then replace that particular buffer. could also be X or Y sustain PCB depending on whether it is vertical or horizontal.Again, you might do a visual for burnt/overheated parts on the particular PCB & replace either parts or PCB.
Lastly , may be panel....not cost effective.
Apr 26, 2014 | Panasonic TH37PX60 37 in. Plasma...
Pcb_w10209636 where can i get this pcb board?
W10209636
Here is a link for you if you like to use them, but any local parts house close to you should be able to obtain this part for you.
Good Luck
Nov 17, 2013 | Whirlpool Refrigerators
When oven was being used. There was a pop...and the code now displayed is F1 and dr. We have a frigidaire drop in unit
the pop you heard was the pcb. you may see the burnt component and try to replace it ot it may be a part of the tracking but it will be better to replace the pcb.
Feb 13, 2010 | Kitchen Ranges
Burnt ic chip on Korg microKorg pcb.
search diagram microkorg in google, and sorprise is the manual service n pars of ic 5 is IC S-8520F33MC-BNS-T2 best regards!!!!....
Jun 02, 2009 | Korg DTR-1000 Microphone
Gateway ma7 will not power up
Gateway MA7s have dodgy DC sockets. Poor solder joint on +ve pin = increased resistance = lots of heat = burnt PCB around +ve pin usually shorting the +ve pin straight to ground. If you're lucky you might still be at the poor solder joint stage and the DC socket might simply need replacing and/or re-soldering. If not, it could be a burnt PCB and it's a pain to bypass the burnt areas due to how the power gets distributed around the PCB.
Apr 18, 2009 | Computers & Internet
Resistors R30 and R31 on pcb 4233-1288d-b completely burnt.
R31 47 ohm 1/4 watt 5%
R30 100 ohm 1/4 watt 5%
Jan 26, 2009 | GPS
Hi Mate, I have the exact same problem, casued by wrong adaptor being connected by accident, did you manage to find what the code is on the IC5 chip ?, I can see NSV, but there is another letter or number before it but cant make it out as that where its burnt.
Jan 17, 2009 | Korg Music
How data can be recover when hard disk PCB burnt
mandyleo
yes, but both hard disk must be identical.
Jun 28, 2008 | Samsung HM160JU Hard Drive
Marley PJ1257 Heater Logo
61 people viewed this question
Top Marley Heating & Cooling Experts
paulcarew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
