Question about Bosch Washing Machines
Clothes keep coming out covered in brown sludge/ slime ?
  • 38 Answers
SOURCE: brown staining of clothes,increased noise on spin cycle
that brown sludge is grease from the bearings and the noise is the bearings breaking up stop using the machine and get them replaced 2 supply and fit new bearings and drum support should nt cost more than £90 good luck not realy a job 4 a novice
Posted on Aug 06, 2007
SOURCE: Candy GO 146 Washing Machine
Buy Gorenje.
Posted on Oct 04, 2008
  • 211 Answers
SOURCE: Brown sludge under drum making washing dirty
You can try to wash on a high temperature with some soda instead of washingpowder.
And offcourse without any clothing in it.
Due the modern washingmethode's the temperature is always very low.
Then you get some dirt sticked into your machine.
We had the same problem, but it's solved now.
Hope it helps,
Gerard
Posted on Nov 17, 2008
rdrsp
  • 85 Answers
SOURCE: A build up of brown slimy mould which marks clothes
try manualy cleaning the door seal with bleach and then amonia, ( NOT TOGETHER, ONE AT A TIME )
then pour some amonia into the machine and run it. amonia and/or vinegar work great to clean washing machines. but please note : this should be done seldomly as Amonia is a corrosive towards electrical parts.... hope this helps.
Posted on Oct 19, 2009
  • 1244 Answers
SOURCE: Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Posted on Jan 13, 2010
Why is rust-colored slime leaking out of top of water heater?
The water heater needs to be replaced. The rust-colored slime indicates that the water heater has a leak.
Sep 17, 2015 | Water Water Heaters
Next question, how do I get the slime out of the clothes from washer?
Cleaning the rubber door gasket will not get rid of the slime issue. The slime comes from buildup on the outside of the washer drum. There are two causes for this. First, if you always close the washer door after use, then the moisture inside the drum cannot dissipate and the slime can form. Also, using the wrong type of detergent (or an excessive amount of the correct detergent) can cause the slime. There are front load washer cleaning products that you can purchase and run to clean the slime from the outside of the drum.
Dec 15, 2014 | Washing Machines
Sometimes the clothes come out of the washer dirtier than when I've put them in! Brown streaks that sort of come of with my finger - sort of like wet dryer lint or sludge. Rewashing takes them away,...
Your washer has too much build up of sludge from excessive use of detergent and fabric softener. You will need to purchase a package of washer machine cleaner from the local hardware store and run the washer on either "clean tub" setting or "sanitary" setting without any clothes in it. Use the cleaner at least once a week for one month and then once a month for maintenance.
Use only 2 tablespoons of detergent per wash.
Good luck
Jun 17, 2011 | LG WM2301HW Front Load Washer
Jan 13, 2010 | Hotpoint Washing Machines
A build up of brown slimy mould which marks clothes after washing. The door seal is stained brown in places and the brown slime is building up in the folds of the doo seal. What can I do?
Oct 18, 2009 | Washing Machines
Stains on clothes coming out of the LG washer
are ther brown stains if so the bearings are faulty.
Jul 07, 2009 | LG WM2455 Front Load Washer
Washing machine does not wash clothes
You are possibly washing at the wrong temp, or not using sufficient powder or detergent.
The m/c is not rinsing properly, check that it is pumping o/k.
If there is a build up off slime and mould on your door seal, then you are definately washing at too low temp.
At least every 4 to 6 weeks, do a high temp wash with powder in but no clothes.
This is called a maintenance wash and helps to keep the inside parts clean..
If your door seal is stained, clean as best you can with a scourer pad or similar. You will not hurt the seal.
plz rate my solution .
Thanks.
Dec 17, 2008 | Washing Machines
Hope it helps,
Gerard
Nov 16, 2008 | Washing Machines
Brown staining of clothes,increased noise on spin cycle
Aug 06, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
